Turbo Information Thread (Needs your contributions!)
(11-30-2014, 01:53 PM)Duncansport(11-17-2014, 01:21 PM)anjay Hi guys!
I am in process of upgrading my 602 with Goran's 7.5 mm pump. Obviously my stock turbo is to small. Locally I have available HE351CW and HY35. Which one of those two would be a better choice. I am looking for dd application so I am not much concerned about top end performance.
Most of my driving is between 2000 to 3000 rpm. Your advice would be much appreciated.
Anjay
Both are very similar, the HE offering a superior turbine design as well as a bigger compressor. I think it tops out at 67LBS. I think if your looking to DD the car and you do not want to modify you OEM manifold i would recommend something like a T25 based GT28. Both the Holset will be a lot more then you need for you 602 if DD the car. If you dont want to spend the money on a GT28 then you could source many different T25 turbos that would be offer more flow then your stock 602 unit and bolt to the OE manifold.
As my 605 build is progressing i've been back at the search for a good choice of turbo.
I've been messing with the BW MatchBot and finding the results intriguing.
Have a look..
F.R.A.S. i'd love your weigh in on this..
Borg Warner MatchBot
That is a nice turbo that can do better
intercooler efficiency is put in a wrong way
volumetric efficiency is put in wrong way
turbine efficiency is wrong, specially with that exhaust house
and there is more that do not end up...
That program is nice but beware how some things is put in it
Anjay
Have a look..
