STD Other Projects Om605 compound turbo build, my Corolla Ke70 tracktoy
  • 2 Vote(s) - 5 Average
Stamsaas
12-08-2013, 12:59 PM #147
(12-08-2013, 07:25 AM)erling66
(12-08-2013, 06:19 AM)Stamsaas I have a gearbox ready to put in, so start With that. But interresting what you say about put a bearing in the flywheel Smile Must check my flywheel (lightwight) to see if i can put a bearing in that. Smile Is it the same splines on the gearbox shaft? Smile
The axle has the same splines but is 2 cm shorter so it will not reach your clutch plate, unless you have a clutch plate with a 2cm offset center. But you probably don't since it fit your long axle 5 speed.
You should adjust the fuel delivered before boost, ask Gøran if you are not sure how to do it. A tuned diesel that make that much smoke gives old diesels a bad reputation. Imagine if one of the politicians so your videoConfused I am afraid to think about the consequences....
I know how to adjust the pump, but the alda gives full amount of diesel at about 1.3bar boost, I have read dieselmeken wrote that someplace. but the pump is adjusted to give diesel enough to 2,6bar boost, but dont have grip to get that boost. Thats why, it gives diesel to 2,6bar boost, but it only makes 1.5-1.8 bar because of the grip. its better on dry and not icy roads when it has grip. Its also late spoolup, so a compound setup will be better on every way, except the space Smile
Stamsaas
Messages In This Thread
Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 03-03-2013, 04:11 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by mantahead - 03-03-2013, 05:07 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by George3soccer - 03-03-2013, 07:21 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by willbhere4u - 03-03-2013, 08:51 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Simpler=Better - 03-03-2013, 10:05 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 03-04-2013, 02:56 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by maxypriest - 03-04-2013, 07:59 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 03-04-2013, 01:24 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Simpler=Better - 03-04-2013, 02:32 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by HaavardPYA - 03-04-2013, 04:24 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 03-05-2013, 03:21 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by HaavardPYA - 03-05-2013, 10:32 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by EDH_Performance - 03-05-2013, 05:14 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 03-06-2013, 03:34 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by willbhere4u - 03-05-2013, 12:29 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 03-06-2013, 08:00 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by jeemu - 03-11-2013, 04:00 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 03-11-2013, 04:11 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Simpler=Better - 03-11-2013, 04:53 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by erling66 - 03-16-2013, 12:07 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 03-16-2013, 08:46 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 03-19-2013, 05:51 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by HaavardPYA - 03-19-2013, 10:54 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 03-19-2013, 12:28 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 03-20-2013, 07:52 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 03-20-2013, 11:06 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 03-25-2013, 04:46 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by MFSuper90 - 03-25-2013, 09:21 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 03-26-2013, 03:20 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by HaavardPYA - 03-26-2013, 03:44 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 03-30-2013, 11:33 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 03-31-2013, 07:10 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Simpler=Better - 03-31-2013, 08:46 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by raysorenson - 03-31-2013, 09:50 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 04-02-2013, 03:13 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 04-05-2013, 03:44 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 04-09-2013, 03:28 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by hansebanger77 - 04-10-2013, 01:31 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 04-10-2013, 02:23 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 04-10-2013, 02:58 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 04-28-2013, 04:43 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 04-29-2013, 02:37 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 04-29-2013, 03:34 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 04-29-2013, 05:20 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 05-02-2013, 02:14 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 05-03-2013, 02:24 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by majesty78 - 05-06-2013, 01:38 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 05-06-2013, 02:32 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Simpler=Better - 05-06-2013, 04:07 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 05-07-2013, 02:14 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 05-07-2013, 04:26 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 05-08-2013, 03:54 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 05-09-2013, 06:03 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Simpler=Better - 05-10-2013, 08:32 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by maxypriest - 05-10-2013, 09:37 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 05-11-2013, 03:40 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 05-10-2013, 03:24 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by hansebanger77 - 05-10-2013, 08:59 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by hansebanger77 - 05-11-2013, 04:09 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 05-12-2013, 03:28 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Simpler=Better - 05-13-2013, 08:15 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 05-13-2013, 02:43 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Njdub - 05-13-2013, 08:16 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 05-19-2013, 06:55 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by maxypriest - 05-20-2013, 11:12 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 05-20-2013, 02:47 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 05-30-2013, 01:40 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 06-09-2013, 04:04 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by