STD Tuning Drivetrain Clutch for OM606 in -88 124 Mercedes
d557017
07-25-2020, 09:12 AM #2
Took the gearbox out of the car today to have a look.
I have found information that says that the Sachs 765 boltcircle diameter is 273mm, looks like the bolts then would end up in the line between the starter ring gear and the actual flywheel, maybe not so good i guess.
I have also been reading about the Sprinter singel mass flywheel kits, but apparently they won´t work if you have the long input shaft wich i belive i have since there is a pilot bearing for the gearbox input shaft in the crankshaft.
Is that because of the "snout" in the center of the flywheel that you see in this picture? https://www.dieselpumpuk.com/shop/clutch...lutch-kit/
Maybe the "snout" could just be machined away in that case?
I tryed to post some pictures but when i click on "add" the frame just reloads and the attatchment is gone for some reason
d557017
Messages In This Thread
Clutch for OM606 in -88 124 Mercedes - by d557017 - 07-23-2020, 01:31 PM
RE: Clutch for OM606 in -88 124 Mercedes - by d557017 - 07-25-2020, 09:12 AM
RE: Clutch for OM606 in -88 124 Mercedes - by d557017 - 08-30-2020, 03:10 AM
RE: Clutch for OM606 in -88 124 Mercedes - by d557017 - 10-13-2020, 06:20 AM
RE: Clutch for OM606 in -88 124 Mercedes - by JoeB - 10-13-2020, 09:02 PM
RE: Clutch for OM606 in -88 124 Mercedes - by d557017 - 10-14-2020, 02:04 AM
RE: Clutch for OM606 in -88 124 Mercedes - by Simon B - 10-18-2020, 06:55 AM
RE: Clutch for OM606 in -88 124 Mercedes - by d557017 - 10-18-2020, 08:34 AM
RE: Clutch for OM606 in -88 124 Mercedes - by Simon B - 10-18-2020, 11:40 AM
RE: Clutch for OM606 in -88 124 Mercedes - by Simon B - 10-18-2020, 11:49 AM
RE: Clutch for OM606 in -88 124 Mercedes - by d557017 - 10-18-2020, 12:51 PM
RE: Clutch for OM606 in -88 124 Mercedes - by Gasoil - 11-08-2020, 08:32 AM
RE: Clutch for OM606 in -88 124 Mercedes - by Gasoil - 11-08-2020, 07:53 AM
RE: Clutch for OM606 in -88 124 Mercedes - by Gasoil - 11-09-2020, 02:50 PM
RE: Clutch for OM606 in -88 124 Mercedes - by d557017 - 11-11-2020, 02:03 PM
RE: Clutch for OM606 in -88 124 Mercedes - by Gasoil - 11-12-2020, 08:56 AM
RE: Clutch for OM606 in -88 124 Mercedes - by d557017 - 11-14-2020, 02:43 AM
RE: Clutch for OM606 in -88 124 Mercedes - by d557017 - 11-29-2020, 10:42 AM
RE: Clutch for OM606 in -88 124 Mercedes - by Simon B - 11-29-2020, 03:23 PM
RE: Clutch for OM606 in -88 124 Mercedes - by d557017 - 12-01-2020, 11:32 AM
RE: Clutch for OM606 in -88 124 Mercedes - by Simon B - 12-01-2020, 04:23 PM
RE: Clutch for OM606 in -88 124 Mercedes - by Simon B - 12-01-2020, 04:31 PM
RE: Clutch for OM606 in -88 124 Mercedes - by d557017 - 12-06-2020, 11:35 AM
RE: Clutch for OM606 in -88 124 Mercedes - by Simon B - 12-07-2020, 04:50 PM
RE: Clutch for OM606 in -88 124 Mercedes - by d557017 - 12-08-2020, 12:23 AM
RE: Clutch for OM606 in -88 124 Mercedes - by Simon B - 12-08-2020, 01:41 PM
RE: Clutch for OM606 in -88 124 Mercedes - by d557017 - 12-19-2020, 02:20 PM
RE: Clutch for OM606 in -88 124 Mercedes - by Simon B - 12-20-2020, 10:49 AM
RE: Clutch for OM606 in -88 124 Mercedes - by Gasoil - 12-21-2020, 04:23 PM
RE: Clutch for OM606 in -88 124 Mercedes - by Simon B - 12-21-2020, 06:45 PM
RE: Clutch for OM606 in -88 124 Mercedes - by Gasoil - 12-25-2020, 10:12 AM
RE: Clutch for OM606 in -88 124 Mercedes - by Simon B - 12-25-2020, 03:15 PM
RE: Clutch for OM606 in -88 124 Mercedes - by d557017 - 12-24-2020, 03:29 AM
RE: Clutch for OM606 in -88 124 Mercedes - by Gasoil - 12-26-2020, 02:31 PM
RE: Clutch for OM606 in -88 124 Mercedes - by Simon B - 12-26-2020, 04:43 PM
RE: Clutch for OM606 in -88 124 Mercedes - by Gasoil - 12-28-2020, 09:05 AM
RE: Clutch for OM606 in -88 124 Mercedes - by d557017 - 01-03-2021, 03:52 AM
RE: Clutch for OM606 in -88 124 Mercedes - by Gasoil - 01-14-2021, 03:28 PM
RE: Clutch for OM606 in -88 124 Mercedes - by d557017 - 01-22-2021, 12:35 PM
RE: Clutch for OM606 in -88 124 Mercedes - by d557017 - 01-24-2021, 09:44 AM
RE: Clutch for OM606 in -88 124 Mercedes - by Simon B - 01-24-2021, 10:32 AM
