06-20-2012, 03:36 PM
#208
47dodge is my user name over there
Here copied from peachparts post "eeking out better performance from 240" This was last fall I did this, have since rebuilt the engine and added a turbo.
"I reamed out the holes in the pre chambers(pc's) this week, and this does give a nice improvement. It has been talked about so I took the plunge and did it. Here are the areas of the holes in the pcs,
616 .0528 square inchs '78
616 .0498 square inchs uprated? an '83
617 .0595 square inchs turbo, '83
It is interesting to note that the uprated ones have less area. three holes are bigger(.125), but two are smaller(.090), plus the mini hole(.025) in the bottom. If i where to go .125 on all five holes in the old style pc then it comes to .0613.
I did ream to .125 diameter on all holes, they were .116.
Results, 5 mph faster on the hill climb. Egts just over 1300 at top of hill. Hill has 700ft of elevation change. Not sure of the distance, but it is steep, and starting from a stop.For general driving lower egts, and more responsive, less smoke too. Now a normal start from a light gets no visible smoke.
This is not a stock engine, changes are new manifold, advanced timing, larger exhaust, ip adjustments. So nothing radical, but not stock either."
__________________
