W124 250TD OM602 Superturbodiesel build
(08-03-2019, 08:04 AM)mmetzdavid(08-02-2019, 03:09 AM)NZScott Well, sure sounds like the vanes are fully shut to me? Is the actuator on the side still connected to the vanes?
The actuator and the vane lever are attached, yes. And it sounds not like if it would move the vanes in any direction, it sounds like the turbos shaft drops in rpm very fast, and when I lift off the throttle, and there are less gases going to the turbine, then the shafts rpm increases to normal again.
