Expiremental OM617 build
i have been running aluminum flex discs with polyurethane bushing inserts for a while now. however the flex discs will always be a weak point so im going away from them. i am going to a cv/double cardan joint based driveshaft to get rid of any flexible coupling in the drive line. the center carrier bearing is an easy issue to fix just remove all the old rubber in the carrier assembly and vacuum cast a high strength polyurethane its what i did for my flex discs i was running recently. i believe it was whipplem104 who was talking about his turbo 104 drag car would destroy a set of v8 flex discs in one good track day if you weren't careful with shock loading.
