STD Other Projects Om605 compound turbo build, my Corolla Ke70 tracktoy
  • 2 Vote(s) - 5 Average
Gasoil
07-19-2014, 06:06 AM #242
Hi Stamsaas, you use valve cap lash from KM to give again the same measure between hydraulic follower and new regrinded cams? The hydraulic follower not lift at the new cam regrinded lobe when engine is started by oil pressure? For example in gas engines with hydraulic followers you can fit racing cams with more lift, and no valve cap lashs are used.
I checked the N/A OM606 intake cam and has 1,3mm more lift than OM turbo one, fitted to the engine and all OK (bad luck a small plastic piece from fuel tubes fittings went into an intake valve of cyl 5 , started without manifold, and a intake valve was bent).
Gasoil
Messages In This Thread
Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 03-03-2013, 04:11 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by mantahead - 03-03-2013, 05:07 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by George3soccer - 03-03-2013, 07:21 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by willbhere4u - 03-03-2013, 08:51 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Simpler=Better - 03-03-2013, 10:05 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 03-04-2013, 02:56 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by maxypriest - 03-04-2013, 07:59 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 03-04-2013, 01:24 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Simpler=Better - 03-04-2013, 02:32 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by HaavardPYA - 03-04-2013, 04:24 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 03-05-2013, 03:21 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by HaavardPYA - 03-05-2013, 10:32 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by EDH_Performance - 03-05-2013, 05:14 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 03-06-2013, 03:34 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by willbhere4u - 03-05-2013, 12:29 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 03-06-2013, 08:00 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by jeemu - 03-11-2013, 04:00 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 03-11-2013, 04:11 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Simpler=Better - 03-11-2013, 04:53 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by erling66 - 03-16-2013, 12:07 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 03-16-2013, 08:46 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 03-19-2013, 05:51 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by HaavardPYA - 03-19-2013, 10:54 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 03-19-2013, 12:28 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 03-20-2013, 07:52 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 03-20-2013, 11:06 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 03-25-2013, 04:46 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by MFSuper90 - 03-25-2013, 09:21 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 03-26-2013, 03:20 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by HaavardPYA - 03-26-2013, 03:44 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 03-30-2013, 11:33 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 03-31-2013, 07:10 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Simpler=Better - 03-31-2013, 08:46 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by raysorenson - 03-31-2013, 09:50 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 04-02-2013, 03:13 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 04-05-2013, 03:44 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 04-09-2013, 03:28 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by hansebanger77 - 04-10-2013, 01:31 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 04-10-2013, 02:23 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 04-10-2013, 02:58 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 04-28-2013, 04:43 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 04-29-2013, 02:37 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 04-29-2013, 03:34 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 04-29-2013, 05:20 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 05-02-2013, 02:14 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 05-03-2013, 02:24 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by majesty78 - 05-06-2013, 01:38 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 05-06-2013, 02:32 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Simpler=Better - 05-06-2013, 04:07 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 05-07-2013, 02:14 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 05-07-2013, 04:26 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 05-08-2013, 03:54 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 05-09-2013, 06:03 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Simpler=Better - 05-10-2013, 08:32 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by maxypriest - 05-10-2013, 09:37 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 05-11-2013, 03:40 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 05-10-2013, 03:24 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by hansebanger77 - 05-10-2013, 08:59 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by hansebanger77 - 05-11-2013, 04:09 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 05-12-2013, 03:28 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Simpler=Better - 05-13-2013, 08:15 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 05-13-2013, 02:43 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Njdub - 05-13-2013, 08:16 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 05-19-2013, 06:55 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by maxypriest - 05-20-2013, 11:12 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 05-20-2013, 02:47 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 05-30-2013, 01:40 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 06-09-2013, 04:04 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by lgreeley83 - 06-09-2013, 10:31 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 06-11-2013, 03:34 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by HaavardPYA - 06-11-2013, 03:55 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by larsalan - 06-11-2013, 06:23 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 06-12-2013, 01:21 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by DiseaselWeasel - 06-12-2013, 01:39 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-02-2013, 06:48 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by lgreeley83 - 07-02-2013, 07:44 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 07-03-2013, 03:09 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by mantahead - 07-03-2013, 04:14 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by bruno_pinho - 07-03-2013, 07:26 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Simpler=Better - 07-03-2013, 07:51 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-03-2013, 06:47 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-04-2013, 06:19 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by winmutt - 07-05-2013, 08:56 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by HaavardPYA - 07-05-2013, 09:38 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by mantahead - 07-05-2013, 06:00 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-05-2013, 08:28 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-09-2013, 09:52 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Simpler=Better - 07-09-2013, 03:33 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by HaavardPYA - 07-10-2013, 11:16 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 07-11-2013, 02:36 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-11-2013, 04:16 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 07-12-2013, 03:08 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-12-2013, 02:32 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by JB3 - 07-14-2013, 03:51 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-17-2013, 10:22 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Simpler=Better - 07-17-2013, 11:30 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by StrikerofDeath - 07-25-2013, 08:22 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by winmutt - 07-18-2013, 08:26 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-18-2013, 02:18 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by willbhere4u - 07-25-2013, 11:37 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Simpler=Better - 07-25-2013, 12:45 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-31-2013, 08:43 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Simpler=Better - 07-31-2013, 09:52 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by lgreeley83 - 07-31-2013, 10:43 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 08-09-2013, 04:46 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by HaavardPYA - 08-09-2013, 06:35 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 08-09-2013, 06:50 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by HaavardPYA - 08-10-2013, 03:40 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 08-17-2013, 04:12 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Simpler=Better - 08-17-2013, 11:12 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 08-19-2013, 01:54 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by MFSuper90 - 08-19-2013, 07:55 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 08-19-2013, 09:21 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 08-20-2013, 03:21 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 09-02-2013, 03:09 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by winmutt - 09-02-2013, 06:54 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by EDH_Performance - 09-02-2013, 08:45 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 09-03-2013, 02:13 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 09-03-2013, 10:19 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 09-04-2013, 03:08 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 09-08-2013, 04:53 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 09-09-2013, 02:57 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 09-13-2013, 11:30 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 09-16-2013, 02:23 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 09-16-2013, 04:36 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 09-17-2013, 03:24 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 09-17-2013, 04:03 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 09-17-2013, 07:27 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 10-24-2013, 03:28 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 10-30-2013, 03:29 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 10-30-2013, 02:48 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by S.Engen - 11-26-2013, 01:14 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by mantahead - 10-30-2013, 04:27 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 10-31-2013, 03:25 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by willbhere4u - 10-31-2013, 10:16 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by bonden_85 - 11-03-2013, 09:16 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 11-24-2013, 03:08 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 11-29-2013, 04:46 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 12-06-2013, 10:28 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Tito - 12-06-2013, 12:28 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 12-07-2013, 02:53 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by erling66 - 12-08-2013, 03:00 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by uli124125 - 12-08-2013, 04:50 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 12-08-2013, 06:19 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by erling66 - 12-08-2013, 07:25 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 12-08-2013, 12:59 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by uli124125 - 12-08-2013, 11:29 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by erling66 - 12-09-2013, 02:56 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 12-09-2013, 04:13 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 12-09-2013, 03:21 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 12-11-2013, 09:44 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 12-11-2013, 02:58 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 12-12-2013, 03:21 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Alcaid - 12-29-2013, 03:24 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by john - 12-29-2013, 04:24 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Alcaid - 12-29-2013, 04:34 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by john - 12-29-2013, 05:06 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 12-29-2013, 05:51 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 12-12-2013, 03:12 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 12-16-2013, 02:08 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by erling66 - 12-20-2013, 03:12 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 12-18-2013, 04:05 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by EDH_Performance - 12-19-2013, 11:34 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 12-19-2013, 04:07 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by EDH_Performance - 12-29-2013, 06:07 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by erling66 - 12-30-2013, 03:52 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Duncansport - 12-30-2013, 12:11 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 12-30-2013, 02:03 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by erling66 - 12-31-2013, 03:59 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Duncansport - 12-31-2013, 10:11 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by erling66 - 12-31-2013, 10:34 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Duncansport - 12-31-2013, 01:03 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 01-03-2014, 11:14 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 02-02-2014, 12:10 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Simpler=Better - 02-03-2014, 09:07 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by S.Engen - 02-03-2014, 12:30 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by EDH_Performance - 02-04-2014, 03:04 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by willbhere4u - 02-03-2014, 04:39 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 02-08-2014, 03:37 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 02-11-2014, 03:07 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Simpler=Better - 02-11-2014, 04:47 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 02-13-2014, 02:13 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by mantahead - 02-13-2014, 05:59 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 02-16-2014, 02:37 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 02-16-2014, 05:25 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by erling66 - 02-17-2014, 04:33 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 02-18-2014, 02:01 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by EDH_Performance - 02-18-2014, 10:37 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 02-18-2014, 11:42 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 02-21-2014, 06:55 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 02-23-2014, 07:24 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by bigbortha - 02-23-2014, 11:36 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by F.R.A.S - 02-24-2014, 07:08 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Simpler=Better - 02-25-2014, 10:35 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by lgreeley83 - 02-25-2014, 10:56 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 02-25-2014, 03:00 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by willbhere4u - 02-26-2014, 01:06 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 02-26-2014, 03:15 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by willbhere4u - 02-26-2014, 05:56 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 02-28-2014, 09:58 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 03-01-2014, 05:26 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by EDH_Performance - 03-02-2014, 01:48 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by F.R.A.S - 03-02-2014, 12:59 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by EDH_Performance - 03-02-2014, 04:56 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 03-04-2014, 10:26 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by sorin_cel - 04-05-2014, 12:05 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 04-20-2014, 12:57 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by F.R.A.S - 04-21-2014, 03:10 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by giuliettaevo - 04-23-2014, 03:35 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by hansebanger77 - 04-25-2014, 05:11 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 06-29-2014, 05:34 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Turbo - 06-29-2014, 07:50 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by giuliettaevo - 04-26-2014, 02:51 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by F.R.A.S - 06-22-2014, 03:25 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Simpler=Better - 