722.608 Police upgrade?
(05-31-2017, 12:29 PM)whipplem104 What are you putting it in. What car? If you are in a factory car you have to have the same gear ratios. So check to see if it is a large nag or small nag ratio set in EPC. If not then it does not matter much and throw it away and get a standard v8 transmission. Dodge or Mercedes and put a valve body in it and be done. No need to upgrade clutch packs at all. Swap the bellhousing if you need to for your application.How do i know if i have small nag or big? i have a 1998 E300 w210
We put over a 1000whp whtq through stock transmissions at over 6k lbs awd vehicles.
