W201 OM602 questions
Hello i am Hermann from Austria.
Usually im into Italian Cars and i own a Lancia delta Integrale Evo that is a little bit moded.
But now i want to start a STD project with a W201.
I have bought a rustfree 190 Turbodiesel with the OM602 engine.
At the first step i want to build the OM602 to a STD and maybe make a engine swap to OM605 in a year or something like that.
I have read a lot in the last time about the engines the Problems and what you need to build a STD and so on.
But still i have a lot of open questions and i hope somebody can help me with that.
I will start with the OM602 as i mentioned.
It will get a big intercooler the waterpump from a OM605 and the intake manifold from a 2.9 Sprinter.
We also will put Spal fans on to move the Watercooler back and make Space for the Intercooler.
The Spal fans will be regulated by a electronic thermostat so it wont will go over 85 deegres engine temp.
The Turbo will be a Garrett Gt28 71 with a costummade downpipe.
Pump will be 7.5 mm from Dieselmekken.
The suspension will be from Spax and the Brakes from a e300 24 v.
And from here my trouble starts.
Does the OM602 and OM605 engines have the same gearbox flanges?
Because i think the original cant handle that power long and if i build a ZF gearbox to the om602 i want to use it with the om605 too and dont build a new adapterplate.
And is there any upgrade clutch for the original 5 Speed gearbox from another Mercedes that i could use plug an Play at first before i have a ZF Gearbox?
How much Boost can the Om602 handle ?
Which ZF 5 Speed Gearbox fits the best in the W201 Chassis?
Sorry for the big load of questions but i couldnt find any good informations about that.
Thank you for the help.
