STD Other Projects Om605 compound turbo build, my Corolla Ke70 tracktoy
  • 2 Vote(s) - 5 Average
Stamsaas
05-30-2015, 01:39 PM #291
Thanks guys! Big Grin Time to give you the rest of the story here now Smile
Starting the day before, picked up the trailer at a frind after work and drove to the garage. Checked all that i could think of, and all clamps and stuff. Never been at a dyno before.. Anyways, got the car on the trailer, and drove to the truckfuel pump Smile (called tax-free diesel here in Norway)
[Image: 20150512_231330_zpsbkzker8w.jpg]
Drove to the dynoguy (Jonus Racing) and got the car in the dyno. Can see that it marked its Territory again :p sometimes it just came a log of thick smoke :p
[Image: 20150513_130349_zpsmv4vzvo0.jpg]
And out in the free again, still alive!
[Image: 20150513_132809_zpshfwhwhji.jpg]
And the final was 398,5whp og 550wnm! Big Grin
First pull was just a test of how it was when I came, and it pushed 367whp and 580wnm at 2,6 bar, but at 7bar (!) backpressure... startet going over thing, and found a series of small preassure leaks in the wastegate controll. Some bad clamps, and even a melted push-fitting. Fixed alot here, and got the wastegate on a separate pressure circuit etc. This together drasticly lowered the backpressure, and lowered boostpressure and the NM. But we gained 13whp! Now we started to play with the turbos, but when we tried to give it more boost and get the turbos to play together the backpressure just took of again...  Therefore we adjusteted the other way, and this worked quite well. pulls starts at hold on 2000rpm, and it hold about 0,4bar boost there. At 3000rpm the Hx30 gives 1bar boost, and here the bigboy Hx40 wakes up and take over the show. From here the HX40 does all the job, and the Hx30 actully is just a brake in the system. Finish pressure is 2,3bar boost. With all the "problems" I am very satisfied with the Power Big Grin
Here is a bad Picture of a even bader print of the curves
[Image: 20150514_000440_zpsj5hxrmqp.jpg]
Why the turbosetup dont worked as it should nobody really know, but it may all be because of my manyfolds that is very very comprimised because of the tight space... Anyways the car loose grip on the rear wheels of only pushing the peadal firm to the floor at 3.gear. It has enough Power :p
[Image: IMG_1839p_zpspdqerlqh.jpg]
Stamsaas
Messages In This Thread
Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 03-03-2013, 04:11 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by mantahead - 03-03-2013, 05:07 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by George3soccer - 03-03-2013, 07:21 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by willbhere4u - 03-03-2013, 08:51 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Simpler=Better - 03-03-2013, 10:05 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 03-04-2013, 02:56 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by maxypriest - 03-04-2013, 07:59 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 03-04-2013, 01:24 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Simpler=Better - 03-04-2013, 02:32 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by HaavardPYA - 03-04-2013, 04:24 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 03-05-2013, 03:21 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by HaavardPYA - 03-05-2013, 10:32 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by EDH_Performance - 03-05-2013, 05:14 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 03-06-2013, 03:34 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by willbhere4u - 03-05-2013, 12:29 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 03-06-2013, 08:00 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by jeemu - 03-11-2013, 04:00 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 03-11-2013, 04:11 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Simpler=Better - 03-11-2013, 04:53 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by erling66 - 03-16-2013, 12:07 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 03-16-2013, 08:46 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 03-19-2013, 05:51 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by HaavardPYA - 03-19-2013, 10:54 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 03-19-2013, 12:28 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 03-20-2013, 07:52 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 03-20-2013, 11:06 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 03-25-2013, 04:46 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by MFSuper90 - 03-25-2013, 09:21 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 03-26-2013, 03:20 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by HaavardPYA - 03-26-2013, 03:44 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 03-30-2013, 11:33 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 03-31-2013, 07:10 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Simpler=Better - 03-31-2013, 08:46 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by raysorenson - 03-31-2013, 09:50 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 04-02-2013, 03:13 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 04-05-2013, 03:44 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 04-09-2013, 03:28 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by hansebanger77 - 04-10-2013, 01:31 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 04-10-2013, 02:23 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 04-10-2013, 02:58 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 04-28-2013, 04:43 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 04-29-2013, 02:37 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 04-29-2013, 03:34 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 04-29-2013, 05:20 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 05-02-2013, 02:14 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 05-03-2013, 02:24 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by majesty78 - 05-06-2013, 01:38 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 05-06-2013, 02:32 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Simpler=Better - 05-06-2013, 04:07 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 05-07-2013, 02:14 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 05-07-2013, 04:26 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 05-08-2013, 03:54 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 05-09-2013, 06:03 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Simpler=Better - 05-10-2013, 08:32 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by maxypriest - 05-10-2013, 09:37 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 05-11-2013, 03:40 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 05-10-2013, 03:24 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by hansebanger77 - 05-10-2013, 08:59 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by hansebanger77 - 05-11-2013, 04:09 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 