STD Other Projects W124 build
W124 build
W124 build
  • 3 Vote(s) - 5 Average
whipplem104
02-21-2016, 12:16 PM #43
We got some dry weather yesterday and I put some drag radials on to see what it will do. The boost feed to the alda kept coming loose. I had the wrong size hose on and could not get a clamp to fit. But got to play a little bit. Interestingly we can get 20 psi of boost with no alda. Fuel limited of course. With alda I was peddling to keep the boost low for now. The turbo really does not want to do anything below 3k. You can brake tq it to get it spooling below but it takes a few seconds. Above 3200 rpm it lights off pretty quickly. And will hit full boost in less than a few hundred rpm. So making full boost is going to be no problem. I am going to drop the wastegate springs down to get it in a safe boost level for now and start playing with fuel and timing and get the transmission tune redone for the extra power. Then to the dyno.
whipplem104
Messages In This Thread
W124 build - by whipplem104 - 04-30-2015, 06:38 PM
RE: W124 build - by raysorenson - 04-30-2015, 08:27 PM
RE: W124 build - by Repetitio - 05-01-2015, 02:19 AM
RE: W124 build - by whipplem104 - 05-01-2015, 10:35 AM
RE: W124 build - by whipplem104 - 05-04-2015, 06:03 PM
RE: W124 build - by whipplem104 - 05-06-2015, 08:10 PM
RE: W124 build - by maxypriest - 05-06-2015, 09:46 PM
RE: W124 build - by whipplem104 - 05-06-2015, 11:31 PM
RE: W124 build - by whipplem104 - 05-07-2015, 01:46 PM
RE: W124 build - by raysorenson - 05-07-2015, 08:16 PM
RE: W124 build - by whipplem104 - 05-08-2015, 02:02 PM
RE: W124 build - by whipplem104 - 05-25-2015, 11:00 PM
RE: W124 build - by Hario' - 05-26-2015, 07:33 AM
RE: W124 build - by whipplem104 - 06-19-2015, 06:33 PM
RE: W124 build - by Turbo - 06-22-2015, 01:13 AM
RE: W124 build - by whipplem104 - 06-30-2015, 06:43 PM
RE: W124 build - by whipplem104 - 07-01-2015, 08:09 AM
RE: W124 build - by Hario' - 07-01-2015, 11:41 AM
RE: W124 build - by whipplem104 - 07-02-2015, 07:25 PM
RE: W124 build - by whipplem104 - 07-02-2015, 07:38 PM
RE: W124 build - by raysorenson - 07-03-2015, 09:10 PM
RE: W124 build - by whipplem104 - 07-04-2015, 06:15 AM
RE: W124 build - by whipplem104 - 07-22-2015, 03:36 PM
RE: W124 build - by Booster - 07-23-2015, 01:50 AM
RE: W124 build - by whipplem104 - 07-23-2015, 06:32 PM
RE: W124 build - by whipplem104 - 07-28-2015, 02:52 PM
RE: W124 build - by Turbo - 08-11-2015, 02:35 PM
RE: W124 build - by whipplem104 - 08-11-2015, 05:31 PM
RE: W124 build - by whipplem104 - 08-27-2015, 12:43 PM
RE: W124 build - by whipplem104 - 10-03-2015, 02:02 PM
RE: W124 build - by whipplem104 - 10-04-2015, 06:08 PM
RE: W124 build - by whipplem104 - 10-05-2015, 09:22 PM
RE: W124 build - by erx - 10-15-2015, 10:42 AM
RE: W124 build - by whipplem104 - 10-16-2015, 11:52 AM
RE: W124 build - by whipplem104 - 12-11-2015, 07:59 PM
RE: W124 build - by whipplem104 - 02-04-2016, 05:12 PM
RE: W124 build - by atypicalguy - 02-12-2016, 07:11 PM
RE: W124 build - by whipplem104 - 02-15-2016, 11:42 AM
RE: W124 build - by whipplem104 - 02-19-2016, 11:50 AM
RE: W124 build - by Sultzi - 02-19-2016, 02:04 PM
RE: W124 build - by whipplem104 - 02-19-2016, 04:17 PM
RE: W124 build - by whipplem104 - 02-19-2016, 07:44 PM
RE: W124 build - by whipplem104 - 02-21-2016, 12:16 PM
