W202 Wagon build thread - *NOW OM606*
(02-21-2017, 05:14 PM)erx(02-21-2017, 04:38 AM)Hario Shit it still runs the same after rebuilt elements fitted, you think it needs a pump swap? I do have a spare EDC pump from a friend so you think I should try that next? As prechambers are good, injectors are good, and the lines are clear, the only bad fuelling will now be coming from the pump..
If engine mechanical is ok then you can try to change delivery valves first. If it's lumpy on idle then loosen injector lines one by one and try to make clear which cylinders are not working.