05-12-2013, 03:28 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Simpler=Better - 05-13-2013, 08:15 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 05-13-2013, 02:43 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Njdub - 05-13-2013, 08:16 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 05-19-2013, 06:55 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by maxypriest - 05-20-2013, 11:12 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 05-20-2013, 02:47 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 05-30-2013, 01:40 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 06-09-2013, 04:04 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by lgreeley83 - 06-09-2013, 10:31 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 06-11-2013, 03:34 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by HaavardPYA - 06-11-2013, 03:55 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by larsalan - 06-11-2013, 06:23 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 06-12-2013, 01:21 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by DiseaselWeasel - 06-12-2013, 01:39 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-02-2013, 06:48 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by lgreeley83 - 07-02-2013, 07:44 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 07-03-2013, 03:09 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by mantahead - 07-03-2013, 04:14 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by bruno_pinho - 07-03-2013, 07:26 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Simpler=Better - 07-03-2013, 07:51 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-03-2013, 06:47 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-04-2013, 06:19 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by winmutt - 07-05-2013, 08:56 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by HaavardPYA - 07-05-2013, 09:38 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by mantahead - 07-05-2013, 06:00 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-05-2013, 08:28 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-09-2013, 09:52 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Simpler=Better - 07-09-2013, 03:33 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by HaavardPYA - 07-10-2013, 11:16 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 07-11-2013, 02:36 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-11-2013, 04:16 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 07-12-2013, 03:08 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-12-2013, 02:32 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by JB3 - 07-14-2013, 03:51 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-17-2013, 10:22 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Simpler=Better - 07-17-2013, 11:30 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by StrikerofDeath - 07-25-2013, 08:22 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by winmutt - 07-18-2013, 08:26 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-18-2013, 02:18 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by willbhere4u - 07-25-2013, 11:37 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Simpler=Better - 07-25-2013, 12:45 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-31-2013, 08:43 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Simpler=Better - 07-31-2013, 09:52 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by lgreeley83 - 07-31-2013, 10:43 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 08-09-2013, 04:46 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by HaavardPYA - 08-09-2013, 06:35 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 08-09-2013, 06:50 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by HaavardPYA - 08-10-2013, 03:40 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 08-17-2013, 04:12 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Simpler=Better - 08-17-2013, 11:12 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 08-19-2013, 01:54 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by MFSuper90 - 08-19-2013, 07:55 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 08-19-2013, 09:21 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 08-20-2013, 03:21 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 09-02-2013, 03:09 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by winmutt - 09-02-2013, 06:54 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by EDH_Performance - 09-02-2013, 08:45 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 09-03-2013, 02:13 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 09-03-2013, 10:19 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 09-04-2013, 03:08 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 09-08-2013, 04:53 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 09-09-2013, 02:57 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 09-13-2013, 11:30 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 09-16-2013, 02:23 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 09-16-2013, 04:36 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 09-17-2013, 03:24 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 09-17-2013, 04:03 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 09-17-2013, 07:27 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 10-24-2013, 03:28 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 10-30-2013, 03:29 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 10-30-2013, 02:48 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by S.Engen - 11-26-2013, 01:14 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by mantahead - 10-30-2013, 04:27 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 10-31-2013, 03:25 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by willbhere4u - 10-31-2013, 10:16 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by bonden_85 - 11-03-2013, 09:16 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 11-24-2013, 03:08 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 11-29-2013, 04:46 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 12-06-2013, 10:28 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Tito - 12-06-2013, 12:28 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 12-07-2013, 02:53 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by erling66 - 12-08-2013, 03:00 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by uli124125 - 12-08-2013, 04:50 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 12-08-2013, 06:19 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by erling66 - 12-08-2013, 07:25 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 12-08-2013, 12:59 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by uli124125 - 12-08-2013, 11:29 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by erling66 - 12-09-2013, 02:56 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 12-09-2013, 04:13 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 