06-23-2014, 08:28 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 06-25-2014, 03:12 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-01-2014, 02:47 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Tito - 07-01-2014, 03:06 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-03-2014, 03:15 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by F.R.A.S - 07-04-2014, 05:09 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by rafael cotrim - 07-04-2014, 05:45 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-05-2014, 12:05 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by StrikerofDeath - 07-05-2014, 06:28 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-06-2014, 06:52 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by StrikerofDeath - 07-07-2014, 06:45 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-07-2014, 05:28 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Sotvisp - 07-08-2014, 02:38 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-08-2014, 02:39 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Simpler=Better - 07-08-2014, 09:30 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-09-2014, 08:11 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by MFSuper90 - 07-09-2014, 08:19 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-09-2014, 08:01 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by MFSuper90 - 07-10-2014, 01:47 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by raysorenson - 07-10-2014, 11:28 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by winmutt - 07-10-2014, 01:59 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-13-2014, 11:39 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Petar - 07-13-2014, 02:17 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-13-2014, 02:52 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by MFSuper90 - 07-13-2014, 08:09 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-14-2014, 03:34 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by F.R.A.S - 07-16-2014, 04:56 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Gasoil - 07-19-2014, 06:06 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-25-2014, 04:16 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by F.R.A.S - 07-28-2014, 03:54 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Gasoil - 07-28-2014, 01:22 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 08-11-2014, 05:56 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by F.R.A.S - 08-15-2014, 02:33 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 08-29-2014, 05:19 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Turbo - 08-30-2014, 12:54 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 08-30-2014, 02:56 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by StrikerofDeath - 10-13-2014, 04:18 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 11-07-2014, 07:26 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by raysorenson - 11-07-2014, 08:06 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 11-07-2014, 08:21 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Gasoil - 11-10-2014, 04:14 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 11-20-2014, 05:54 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by StrikerofDeath - 11-23-2014, 04:31 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by hents99 - 11-24-2014, 10:17 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 01-10-2015, 06:28 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 01-11-2015, 04:14 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by rolfts - 01-12-2015, 02:19 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by F.R.A.S - 01-12-2015, 06:19 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Ksteen2 - 01-14-2015, 05:07 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 01-15-2015, 04:10 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 01-18-2015, 04:12 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by seanyt - 01-26-2015, 11:43 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by maxypriest - 01-26-2015, 07:35 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 01-27-2015, 04:14 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Ksteen2 - 01-28-2015, 01:35 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Max - 01-28-2015, 04:35 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 02-10-2015, 03:01 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by mantahead - 02-10-2015, 03:58 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Ksteen2 - 02-10-2015, 06:42 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Tito - 02-13-2015, 01:04 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 02-14-2015, 07:40 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 02-28-2015, 07:20 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Mr_Robs - 02-28-2015, 09:29 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 04-15-2015, 02:58 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Turbo - 04-16-2015, 11:23 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 04-22-2015, 04:46 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 05-04-2015, 03:05 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 05-06-2015, 02:35 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Turbo - 05-06-2015, 02:53 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 05-10-2015, 02:40 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by svenr - 05-10-2015, 03:09 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 05-14-2015, 02:06 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by DiseaselWeasel - 05-14-2015, 03:23 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 05-14-2015, 04:09 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by DiseaselWeasel - 05-14-2015, 09:37 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Booster - 05-14-2015, 12:37 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 05-30-2015, 01:39 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Turbo - 05-30-2015, 02:08 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 05-30-2015, 02:34 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Turbo - 05-30-2015, 03:03 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 05-31-2015, 03:13 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by raysorenson - 05-31-2015, 08:45 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Turbo - 06-01-2015, 01:37 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Alcaid - 06-04-2015, 06:39 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Alcaid - 06-04-2015, 06:47 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Turbo - 06-04-2015, 02:12 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Turbo - 06-04-2015, 02:14 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Alcaid - 06-04-2015, 03:06 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Turbo - 06-04-2015, 05:31 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Alcaid - 06-05-2015, 02:31 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Duncansport - 06-05-2015, 06:02 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Alcaid - 06-05-2015, 06:29 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Turbo - 06-05-2015, 08:07 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by atypicalguy - 06-08-2015, 02:50 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Alcaid - 06-09-2015, 05:29 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by atypicalguy - 06-09-2015, 07:02 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 06-26-2015, 08:49 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Keino - 06-26-2015, 10:36 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by atypicalguy - 06-27-2015, 10:06 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 07-03-2015, 04:56 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by raysorenson - 07-03-2015, 09:07 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by MFSuper90 - 07-04-2015, 10:57 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 07-13-2015, 01:13 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 08-24-2015, 09:53 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by StrikerofDeath - 08-27-2015, 07:50 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 08-31-2015, 02:11 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Keino - 08-31-2015, 02:50 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 09-08-2015, 04:03 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by atypicalguy - 09-08-2015, 06:29 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by MFSuper90 - 09-09-2015, 09:40 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 09-23-2015, 01:51 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by CRD4x4 - 09-23-2015, 04:11 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by MFSuper90 - 09-23-2015, 07:50 PM
 11 Guest(s)
 11 Guest(s)
