OM 606 crankshaft grinding
(01-28-2019, 07:55 PM)zeeman(01-28-2019, 08:09 AM)baldur(01-27-2019, 10:17 PM)zeeman You are not balancing the up and down motion with the crank. Your are balancing the rotating mass of the crankshaft. The pistons are balanced by their weight as well as the rods big end and small end. It doesn't matter if it is an inline or opposed cylinder. Balancing is balancing.Except there's an even number of evenly spaced rotating masses attached to the crank. You do not bob weight balance a crank for an inline 6 engine, you balance the crank by itself and you balance the rods by themselves.
I think the balancer is quite aware of that. What is your point?
