STD Tuning Drivetrain OM60x to GM Manual Trans adapter?
09-24-2014, 10:10 AM #28
FYI the one-piece rear many chevy 5.7L flywheels can be easily redrilled for a 617 pattern-I'm assuming the 603 would be similar(I can measure tonight if I remember). 14" flywheel with the trucks (needs big bellhousing) or 12.75" flywheel with the cars (camaro, firebird, etc.) can use the smaller bell.-also a 16lb car flywheel floating around.
The dimensions for a 60X bell bolt pattern are in the sticky, as are the GM. Pretty easy to draw it up, then fit a starter.
Messages In This Thread
OM60x to GM Manual Trans adapter? - by Jetmugg - 09-16-2013, 09:39 AM
RE: OM60x to GM Manual Trans adapter? - by waz - 09-16-2013, 09:53 AM
RE: OM60x to GM Manual Trans adapter? - by Jetmugg - 09-16-2013, 09:59 AM
RE: OM60x to GM Manual Trans adapter? - by Jetmugg - 09-16-2013, 02:58 PM
RE: OM60x to GM Manual Trans adapter? - by waz - 09-17-2013, 09:46 AM
RE: OM60x to GM Manual Trans adapter? - by Jetmugg - 09-17-2013, 10:20 AM
RE: OM60x to GM Manual Trans adapter? - by Mark_M - 09-18-2013, 04:14 AM
RE: OM60x to GM Manual Trans adapter? - by Jetmugg - 09-18-2013, 10:04 AM
RE: OM60x to GM Manual Trans adapter? - by tjts1 - 09-18-2013, 11:19 AM
RE: OM60x to GM Manual Trans adapter? - by Jetmugg - 09-18-2013, 11:51 AM
RE: OM60x to GM Manual Trans adapter? - by tjts1 - 09-18-2013, 12:28 PM
RE: OM60x to GM Manual Trans adapter? - by Jetmugg - 09-18-2013, 03:26 PM
RE: OM60x to GM Manual Trans adapter? - by zeeman - 09-18-2013, 05:14 PM
RE: OM60x to GM Manual Trans adapter? - by Mark_M - 09-18-2013, 05:15 PM
RE: OM60x to GM Manual Trans adapter? - by Jetmugg - 09-18-2013, 05:51 PM
RE: OM60x to GM Manual Trans adapter? - by zeeman - 09-18-2013, 07:26 PM
RE: OM60x to GM Manual Trans adapter? - by Mark_M - 09-18-2013, 06:17 PM
RE: OM60x to GM Manual Trans adapter? - by Jetmugg - 09-19-2013, 11:20 AM
RE: OM60x to GM Manual Trans adapter? - by zeeman - 09-19-2013, 01:24 PM
RE: OM60x to GM Manual Trans adapter? - by Jetmugg - 09-19-2013, 03:01 PM
RE: OM60x to GM Manual Trans adapter? - by zeeman - 09-19-2013, 03:48 PM
RE: OM60x to GM Manual Trans adapter? - by Jetmugg - 09-20-2013, 01:42 PM
RE: OM60x to GM Manual Trans adapter? - by zeeman - 09-20-2013, 03:30 PM
RE: OM60x to GM Manual Trans adapter? - by Jetmugg - 09-20-2013, 07:28 PM
RE: OM60x to GM Manual Trans adapter? - by zeeman - 09-20-2013, 09:39 PM
RE: OM60x to GM Manual Trans adapter? - by Jetmugg - 09-22-2013, 07:57 PM
RE: OM60x to GM Manual Trans adapter? - by zeeman - 09-22-2013, 09:45 PM
RE: OM60x to GM Manual Trans adapter? - by Simpler=Better - 09-24-2014, 10:10 AM
