W202 Wagon build thread - *NOW OM606*
(01-12-2017, 01:40 PM)Hario(01-12-2017, 07:08 AM)charlysays(01-11-2017, 04:50 PM)Hario Bit boring but I made some rust repair progress, very satisfying, other inner rear arch to do then the weld-a-thon is complete
Well done. Once I started digging around on mine there were a lot of holes in the inner front wings. Worst bit was up at the top, in the channel where all the wiring runs just below the outer wing mounting rail. But anywhere where there was one of those weld studs for the inner arch liners there was a good chance of a hole.
You can buy M6 weld studs off ebay and plug weld them on, then drill out the black plastic nuts a bit bigger and it works.
Thanks, the front of mine is completely fine, I've had all the front panels off, it just has very localised rust to all 4 jacking points, NS and OS rear floor and the arches as above. It's started at the seams and progressed about 2-4" in every direction, fortunately I've caught it in time. I've used 3 cans of waxoil so far..