lgreeley83 - 06-09-2013, 10:31 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 06-11-2013, 03:34 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by HaavardPYA - 06-11-2013, 03:55 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by larsalan - 06-11-2013, 06:23 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 06-12-2013, 01:21 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by DiseaselWeasel - 06-12-2013, 01:39 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-02-2013, 06:48 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by lgreeley83 - 07-02-2013, 07:44 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 07-03-2013, 03:09 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by mantahead - 07-03-2013, 04:14 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by bruno_pinho - 07-03-2013, 07:26 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Simpler=Better - 07-03-2013, 07:51 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-03-2013, 06:47 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-04-2013, 06:19 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by winmutt - 07-05-2013, 08:56 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by HaavardPYA - 07-05-2013, 09:38 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by mantahead - 07-05-2013, 06:00 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-05-2013, 08:28 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-09-2013, 09:52 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Simpler=Better - 07-09-2013, 03:33 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by HaavardPYA - 07-10-2013, 11:16 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 07-11-2013, 02:36 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-11-2013, 04:16 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 07-12-2013, 03:08 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-12-2013, 02:32 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by JB3 - 07-14-2013, 03:51 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-17-2013, 10:22 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Simpler=Better - 07-17-2013, 11:30 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by StrikerofDeath - 07-25-2013, 08:22 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by winmutt - 07-18-2013, 08:26 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-18-2013, 02:18 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by willbhere4u - 07-25-2013, 11:37 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Simpler=Better - 07-25-2013, 12:45 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-31-2013, 08:43 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Simpler=Better - 07-31-2013, 09:52 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by lgreeley83 - 07-31-2013, 10:43 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 08-09-2013, 04:46 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by HaavardPYA - 08-09-2013, 06:35 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 08-09-2013, 06:50 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by HaavardPYA - 08-10-2013, 03:40 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 08-17-2013, 04:12 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Simpler=Better - 08-17-2013, 11:12 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 08-19-2013, 01:54 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by MFSuper90 - 08-19-2013, 07:55 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 08-19-2013, 09:21 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 08-20-2013, 03:21 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 09-02-2013, 03:09 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by winmutt - 09-02-2013, 06:54 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by EDH_Performance - 09-02-2013, 08:45 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 09-03-2013, 02:13 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 09-03-2013, 10:19 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 09-04-2013, 03:08 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 09-08-2013, 04:53 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 09-09-2013, 02:57 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 09-13-2013, 11:30 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 09-16-2013, 02:23 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 09-16-2013, 04:36 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 09-17-2013, 03:24 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 09-17-2013, 04:03 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 09-17-2013, 07:27 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 10-24-2013, 03:28 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 10-30-2013, 03:29 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 10-30-2013, 02:48 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by S.Engen - 11-26-2013, 01:14 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by mantahead - 10-30-2013, 04:27 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 10-31-2013, 03:25 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by willbhere4u - 10-31-2013, 10:16 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by bonden_85 - 11-03-2013, 09:16 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 11-24-2013, 03:08 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 11-29-2013, 04:46 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 12-06-2013, 10:28 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Tito - 12-06-2013, 12:28 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 12-07-2013, 02:53 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by erling66 - 12-08-2013, 03:00 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by uli124125 - 12-08-2013, 04:50 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 12-08-2013, 06:19 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by erling66 - 12-08-2013, 07:25 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 12-08-2013, 12:59 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by uli124125 - 12-08-2013, 11:29 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by erling66 - 12-09-2013, 02:56 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 12-09-2013, 04:13 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 12-09-2013, 03:21 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 12-11-2013, 09:44 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 12-11-2013, 02:58 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 12-12-2013, 03:21 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Alcaid - 12-29-2013, 03:24 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by john - 12-29-2013, 04:24 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Alcaid - 12-29-2013, 04:34 