OM60x timing device information
(02-13-2018, 07:16 PM)baldurCould you please make a cold start video of your car? I've made some yesterday of mine and I would like to compare the two is possible.(02-13-2018, 05:11 AM)addi.bigg(01-16-2018, 05:48 PM)baldur The engine pings like a machine gun at low RPM unless I retard the pump. I do however have it running smoothly at higher speeds and loads but it still is a bit rough at low RPM. Leading me to believe it would be of benefit to pull a couple of degrees out up to 2000RPM.
That could be interesting for me too. I also have noise above 2000rpm that dissapears above that.
Maybe that is because of the 7,5mm elements.
Yes, my engine sounded much smoother with 6mm elements. It was suggested to me to try special injection nozzles that reduce pinging. I will post an update when I have tested those.
I also want to do some development on the pump timing, find the curve that gives me the best performance.
