STD Tuning Engine M103 Oil Filter Housing on OM605
benjy_b
03-09-2020, 08:03 AM #1
Hi all,
I’m currently in the process of fitting an OM605 into a BMW E36. Whilst I could get away with the normal oil filter housing setup, I’ve decided to try fitting the M103 screw on filter housing to create some room for the cabin heater hoses.
I wanted to ask about the details of this. Comparing the two filter housing together they clearly have the same shape and bolt holes. However, there are a couple of discrepancies.
The OM filter housing has:
- a one way valve
- a thermostatic valve controlling oil flow to the cooler
- small gallery hole to the sump
The M103 housing has:
- a valve of some sort, maybe a pressure valve. But, it lines up with a blank space on the OM Block. So appears it would be no use.
- no thermostatic valve, but this makes sense, as I could fit a remote cooler and thermostatic valve.
- no small gallery hole to the sump.
I’m just after a few reassurances and some more information, that it’s going to carry on filtering the oil as planned.
This post was last modified: 03-09-2020, 08:06 AM by benjy_b.
benjy_b
Hi all,
- a one way valve
Messages In This Thread
M103 Oil Filter Housing on OM605 - by benjy_b - 03-09-2020, 08:03 AM