12-09-2013, 03:21 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 12-11-2013, 09:44 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 12-11-2013, 02:58 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 12-12-2013, 03:21 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Alcaid - 12-29-2013, 03:24 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by john - 12-29-2013, 04:24 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Alcaid - 12-29-2013, 04:34 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by john - 12-29-2013, 05:06 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 12-29-2013, 05:51 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 12-12-2013, 03:12 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 12-16-2013, 02:08 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by erling66 - 12-20-2013, 03:12 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 12-18-2013, 04:05 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by EDH_Performance - 12-19-2013, 11:34 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 12-19-2013, 04:07 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by EDH_Performance - 12-29-2013, 06:07 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by erling66 - 12-30-2013, 03:52 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Duncansport - 12-30-2013, 12:11 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 12-30-2013, 02:03 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by erling66 - 12-31-2013, 03:59 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Duncansport - 12-31-2013, 10:11 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by erling66 - 12-31-2013, 10:34 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Duncansport - 12-31-2013, 01:03 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 01-03-2014, 11:14 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 02-02-2014, 12:10 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Simpler=Better - 02-03-2014, 09:07 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by S.Engen - 02-03-2014, 12:30 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by EDH_Performance - 02-04-2014, 03:04 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by willbhere4u - 02-03-2014, 04:39 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 02-08-2014, 03:37 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 02-11-2014, 03:07 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Simpler=Better - 02-11-2014, 04:47 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 02-13-2014, 02:13 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by mantahead - 02-13-2014, 05:59 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 02-16-2014, 02:37 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 02-16-2014, 05:25 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by erling66 - 02-17-2014, 04:33 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 02-18-2014, 02:01 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by EDH_Performance - 02-18-2014, 10:37 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 02-18-2014, 11:42 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 02-21-2014, 06:55 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 02-23-2014, 07:24 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by bigbortha - 02-23-2014, 11:36 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by F.R.A.S - 02-24-2014, 07:08 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Simpler=Better - 02-25-2014, 10:35 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by lgreeley83 - 02-25-2014, 10:56 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 02-25-2014, 03:00 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by willbhere4u - 02-26-2014, 01:06 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 02-26-2014, 03:15 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by willbhere4u - 02-26-2014, 05:56 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 02-28-2014, 09:58 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 03-01-2014, 05:26 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by EDH_Performance - 03-02-2014, 01:48 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by F.R.A.S - 03-02-2014, 12:59 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by EDH_Performance - 03-02-2014, 04:56 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 03-04-2014, 10:26 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by sorin_cel - 04-05-2014, 12:05 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 04-20-2014, 12:57 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by F.R.A.S - 04-21-2014, 03:10 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by giuliettaevo - 04-23-2014, 03:35 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by hansebanger77 - 04-25-2014, 05:11 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 06-29-2014, 05:34 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Turbo - 06-29-2014, 07:50 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by giuliettaevo - 04-26-2014, 02:51 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by F.R.A.S - 06-22-2014, 03:25 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Simpler=Better - 06-23-2014, 08:28 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 06-25-2014, 03:12 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-01-2014, 02:47 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Tito - 07-01-2014, 03:06 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-03-2014, 03:15 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by F.R.A.S - 07-04-2014, 05:09 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by rafael cotrim - 07-04-2014, 05:45 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-05-2014, 12:05 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by StrikerofDeath - 07-05-2014, 06:28 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-06-2014, 06:52 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by StrikerofDeath - 07-07-2014, 06:45 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-07-2014, 05:28 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Sotvisp - 07-08-2014, 02:38 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-08-2014, 02:39 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Simpler=Better - 07-08-2014, 09:30 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-09-2014, 08:11 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by MFSuper90 - 07-09-2014, 08:19 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-09-2014, 08:01 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by MFSuper90 - 07-10-2014, 01:47 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by raysorenson - 07-10-2014, 11:28 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by winmutt - 07-10-2014, 01:59 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-13-2014, 11:39 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Petar - 07-13-2014, 02:17 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-13-2014, 02:52 