STD Other Projects Turbo 616 powered Astro Van build
  • 5 Vote(s) - 4.2 Average
04-13-2013, 02:31 PM #131
so here are the radiators compared- MB on the left. The ports are in the right place apart from the difference of side to side vs up and down flow.
[Image: 001-3_zps92959cf1.jpg]
Amazingly, the stock astro upper hose fits perfectly if you cut off about 2 inches. The stock Mercedes lower hose fits with about 4 inches removed. There might be a reference issue with the fan for the lower hose, and Im missing a lower plastic shroud that I definitely need that should solve that problem. The fans almost fits in the shroud correctly, just about 1 inch over to the passenger side. Also I had to trim a one inch strip off the upper shroud to clear the power steering pump
cooling system almost completely hooked up-
[Image: 004-2_zps2fb58540.jpg]
the only thing left is this rear port that needs to go to the heater core. The plan is to fabricate a pipe passage that bolts to the top of the valve cover and gets the coolant line past the turbo exhaust area without getting too close-
[Image: 005-2_zps88a6d7b8.jpg]
Excellent development on the throttle. Due to some amazing coincidence, or just a standard hole size that all automakers make for these things, the astro throttle cable fits right in perfectly to the Mercedes cruise control cable attachment. As if it were made for it. Some heavy modification to the throttle will need to take place here, as the distance is quite a bit different for cable throw, but I can use the mercedes bracket for the custom mod
[Image: 007-1_zps9417f9a4.jpg]
[Image: 008_zpsd8780f30.jpg]
@ deliveryvalve-
thanks! HELL no on low pro over size ghetto type crap, lol. Big Grin
this thing is going to be generic gen 1 astro when im done, lettered and commercial plated, just as boring as can possibly be
@ ben2go-
lol, another expensive look id prefer to avoid. the plan is parked in a lot, your eyes don't even recognize this as anything other than a gen 1 work van and pass over without interest until it fires up. Smile
This post was last modified: 04-13-2013, 02:35 PM by JB3.
@ deliveryvalve-
@ ben2go-
Messages In This Thread
Turbo 616 powered Astro Van build - by dropnosky - 11-07-2010, 01:57 PM
RE: Turbo 616 powered Astro Van build - by 300D50 - 11-07-2010, 02:45 PM
RE: Turbo 616 powered Astro Van build - by mike-81-240d - 11-07-2010, 02:49 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 11-07-2010, 04:34 PM
RE: Turbo 616 powered Astro Van build - by 300D50 - 11-07-2010, 04:52 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 11-07-2010, 05:00 PM
RE: Turbo 616 powered Astro Van build - by ben2go - 11-07-2010, 05:04 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 11-07-2010, 05:10 PM
RE: Turbo 616 powered Astro Van build - by 300D50 - 11-07-2010, 05:14 PM
RE: Turbo 616 powered Astro Van build - by DeliveryValve - 11-07-2010, 09:22 PM
RE: Turbo 616 powered Astro Van build - by ben2go - 11-07-2010, 11:27 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 11-24-2010, 02:45 PM
RE: Turbo 616 powered Astro Van build - by ben2go - 11-24-2010, 03:27 PM
RE: Turbo 616 powered Astro Van build - by 300D50 - 11-24-2010, 06:40 PM
RE: Turbo 616 powered Astro Van build - by ben2go - 11-25-2010, 12:03 AM
RE: Turbo 616 powered Astro Van build - by willbhere4u - 11-25-2010, 12:08 AM
RE: Turbo 616 powered Astro Van build - by 300D50 - 11-25-2010, 12:47 AM
RE: Turbo 616 powered Astro Van build - by dropnosky - 11-26-2010, 10:45 PM
RE: Turbo 616 powered Astro Van build - by 300D50 - 11-26-2010, 10:54 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 11-29-2010, 09:24 AM
RE: Turbo 616 powered Astro Van build - by 300D50 - 11-29-2010, 12:58 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 11-30-2010, 09:44 PM
RE: Turbo 616 powered Astro Van build - by 300D50 - 11-30-2010, 09:49 PM
RE: Turbo 616 powered Astro Van build - by Captain America - 11-30-2010, 04:45 PM
RE: Turbo 616 powered Astro Van build - by 300D50 - 12-05-2010, 07:05 AM
RE: Turbo 616 powered Astro Van build - by dropnosky - 12-05-2010, 08:02 AM
RE: Turbo 616 powered Astro Van build - by 300D50 - 12-05-2010, 03:06 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 12-19-2010, 09:05 PM
RE: Turbo 616 powered Astro Van build - by 300D50 - 12-19-2010, 09:36 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 12-20-2010, 08:03 AM
RE: Turbo 616 powered Astro Van build - by Diesel-Wiking - 12-21-2010, 02:53 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 12-23-2010, 12:06 PM
RE: Turbo 616 powered Astro Van build - by ben2go - 12-21-2010, 02:58 PM
RE: Turbo 616 powered Astro Van build - by ben2go - 12-23-2010, 05:35 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 12-24-2010, 06:19 PM
RE: Turbo 616 powered Astro Van build - by ben2go - 12-24-2010, 10:08 PM
RE: Turbo 616 powered Astro Van build - by garage - 02-26-2011, 03:43 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 02-28-2011, 09:01 AM
