(10-22-2009, 11:22 PM)winmutt Is that 10v at 100% duty cycle?
10V is as high as that particular function generator goes to. If you view the high quality version you should be able to see the duty cycle ranges I used. Keep in mind that there are two different PWM things going on. When it is automatically moving the PWM frequency is the frequency at which the actuator is sweeping (ie, 2Hz made the actuator go 0-100-0-100 twice in a second).
If you watch the duty cycle and listen to actuator movement you should see that it starts moving from position vanes full open at 14% (0-14% duty cycle is open vanes), and reaches vanes fully closed at 94% duty cycle. At 98% duty cycle and above the actuator assumes the signal has been shorted to 12V and goes to the vanes open position.
Did that help any?
John Robbins
'05 E320 CDI - 118k -
Faaaaaast!!
'87 300TD - 317k - Cracked head... but an
OM606 is on the way!
