Upgrade w201 with w124 parts?
the brakes are an easy upgrade, also keep the brakes from the rear as spares (they also fit)
+ is it a wagon?
if so its almost the beefiest of the swaybars, but even with a sedan it will most likely be a big upgrade over the stock one in the w201.
al you have to do is cut about 1-2cm at the end of each side of the swaybar to fit the w124 swaybar in the w201 (front swaybar)
besides that, also the dampers are interchangeable (if the w124s is better)
aswell as the springs, i put w124 springs in my w201, and it got very high, but cut the coils till they are perfect and you will get harder springs as an easy upgrade with stock ridehight.
