W124 build
W124 build
I have troubles with this sight from home but not at work. Most of the time at home it will load once but I cannot post or get back in or see the pictures. Work always works and all the pictures load.
We are running twin wastegates with the D200 on this car. You could do a staged setup as well by using the other output.
Springs are from Ferrea. They are not the cheapest setup by far but we have all new retainers and keepers etc. We have not decided on the Cams yet. Going to start off with the stock turbo cams and then put in the N/A cams. and see what is next. Honestly I think that we are going to meet our goals with the stock cams. Just wanted room for more if necessary. Honestly with the low exh. back pressure I am not as concerned about the springs as I was at the beginning. We are running 10-11psi on the 7lbs springs and 20psi on the 15bls springs and 40 on the 27lb springs so we are running a very good pressure ratio. I do not think we will have to exceed 40 psi of boost but again we will see. I have to drop the volumetric efficiency down to around 65% to get the head flow down enough to need to go higher in the calculations but reality is reality.
Intercooler is working great. On the logs it pretty much runs static temperature of around 20F above ambient no matter how long we make a pull. Most boost we have run has been 25psi gauge so far. But we will see once the boost is turned up. You can look up the info on the core at Bell Intercoolers. It is one of their standard cores. It is 18x19x3.5.
We have not done anything for the cooling system. I have my own opinions about that and am not concerned about it with this build.
Hopefully if everything goes well we will know on Saturday.