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by john - 12-29-2013, 05:06 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 12-29-2013, 05:51 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 12-12-2013, 03:12 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 12-16-2013, 02:08 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by erling66 - 12-20-2013, 03:12 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 12-18-2013, 04:05 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by EDH_Performance - 12-19-2013, 11:34 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 12-19-2013, 04:07 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by EDH_Performance - 12-29-2013, 06:07 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by erling66 - 12-30-2013, 03:52 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Duncansport - 12-30-2013, 12:11 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 12-30-2013, 02:03 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by erling66 - 12-31-2013, 03:59 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Duncansport - 12-31-2013, 10:11 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by erling66 - 12-31-2013, 10:34 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Duncansport - 12-31-2013, 01:03 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 01-03-2014, 11:14 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 02-02-2014, 12:10 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Simpler=Better - 02-03-2014, 09:07 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by S.Engen - 02-03-2014, 12:30 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by EDH_Performance - 02-04-2014, 03:04 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by willbhere4u - 02-03-2014, 04:39 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 02-08-2014, 03:37 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 02-11-2014, 03:07 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Simpler=Better - 02-11-2014, 04:47 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 02-13-2014, 02:13 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by mantahead - 02-13-2014, 05:59 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 02-16-2014, 02:37 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Ksteen2 - 02-16-2014, 05:25 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by erling66 - 02-17-2014, 04:33 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 02-18-2014, 02:01 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by EDH_Performance - 02-18-2014, 10:37 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 02-18-2014, 11:42 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 02-21-2014, 06:55 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 02-23-2014, 07:24 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by bigbortha - 02-23-2014, 11:36 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by F.R.A.S - 02-24-2014, 07:08 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Simpler=Better - 02-25-2014, 10:35 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by lgreeley83 - 02-25-2014, 10:56 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 02-25-2014, 03:00 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by willbhere4u - 02-26-2014, 01:06 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 02-26-2014, 03:15 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by willbhere4u - 02-26-2014, 05:56 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 02-28-2014, 09:58 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 03-01-2014, 05:26 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by EDH_Performance - 03-02-2014, 01:48 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by F.R.A.S - 03-02-2014, 12:59 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by EDH_Performance - 03-02-2014, 04:56 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 03-04-2014, 10:26 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by sorin_cel - 04-05-2014, 12:05 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 04-20-2014, 12:57 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by F.R.A.S - 04-21-2014, 03:10 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by giuliettaevo - 04-23-2014, 03:35 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by hansebanger77 - 04-25-2014, 05:11 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 06-29-2014, 05:34 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Turbo - 06-29-2014, 07:50 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by giuliettaevo - 04-26-2014, 02:51 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by F.R.A.S - 06-22-2014, 03:25 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Simpler=Better - 06-23-2014, 08:28 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 06-25-2014, 03:12 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-01-2014, 02:47 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Tito - 07-01-2014, 03:06 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-03-2014, 03:15 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by F.R.A.S - 07-04-2014, 05:09 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by rafael cotrim - 07-04-2014, 05:45 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-05-2014, 12:05 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by StrikerofDeath - 07-05-2014, 06:28 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-06-2014, 06:52 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by StrikerofDeath - 07-07-2014, 06:45 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-07-2014, 05:28 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Sotvisp - 07-08-2014, 02:38 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-08-2014, 02:39 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Simpler=Better - 07-08-2014, 09:30 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-09-2014, 08:11 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by MFSuper90 - 07-09-2014, 08:19 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-09-2014, 08:01 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by MFSuper90 - 07-10-2014, 01:47 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by raysorenson - 07-10-2014, 11:28 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by winmutt - 07-10-2014, 01:59 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-13-2014, 11:39 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Petar - 07-13-2014, 02:17 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-13-2014, 02:52 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by MFSuper90 - 07-13-2014, 08:09 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-14-2014, 03:34 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by F.R.A.S - 07-16-2014, 04:56 