S210 -> W203 brake upgrade or?
(04-03-2011, 01:33 PM)bmartins w210 300td discs upgrade
Hello.
I own a W210 300TD from 1997 with 300mm rotors.
I was wondering upgrading my rotors and calipers to 330mm from a S320 cdi or 400cdi or 500(W220).
I am almost sure that the calipers fit my car, but the rotors i don´t think so...
Can you tell me which is the best part that i can install there?
330mm from a W220 or 345mm from a C32AMG(W203)?
Does 345mm fit 17"?
Thanks
Hello fellow dieselheads!
I'm overhauling my '00 S210 320CDI in almost every aspect in the coming winter, and was wondering what would be the best brake kit on a budget.
I'm not rich so a full Brembo, D2, etc. kit is out of the question.
I was wondering if I install braided brake lines, rebuild a set of used C32 or E55 AMG calipers, install rotors and pads for the AMG calipers:
-Do the calipers bolt on to the stock avantgarde/sport S210?
-Do the rotors bolt on to the stock S210 bearing flange?
-What brand of cross-drilled rotors would you recommend on a budget?
-Are EBC Redstuffs the best budget pads for street use?
-Is there a better option to the AMG calipers at about the same pricetag?
I'd quote bmartins in his post "w210 300td discs upgrade"
Hello.
Does 345mm fit 17"?
Thanks
