(09-23-2014, 06:35 AM)lgreeley83 Any details on how you plumbed the holset? Got an hx30 I'm getting ready to put in mine. I've got an extra oil supply line. I figure I can have it chopped up and get oil feed right. What did you do for return?
For the feed I looked online for the proper oil restrictor, IIRC it's a Volvo part, that screws into the turbo with a -4AN to connect to. I took the banjo bolt with me to a hydraulic store and matched up the threads, they made me a 3ft braided steel line, with proper connectors/swivels for $40.
The drain I cut the "bell" end of the stock drain off, and cut the flared end of the tube off that sticks up from the oil pan. Then just used a hose to connect the two pipes. Best way I've found without getting fancy.
7.5mm M-pump, GT3582 turbo, F-Tune Performance intake/exhaust manifolds, A/A intercooler, 315 nozzles, Enlarged prechambers, Bosch 044 feed pump, Custom lightweight flywheel with 240mm clutch, Lowered, 17" AMG rims - 300 hp OM617 project
1985 300D 280,000 miles RIP