RE: Turbo 616 powered Astro Van build - by willbhere4u - 02-28-2011, 11:45 AM
RE: Turbo 616 powered Astro Van build - by dropnosky - 02-28-2011, 12:50 PM
RE: Turbo 616 powered Astro Van build - by garage - 02-28-2011, 03:38 PM
RE: Turbo 616 powered Astro Van build - by willbhere4u - 02-28-2011, 01:21 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 05-06-2011, 05:41 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 07-06-2011, 11:00 AM
RE: Turbo 616 powered Astro Van build - by ben2go - 07-06-2011, 07:08 PM
RE: Turbo 616 powered Astro Van build - by srbsmartie - 09-08-2011, 10:12 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 09-09-2011, 08:28 AM
RE: Turbo 616 powered Astro Van build - by dropnosky - 10-03-2011, 03:21 PM
RE: Turbo 616 powered Astro Van build - by DeliveryValve - 10-03-2011, 07:14 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 10-05-2011, 04:37 PM
RE: Turbo 616 powered Astro Van build - by DeliveryValve - 10-05-2011, 06:43 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 10-05-2011, 07:33 PM
RE: Turbo 616 powered Astro Van build - by DeliveryValve - 10-06-2011, 10:48 AM
RE: Turbo 616 powered Astro Van build - by ben2go - 10-03-2011, 05:20 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 10-03-2011, 06:31 PM
RE: Turbo 616 powered Astro Van build - by Purplecomputer - 10-06-2011, 10:40 AM
RE: Turbo 616 powered Astro Van build - by dropnosky - 10-06-2011, 10:54 AM
RE: Turbo 616 powered Astro Van build - by DeliveryValve - 10-06-2011, 11:23 AM
RE: Turbo 616 powered Astro Van build - by Purplecomputer - 10-06-2011, 05:46 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 10-06-2011, 06:38 PM
RE: Turbo 616 powered Astro Van build - by yankneck696 - 10-06-2011, 07:41 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 10-25-2011, 10:20 AM
RE: Turbo 616 powered Astro Van build - by Purplecomputer - 10-25-2011, 10:38 AM
RE: Turbo 616 powered Astro Van build - by dropnosky - 10-25-2011, 10:50 AM
RE: Turbo 616 powered Astro Van build - by 300D50 - 10-25-2011, 03:26 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 10-25-2011, 03:33 PM
RE: Turbo 616 powered Astro Van build - by 300D50 - 10-25-2011, 03:36 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 10-28-2011, 08:41 PM
RE: Turbo 616 powered Astro Van build - by OM616 - 12-30-2011, 04:50 PM
RE: Turbo 616 powered Astro Van build - by DeliveryValve - 10-28-2011, 09:01 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 10-28-2011, 09:23 PM
RE: Turbo 616 powered Astro Van build - by DeliveryValve - 10-29-2011, 01:01 AM
RE: Turbo 616 powered Astro Van build - by dropnosky - 10-29-2011, 08:07 AM
RE: Turbo 616 powered Astro Van build - by willbhere4u - 10-29-2011, 11:09 AM
RE: Turbo 616 powered Astro Van build - by dropnosky - 10-31-2011, 07:20 AM
RE: Turbo 616 powered Astro Van build - by willbhere4u - 10-31-2011, 10:31 AM
RE: Turbo 616 powered Astro Van build - by yankneck696 - 10-31-2011, 03:15 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 10-31-2011, 03:32 PM
RE: Turbo 616 powered Astro Van build - by DeliveryValve - 11-01-2011, 03:52 AM
RE: Turbo 616 powered Astro Van build - by dropnosky - 11-02-2011, 02:40 PM
RE: Turbo 616 powered Astro Van build - by yankneck696 - 11-02-2011, 05:21 PM
RE: Turbo 616 powered Astro Van build - by ben2go - 11-02-2011, 06:41 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 11-09-2011, 06:27 PM
RE: Turbo 616 powered Astro Van build - by Purplecomputer - 11-09-2011, 09:01 PM
RE: Turbo 616 powered Astro Van build - by Captain America - 11-14-2011, 01:26 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 02-13-2012, 09:20 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 06-15-2012, 10:06 AM
RE: Turbo 616 powered Astro Van build - by Purplecomputer - 06-15-2012, 10:34 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 06-15-2012, 02:12 PM
RE: Turbo 616 powered Astro Van build - by Purplecomputer - 06-15-2012, 05:14 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 06-27-2012, 10:47 AM
RE: Turbo 616 powered Astro Van build - by aaa - 06-27-2012, 11:21 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 06-27-2012, 11:31 AM
RE: Turbo 616 powered Astro Van build - by aaa - 06-27-2012, 11:40 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 06-27-2012, 02:09 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 06-27-2012, 01:36 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 09-26-2012, 01:28 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 09-26-2012, 01:56 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-27-2012, 04:27 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 01-16-2013, 11:30 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 01-16-2013, 12:48 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 01-16-2013, 03:44 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 01-17-2013, 04:19 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 01-31-2013, 04:32 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 02-14-2013, 05:49 PM