RE: W124 build - by whipplem104 - 02-23-2016, 02:58 PM
RE: W124 build - by whipplem104 - 03-03-2016, 05:12 PM
RE: W124 build - by whipplem104 - 03-11-2016, 02:07 PM
RE: W124 build - by whipplem104 - 03-18-2016, 11:25 AM
RE: W124 build - by atypicalguy - 03-22-2016, 04:44 AM
RE: W124 build - by whipplem104 - 03-22-2016, 11:16 AM
RE: W124 build - by atypicalguy - 03-24-2016, 05:30 AM
RE: W124 build - by whipplem104 - 03-24-2016, 10:24 AM
RE: W124 build - by whipplem104 - 03-24-2016, 02:36 PM
RE: W124 build - by SurfRodder - 03-24-2016, 03:21 PM
RE: W124 build - by whipplem104 - 03-24-2016, 03:58 PM
RE: W124 build - by atypicalguy - 03-24-2016, 11:22 PM
RE: W124 build - by whipplem104 - 03-25-2016, 08:12 AM
RE: W124 build - by atypicalguy - 03-25-2016, 03:47 PM
RE: W124 build - by whipplem104 - 03-25-2016, 04:10 PM
RE: W124 build - by atypicalguy - 03-25-2016, 04:27 PM
RE: W124 build - by whipplem104 - 04-10-2016, 12:54 PM
RE: W124 build - by erx - 04-11-2016, 01:47 AM
RE: W124 build - by whipplem104 - 04-11-2016, 07:57 AM
RE: W124 build - by erx - 04-11-2016, 09:12 AM
RE: W124 build - by whipplem104 - 04-11-2016, 12:45 PM
RE: W124 build - by erx - 04-11-2016, 01:19 PM
RE: W124 build - by whipplem104 - 04-11-2016, 01:35 PM
RE: W124 build - by Sultzi - 04-12-2016, 03:28 AM
RE: W124 build - by whipplem104 - 05-27-2016, 08:29 AM
RE: W124 build - by erx - 06-14-2016, 02:19 PM
RE: W124 build - by whipplem104 - 06-14-2016, 03:17 PM
RE: W124 build - by whipplem104 - 07-06-2016, 03:47 PM
RE: W124 build - by whipplem104 - 11-13-2016, 10:55 AM
RE: W124 build - by atypicalguy - 11-13-2016, 01:30 PM
RE: W124 build - by whipplem104 - 11-13-2016, 02:24 PM
RE: W124 build - by erx - 11-13-2016, 03:26 PM
RE: W124 build - by whipplem104 - 11-15-2016, 02:14 PM
RE: W124 build - by erx - 11-15-2016, 02:51 PM
RE: W124 build - by whipplem104 - 11-15-2016, 04:50 PM
RE: W124 build - by erx - 11-15-2016, 05:31 PM
RE: W124 build - by R-3350 - 11-15-2016, 07:58 PM
RE: W124 build - by atypicalguy - 11-15-2016, 10:33 PM
RE: W124 build - by whipplem104 - 11-16-2016, 04:56 PM
RE: W124 build - by erx - 11-17-2016, 04:11 AM
RE: W124 build - by atypicalguy - 11-17-2016, 08:53 PM
RE: W124 build - by atypicalguy - 11-17-2016, 09:03 PM
RE: W124 build - by Mr_Robs - 12-25-2016, 08:01 PM
RE: W124 build - by whipplem104 - 12-26-2016, 12:38 PM
RE: W124 build - by atypicalguy - 03-24-2017, 03:29 AM
RE: W124 build - by whipplem104 - 03-24-2017, 08:13 AM
RE: W124 build - by atypicalguy - 03-24-2017, 09:51 AM
RE: W124 build - by whipplem104 - 03-24-2017, 07:12 PM
RE: W124 build - by whipplem104 - 04-28-2017, 08:01 AM
RE: W124 build - by Turbo - 04-29-2017, 01:04 AM
RE: W124 build - by whipplem104 - 04-30-2017, 01:44 PM
RE: W124 build - by whipplem104 - 09-24-2017, 12:52 PM
RE: W124 build - by maxypriest - 09-25-2017, 09:00 AM
RE: W124 build - by whipplem104 - 09-25-2017, 12:09 PM
RE: W124 build - by atypicalguy - 11-20-2017, 10:14 PM
RE: W124 build - by whipplem104 - 11-20-2017, 11:31 PM
RE: W124 build - by whipplem104 - 04-24-2018, 01:21 PM
RE: W124 build - by atypicalguy - 05-15-2018, 01:23 AM
RE: W124 build - by MFSuper90 - 04-24-2018, 06:53 PM
RE: W124 build - by atypicalguy - 10-07-2018, 09:27 PM
RE: W124 build - by whipplem104 - 10-09-2018, 10:24 PM