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Gasoil - 07-19-2014, 06:06 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 07-25-2014, 04:16 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by F.R.A.S - 07-28-2014, 03:54 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Gasoil - 07-28-2014, 01:22 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 08-11-2014, 05:56 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by F.R.A.S - 08-15-2014, 02:33 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 08-29-2014, 05:19 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Turbo - 08-30-2014, 12:54 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 08-30-2014, 02:56 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by StrikerofDeath - 10-13-2014, 04:18 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 11-07-2014, 07:26 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by raysorenson - 11-07-2014, 08:06 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 11-07-2014, 08:21 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Gasoil - 11-10-2014, 04:14 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 11-20-2014, 05:54 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by StrikerofDeath - 11-23-2014, 04:31 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by hents99 - 11-24-2014, 10:17 AM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 01-10-2015, 06:28 PM
RE: Norwegian OM605 build -> 1980 Ke70 Corolla - by Stamsaas - 01-11-2015, 04:14 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by rolfts - 01-12-2015, 02:19 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by F.R.A.S - 01-12-2015, 06:19 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Ksteen2 - 01-14-2015, 05:07 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 01-15-2015, 04:10 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 01-18-2015, 04:12 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by seanyt - 01-26-2015, 11:43 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by maxypriest - 01-26-2015, 07:35 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 01-27-2015, 04:14 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Ksteen2 - 01-28-2015, 01:35 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Max - 01-28-2015, 04:35 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 02-10-2015, 03:01 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by mantahead - 02-10-2015, 03:58 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Ksteen2 - 02-10-2015, 06:42 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Tito - 02-13-2015, 01:04 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 02-14-2015, 07:40 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 02-28-2015, 07:20 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Mr_Robs - 02-28-2015, 09:29 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 04-15-2015, 02:58 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Turbo - 04-16-2015, 11:23 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 04-22-2015, 04:46 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 05-04-2015, 03:05 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 05-06-2015, 02:35 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Turbo - 05-06-2015, 02:53 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 05-10-2015, 02:40 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by svenr - 05-10-2015, 03:09 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 05-14-2015, 02:06 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by DiseaselWeasel - 05-14-2015, 03:23 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 05-14-2015, 04:09 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by DiseaselWeasel - 05-14-2015, 09:37 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Booster - 05-14-2015, 12:37 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 05-30-2015, 01:39 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Turbo - 05-30-2015, 02:08 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 05-30-2015, 02:34 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Turbo - 05-30-2015, 03:03 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 05-31-2015, 03:13 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by raysorenson - 05-31-2015, 08:45 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Turbo - 06-01-2015, 01:37 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Alcaid - 06-04-2015, 06:39 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Alcaid - 06-04-2015, 06:47 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Turbo - 06-04-2015, 02:12 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Turbo - 06-04-2015, 02:14 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Alcaid - 06-04-2015, 03:06 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Turbo - 06-04-2015, 05:31 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Alcaid - 06-05-2015, 02:31 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Duncansport - 06-05-2015, 06:02 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Alcaid - 06-05-2015, 06:29 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Turbo - 06-05-2015, 08:07 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by atypicalguy - 06-08-2015, 02:50 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Alcaid - 06-09-2015, 05:29 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by atypicalguy - 06-09-2015, 07:02 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 06-26-2015, 08:49 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Keino - 06-26-2015, 10:36 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by atypicalguy - 06-27-2015, 10:06 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 07-03-2015, 04:56 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by raysorenson - 07-03-2015, 09:07 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by MFSuper90 - 07-04-2015, 10:57 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 07-13-2015, 01:13 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 08-24-2015, 09:53 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by StrikerofDeath - 08-27-2015, 07:50 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 08-31-2015, 02:11 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Keino - 08-31-2015, 02:50 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 09-08-2015, 04:03 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by atypicalguy - 09-08-2015, 06:29 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by MFSuper90 - 09-09-2015, 09:40 AM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by Stamsaas - 09-23-2015, 01:51 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by CRD4x4 - 09-23-2015, 04:11 PM
RE: Om605 compound turbo build, my Corolla Ke70 tracktoy - by MFSuper90 - 09-23-2015, 07:50 PM
 11 Guest(s)
 11 Guest(s)