RE: Turbo 616 powered Astro Van build - by aaa - 02-15-2013, 09:27 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 02-15-2013, 10:51 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 02-15-2013, 10:07 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 02-15-2013, 11:17 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 02-15-2013, 11:36 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 02-15-2013, 12:44 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 02-15-2013, 02:22 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 02-15-2013, 03:42 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 02-15-2013, 04:03 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 03-15-2013, 04:56 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 03-21-2013, 08:53 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 04-04-2013, 06:34 PM
RE: Turbo 616 powered Astro Van build - by DeliveryValve - 04-05-2013, 01:12 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 04-05-2013, 07:59 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 04-05-2013, 08:10 AM
RE: Turbo 616 powered Astro Van build - by Ksteen2 - 04-05-2013, 09:04 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 04-05-2013, 09:12 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 04-05-2013, 09:18 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 04-05-2013, 11:45 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 04-05-2013, 03:46 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 04-12-2013, 08:27 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 04-12-2013, 09:00 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 04-12-2013, 09:07 AM
RE: Turbo 616 powered Astro Van build - by DeliveryValve - 04-12-2013, 09:45 AM
RE: Turbo 616 powered Astro Van build - by ben2go - 04-12-2013, 10:23 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 04-13-2013, 02:31 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 04-13-2013, 05:24 PM
RE: Turbo 616 powered Astro Van build - by DeliveryValve - 04-13-2013, 05:42 PM
RE: Turbo 616 powered Astro Van build - by ben2go - 04-13-2013, 10:21 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 04-15-2013, 05:54 AM
RE: Turbo 616 powered Astro Van build - by DeliveryValve - 04-15-2013, 10:47 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 04-15-2013, 11:01 AM
RE: Turbo 616 powered Astro Van build - by DeliveryValve - 04-15-2013, 11:19 AM
RE: Turbo 616 powered Astro Van build - by maxypriest - 04-15-2013, 12:25 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 04-17-2013, 03:14 PM
RE: Turbo 616 powered Astro Van build - by willbhere4u - 04-17-2013, 03:29 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 04-17-2013, 03:35 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 04-18-2013, 08:38 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 04-18-2013, 01:54 PM
RE: Turbo 616 powered Astro Van build - by Purplecomputer - 04-18-2013, 08:42 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 04-19-2013, 06:00 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 04-20-2013, 05:16 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 04-22-2013, 03:03 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 04-22-2013, 03:51 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 04-23-2013, 08:23 AM
RE: Turbo 616 powered Astro Van build - by raysorenson - 04-23-2013, 10:47 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 04-27-2013, 10:15 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 05-17-2013, 08:28 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 05-21-2013, 02:25 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 05-21-2013, 03:23 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 05-22-2013, 05:49 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 05-22-2013, 06:50 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 05-23-2013, 05:23 PM
RE: Turbo 616 powered Astro Van build - by MFSuper90 - 05-22-2013, 08:49 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 05-23-2013, 08:11 AM
RE: Turbo 616 powered Astro Van build - by waz - 05-23-2013, 09:44 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 05-23-2013, 10:12 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 05-24-2013, 05:01 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 05-29-2013, 09:52 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 05-29-2013, 10:30 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 05-29-2013, 01:29 PM
