STD Tuning Engine Garrett 712120 VNT Hella 6NW 008 412 actuator.
  • 2 Vote(s) - 5 Average
300SD81
11-14-2009, 05:00 AM #55
V2 of the controller is complete, and COMPUTER CONTROL IS WORKING Big Grin I can move the actuator to any position using 3-5 byte UDP packets sent over the network. Now if I ever get a turbo installed into the car, I can control it with any computer with a network port Smile
Been working on it a little more, 256 step PWM resolution is about the best for the actuator, since it moves a little about every step or 2. The full open state should not be set to 0% duty cycle, since there is a delay between it starting to get a signal and actually moving. PWM duty cycle should not be changed instantly, but sweeped to avoid a delay between the change and it moving. Optimal positions for 256 step PWM with 0x00 as 0% and 0xFF as 100% are 0x26 for full open and 0xF3 for full close.
This post was last modified: 11-16-2009, 01:17 AM by 300SD81.
Ich liebe meine Autos!
300SD81
Messages In This Thread
Garrett 712120 VNT Hella 6NW 008 412 actuator. - by tomnik - 08-18-2009, 09:13 AM
RE: electronic actuator? - by Tymbrymi - 08-25-2009, 01:15 PM
RE: electronic actuator? - by tomnik - 08-27-2009, 07:15 AM
RE: electronic actuator? - by winmutt - 09-01-2009, 09:01 AM
RE: electronic actuator? - by Tymbrymi - 09-01-2009, 09:28 AM
RE: electronic actuator? - by winmutt - 09-01-2009, 03:51 PM
RE: electronic actuator? - by tomnik - 09-01-2009, 09:49 AM
RE: electronic actuator? - by Tymbrymi - 09-03-2009, 08:31 AM
RE: electronic actuator? - by winmutt - 09-03-2009, 01:18 PM
RE: electronic actuator? - by Tymbrymi - 09-03-2009, 01:32 PM
RE: electronic actuator? - by winmutt - 09-03-2009, 02:23 PM
RE: Garrett VNT Hella actuator. - by winmutt - 09-04-2009, 08:21 AM
RE: Garrett VNT Hella actuator. - by Tymbrymi - 09-04-2009, 11:30 AM
RE: Garrett VNT Hella actuator. - by winmutt - 09-04-2009, 03:17 PM
RE: Garrett VNT Hella actuator. - by winmutt - 09-04-2009, 12:29 PM
RE: Garrett VNT Hella actuator. - by Tymbrymi - 09-04-2009, 01:36 PM
RE: Garrett VNT Hella actuator. - by winmutt - 09-05-2009, 10:26 AM
RE: Garrett VNT Hella actuator. - by Tymbrymi - 09-05-2009, 10:14 PM
RE: Garrett VNT Hella actuator. - by winmutt - 10-22-2009, 11:22 PM
RE: Garrett VNT Hella actuator. - by Tymbrymi - 10-23-2009, 09:55 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 09-05-2009, 10:49 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 09-08-2009, 10:12 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 09-08-2009, 02:21 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Tymbrymi - 09-09-2009, 08:38 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 09-09-2009, 10:28 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 09-10-2009, 08:02 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by ForcedInduction - 09-14-2009, 04:09 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 10-19-2009, 02:29 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 10-20-2009, 10:51 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 10-23-2009, 01:41 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Tymbrymi - 10-23-2009, 03:51 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 10-27-2009, 08:42 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Tymbrymi - 10-28-2009, 09:48 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 10-28-2009, 10:34 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 10-27-2009, 11:36 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 10-29-2009, 12:21 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Tymbrymi - 10-29-2009, 02:12 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 10-29-2009, 05:01 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 10-29-2009, 12:38 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 10-29-2009, 02:06 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by piledriver - 10-29-2009, 08:07 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Tymbrymi - 10-29-2009, 09:29 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 10-30-2009, 08:25 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 11-02-2009, 11:25 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 11-03-2009, 03:48 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 11-03-2009, 04:01 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Tymbrymi - 11-05-2009, 10:32 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 11-04-2009, 04:53 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 11-04-2009, 09:36 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 11-05-2009, 12:26 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 11-05-2009, 01:38 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 11-06-2009, 04:22 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by muuris - 01-12-2010, 10:58 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 01-12-2010, 04:07 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by muuris - 01-13-2010, 05:39 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 11-08-2009, 03:40 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 11-09-2009, 02:40 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 11-14-2009, 05:00 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by cell - 11-19-2009, 03:35 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 11-21-2009, 03:32 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by ForcedInduction - 11-21-2009, 05:01 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by nockter - 12-05-2009, 01:40 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 12-07-2009, 02:08 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by lars - 12-08-2009, 05:25 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 12-08-2009, 11:21 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 12-08-2009, 07:19 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 12-14-2009, 03:28 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 01-12-2010, 04:45 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by kmaser - 01-12-2010, 05:52 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by cell - 01-23-2010, 08:09 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Kiwibacon - 01-23-2010, 08:23 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by cell - 01-23-2010, 08:25 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 01-26-2010, 04:02 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by ForcedInduction - 02-07-2010, 