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by MFSuper90 - 07-13-2014, 08:09 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-14-2014, 03:34 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by F.R.A.S - 07-16-2014, 04:56 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Gasoil - 07-19-2014, 06:06 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-25-2014, 04:16 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by F.R.A.S - 07-28-2014, 03:54 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Gasoil - 07-28-2014, 01:22 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 08-11-2014, 05:56 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by F.R.A.S - 08-15-2014, 02:33 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 08-29-2014, 05:19 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Turbo - 08-30-2014, 12:54 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 08-30-2014, 02:56 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by StrikerofDeath - 10-13-2014, 04:18 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 11-07-2014, 07:26 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by raysorenson - 11-07-2014, 08:06 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 11-07-2014, 08:21 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Gasoil - 11-10-2014, 04:14 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 11-20-2014, 05:54 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by StrikerofDeath - 11-23-2014, 04:31 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by hents99 - 11-24-2014, 10:17 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 01-10-2015, 06:28 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 01-11-2015, 04:14 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by rolfts - 01-12-2015, 02:19 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by F.R.A.S - 01-12-2015, 06:19 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Ksteen2 - 01-14-2015, 05:07 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 01-15-2015, 04:10 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 01-18-2015, 04:12 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by seanyt - 01-26-2015, 11:43 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by maxypriest - 01-26-2015, 07:35 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 01-27-2015, 04:14 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Ksteen2 - 01-28-2015, 01:35 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Max - 01-28-2015, 04:35 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 02-10-2015, 03:01 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by mantahead - 02-10-2015, 03:58 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Ksteen2 - 02-10-2015, 06:42 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Tito - 02-13-2015, 01:04 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 02-14-2015, 07:40 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 02-28-2015, 07:20 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Mr_Robs - 02-28-2015, 09:29 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 04-15-2015, 02:58 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Turbo - 04-16-2015, 11:23 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 04-22-2015, 04:46 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 05-04-2015, 03:05 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 05-06-2015, 02:35 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Turbo - 05-06-2015, 02:53 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 05-10-2015, 02:40 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by svenr - 05-10-2015, 03:09 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 05-14-2015, 02:06 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by DiseaselWeasel - 05-14-2015, 03:23 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 05-14-2015, 04:09 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by DiseaselWeasel - 05-14-2015, 09:37 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Booster - 05-14-2015, 12:37 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 05-30-2015, 01:39 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Turbo - 05-30-2015, 02:08 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 05-30-2015, 02:34 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Turbo - 05-30-2015, 03:03 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 05-31-2015, 03:13 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by raysorenson - 05-31-2015, 08:45 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Turbo - 06-01-2015, 01:37 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Alcaid - 06-04-2015, 06:39 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Alcaid - 06-04-2015, 06:47 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Turbo - 06-04-2015, 02:12 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Turbo - 06-04-2015, 02:14 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Alcaid - 06-04-2015, 03:06 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Turbo - 06-04-2015, 05:31 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Alcaid - 06-05-2015, 02:31 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Duncansport - 06-05-2015, 06:02 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Alcaid - 06-05-2015, 06:29 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Turbo - 06-05-2015, 08:07 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by atypicalguy - 06-08-2015, 02:50 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Alcaid - 06-09-2015, 05:29 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by atypicalguy - 06-09-2015, 07:02 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 06-26-2015, 08:49 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Keino - 06-26-2015, 10:36 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by atypicalguy - 06-27-2015, 10:06 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 07-03-2015, 04:56 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by raysorenson - 07-03-2015, 09:07 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by MFSuper90 - 07-04-2015, 10:57 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 07-13-2015, 01:13 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 08-24-2015, 09:53 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by StrikerofDeath - 08-27-2015, 07:50 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 08-31-2015, 02:11 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Keino - 08-31-2015, 02:50 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 09-08-2015, 04:03 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by atypicalguy - 09-08-2015, 06:29 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by MFSuper90 - 09-09-2015, 09:40 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 09-23-2015, 01:51 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by CRD4x4 - 09-23-2015, 04:11 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by MFSuper90 - 09-23-2015, 07:50 PM
 7 Guest(s)
 7 Guest(s)