RE: Turbo 616 powered Astro Van build - by DeliveryValve - 05-29-2013, 11:51 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 05-29-2013, 02:25 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 05-29-2013, 05:06 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 05-29-2013, 08:24 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 05-31-2013, 10:41 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 05-31-2013, 11:51 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 06-06-2013, 12:35 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 06-06-2013, 03:09 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 06-11-2013, 05:14 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 06-18-2013, 05:42 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 06-19-2013, 05:12 PM
RE: Turbo 616 powered Astro Van build - by maxypriest - 06-21-2013, 07:37 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 06-22-2013, 05:00 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 06-22-2013, 07:56 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 06-22-2013, 08:25 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 06-26-2013, 03:17 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 06-27-2013, 04:49 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 06-27-2013, 10:21 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 07-02-2013, 10:08 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 07-02-2013, 10:52 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 07-02-2013, 03:28 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 07-03-2013, 10:51 AM
RE: Turbo 616 powered Astro Van build - by OM616 - 07-04-2013, 02:19 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 07-04-2013, 02:33 PM
RE: Turbo 616 powered Astro Van build - by OM616 - 07-04-2013, 04:35 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 07-05-2013, 09:41 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 07-11-2013, 03:10 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 07-11-2013, 04:36 PM
RE: Turbo 616 powered Astro Van build - by Purplecomputer - 07-12-2013, 01:10 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 07-15-2013, 04:42 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 07-16-2013, 06:47 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 07-17-2013, 08:53 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 07-17-2013, 08:56 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 07-18-2013, 10:17 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 07-19-2013, 10:15 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 07-24-2013, 06:05 AM
RE: Turbo 616 powered Astro Van build - by Purplecomputer - 07-24-2013, 11:22 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 07-24-2013, 08:03 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 07-25-2013, 10:19 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 08-07-2013, 10:44 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 08-07-2013, 12:17 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 08-07-2013, 12:43 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 08-07-2013, 02:10 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 08-14-2013, 06:55 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 08-15-2013, 10:08 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 08-15-2013, 02:01 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 08-15-2013, 03:20 PM
RE: Turbo 616 powered Astro Van build - by DeliveryValve - 08-16-2013, 01:39 AM
RE: Turbo 616 powered Astro Van build - by Ksteen2 - 08-16-2013, 02:33 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 08-16-2013, 07:17 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 08-16-2013, 07:51 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 08-16-2013, 08:29 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 08-22-2013, 11:32 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 08-22-2013, 01:47 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 08-22-2013, 05:27 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 08-28-2013, 08:44 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 08-28-2013, 09:35 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 08-28-2013, 12:00 PM
RE: Turbo 616 powered Astro Van build - by Ksteen2 - 09-04-2013, 03:12 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 09-04-2013, 08:10 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 09-04-2013, 02:41 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 10-10-2013, 07:55 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 10-22-2013, 08:44 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 10-22-2013, 12:50 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 11-25-2013, 09:40 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 11-25-2013, 06:00 PM
RE: Turbo 616 powered Astro Van build - by willbhere4u - 11-26-2013, 11:31 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-03-2013, 05:18 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-05-2013, 09:34 AM
RE: Turbo 616 powered Astro Van build - by Purplecomputer - 12-05-2013, 09:43 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-05-2013, 11:52 AM