07:25 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 02-08-2010, 10:41 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by ForcedInduction - 02-11-2010, 02:13 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 02-18-2010, 10:36 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by cell - 02-19-2010, 01:30 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 03-30-2010, 01:19 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by racerxoffl - 10-19-2010, 11:39 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by TB206HDI - 09-23-2010, 02:56 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by dgn555 - 09-23-2010, 02:24 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 09-23-2010, 03:05 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by dgn555 - 10-03-2010, 06:53 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Darqs - 12-01-2010, 03:46 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 12-01-2010, 10:39 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Darqs - 12-02-2010, 02:58 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Tymbrymi - 12-02-2010, 07:48 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Darqs - 12-02-2010, 09:07 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 12-02-2010, 10:03 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Tymbrymi - 12-02-2010, 12:31 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Darqs - 12-08-2010, 06:31 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Biohazard - 12-01-2010, 10:53 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Biohazard - 12-06-2010, 01:32 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Captain America - 12-07-2010, 04:07 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 12-08-2010, 10:25 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Darqs - 12-09-2010, 02:24 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 12-09-2010, 11:32 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Darqs - 12-15-2010, 03:22 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 12-15-2010, 09:14 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Darqs - 12-17-2010, 03:49 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Pali - 04-15-2011, 07:20 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by tomnik - 04-15-2011, 08:03 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Pali - 04-16-2011, 02:44 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Darqs - 04-21-2011, 03:38 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300D50 - 12-15-2010, 09:10 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Biohazard - 12-16-2010, 11:49 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300D50 - 12-16-2010, 11:55 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Biohazard - 12-16-2010, 03:43 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300D50 - 12-16-2010, 06:50 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Biohazard - 12-16-2010, 08:35 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300D50 - 12-17-2010, 11:03 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Biohazard - 12-17-2010, 11:09 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Biohazard - 12-20-2010, 10:21 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Biohazard - 01-16-2011, 10:42 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Darqs - 01-18-2011, 02:37 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Biohazard - 01-18-2011, 09:52 AM
It's the "post your actuator guts" thread now - by aaa - 04-15-2011, 02:41 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by tomnik - 04-17-2011, 11:25 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Pali - 04-18-2011, 01:30 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by tomnik - 04-18-2011, 02:25 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Pali - 04-18-2011, 02:59 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 04-18-2011, 11:47 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 04-18-2011, 09:29 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Pali - 04-19-2011, 02:33 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 04-19-2011, 09:16 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Pali - 04-20-2011, 08:39 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 04-20-2011, 08:48 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Pali - 04-21-2011, 03:01 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Darqs - 07-01-2011, 04:07 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 07-01-2011, 03:57 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Darqs - 07-05-2011, 02:21 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by janus - 01-25-2012, 02:45 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Darqs - 02-20-2012, 04:20 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by janus - 01-29-2012, 11:16 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Rub87 - 01-29-2012, 02:47 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by majesty78 - 01-30-2012, 04:21 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Rub87 - 01-30-2012, 05:03 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by janus - 01-30-2012, 01:45 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by janus - 02-20-2012, 11:13 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Darqs - 02-22-2012, 05:42 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by janus - 07-17-2012, 07:03 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Darqs - 09-25-2012, 03:46 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by janus - 07-18-2012, 05:25 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by raysorenson - 07-18-2012, 10:56 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by janus - 10-09-2013, 08:58 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by pemtek - 11-04-2013, 06:22 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by janus - 11-05-2013, 01:47 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by pemtek - 11-05-2013, 03:49 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Iangiulu - 07-10-2014, 02:06 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Iangiulu - 07-12-2014, 02:42 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Darqs - 12-18-2014, 03:06 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by antonmies - 01-23-2015, 06:43 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by HoleshotHolset - 04-15-2015, 10:37 AM
 12 Guest(s)
 12 Guest(s)
