Another car, chicago, uhhh 300d turbo w/4 speed manual
(08-13-2013, 07:55 AM)Simpler=Better Buy an indicator from HF and a stand, then stick a drill bit or other thing in the end to extend it. A 1" throw won't reach valve spring retaining plate thingy. Remove valve last, and rotate until you're up 2mm. read the timing on the engine. Bam. done.
[undefined=undefined]Your fuel filter can move to the bracket holes, that's how mine is setup. You will need new clear lines though (tygon/fuel-rated nylon/etc.)[/undefined]