RE: Turbo 616 powered Astro Van build - by willbhere4u - 12-05-2013, 12:14 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-05-2013, 01:27 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-05-2013, 04:39 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 12-05-2013, 04:50 PM
RE: Turbo 616 powered Astro Van build - by willbhere4u - 12-05-2013, 04:52 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-05-2013, 04:59 PM
RE: Turbo 616 powered Astro Van build - by willbhere4u - 12-05-2013, 05:21 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-05-2013, 05:58 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-06-2013, 07:02 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-07-2013, 05:41 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-08-2013, 05:02 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-09-2013, 06:03 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-10-2013, 02:22 PM
RE: Turbo 616 powered Astro Van build - by willbhere4u - 12-10-2013, 05:24 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-11-2013, 10:12 AM
RE: Turbo 616 powered Astro Van build - by Tito - 12-11-2013, 12:54 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 12-11-2013, 01:12 PM
RE: Turbo 616 powered Astro Van build - by Tito - 12-11-2013, 01:22 PM
RE: Turbo 616 powered Astro Van build - by Jooseppi Luna - 12-11-2013, 02:42 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-11-2013, 02:43 PM
RE: Turbo 616 powered Astro Van build - by Tito - 12-11-2013, 03:17 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-11-2013, 03:23 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-11-2013, 05:53 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-12-2013, 06:11 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 12-12-2013, 07:39 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-12-2013, 09:25 PM
RE: Turbo 616 powered Astro Van build - by willbhere4u - 12-13-2013, 10:22 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-13-2013, 12:29 PM
RE: Turbo 616 powered Astro Van build - by willbhere4u - 12-13-2013, 06:17 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-18-2013, 03:19 PM
RE: Turbo 616 powered Astro Van build - by willbhere4u - 12-18-2013, 03:57 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-19-2013, 09:47 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 12-19-2013, 10:28 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-21-2013, 05:07 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-23-2013, 01:54 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-26-2013, 01:37 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 01-06-2014, 02:21 PM
RE: Turbo 616 powered Astro Van build - by Jooseppi Luna - 01-06-2014, 03:23 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 01-06-2014, 01:38 PM
RE: Turbo 616 powered Astro Van build - by willbhere4u - 01-06-2014, 05:27 PM
RE: Turbo 616 powered Astro Van build - by Jooseppi Luna - 01-06-2014, 06:48 PM
RE: Turbo 616 powered Astro Van build - by willbhere4u - 01-07-2014, 12:10 PM
RE: Turbo 616 powered Astro Van build - by Purplecomputer - 01-09-2014, 10:49 AM
RE: Turbo 616 powered Astro Van build - by ben2go - 01-29-2014, 04:06 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 01-25-2014, 05:56 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 01-28-2014, 04:45 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 01-29-2014, 10:30 AM
RE: Turbo 616 powered Astro Van build - by Austincarnut - 01-29-2014, 10:46 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 01-29-2014, 10:48 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 01-29-2014, 01:01 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 01-29-2014, 01:52 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 01-30-2014, 09:31 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 01-30-2014, 09:52 AM
RE: Turbo 616 powered Astro Van build - by willbhere4u - 01-29-2014, 02:07 PM
RE: Turbo 616 powered Astro Van build - by willbhere4u - 01-29-2014, 04:36 PM
RE: Turbo 616 powered Astro Van build - by ben2go - 01-29-2014, 10:25 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 01-30-2014, 05:01 PM
RE: Turbo 616 powered Astro Van build - by willbhere4u - 01-31-2014, 10:44 AM
RE: Turbo 616 powered Astro Van build - by _siim_ - 01-31-2014, 02:07 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 08-22-2014, 08:49 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 08-22-2014, 12:01 PM
RE: Turbo 616 powered Astro Van build - by turbojeep - 02-16-2015, 11:37 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 02-19-2015, 02:12 PM
RE: Turbo 616 powered Astro Van build - by Greazzer - 02-19-2015, 09:58 PM
RE: Turbo 616 powered Astro Van build - by Purplecomputer - 02-23-2015, 10:07 AM
RE: Turbo 616 powered Astro Van build - by turbojeep - 02-23-2015, 09:14 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 03-01-2015, 01:38 PM
