STD Other Projects Turbo 616 powered Astro Van build
  • 5 Vote(s) - 4.2 Average
10-29-2011, 01:01 AM #71
Your welcome! I just know how much a pain in the arse that engine bay is to work in!
Lowering the engine more is probably the best way to deal with that. Another would be to make a custom valve cover in which the upper portion can slide to towards the rear right off. (Calling Walt!) But I still wonder how much room you'll have to put the wrench in if you don't drop the engine more.
Modifying the subframe to lower the engine will definitely cause the oil pan to hit the steering linkages if your going to keep the engine at the same location. Perhaps you can drop the linkages down? Possibly have the steering box go lower and have the two idler arms mount lower also? Or if you can't lower the box, then make a custom bent connecting rod between the box and the relay arm working in conjunction with the lowered idler arms.
And if you can't get the steering to work out, then maybe an entirely different suspension is needed.... Like a custom Mustang II supension with "rear" steering rack and pinion or a Plymouth Volare suspension type subframe swap. I don't know, just throwing stuff out there.
Messages In This Thread
Turbo 616 powered Astro Van build - by dropnosky - 11-07-2010, 01:57 PM
RE: Turbo 616 powered Astro Van build - by 300D50 - 11-07-2010, 02:45 PM
RE: Turbo 616 powered Astro Van build - by mike-81-240d - 11-07-2010, 02:49 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 11-07-2010, 04:34 PM
RE: Turbo 616 powered Astro Van build - by 300D50 - 11-07-2010, 04:52 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 11-07-2010, 05:00 PM
RE: Turbo 616 powered Astro Van build - by ben2go - 11-07-2010, 05:04 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 11-07-2010, 05:10 PM
RE: Turbo 616 powered Astro Van build - by 300D50 - 11-07-2010, 05:14 PM
RE: Turbo 616 powered Astro Van build - by DeliveryValve - 11-07-2010, 09:22 PM
RE: Turbo 616 powered Astro Van build - by ben2go - 11-07-2010, 11:27 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 11-24-2010, 02:45 PM
RE: Turbo 616 powered Astro Van build - by ben2go - 11-24-2010, 03:27 PM
RE: Turbo 616 powered Astro Van build - by 300D50 - 11-24-2010, 06:40 PM
RE: Turbo 616 powered Astro Van build - by ben2go - 11-25-2010, 12:03 AM
RE: Turbo 616 powered Astro Van build - by willbhere4u - 11-25-2010, 12:08 AM
RE: Turbo 616 powered Astro Van build - by 300D50 - 11-25-2010, 12:47 AM
RE: Turbo 616 powered Astro Van build - by dropnosky - 11-26-2010, 10:45 PM
RE: Turbo 616 powered Astro Van build - by 300D50 - 11-26-2010, 10:54 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 11-29-2010, 09:24 AM
RE: Turbo 616 powered Astro Van build - by 300D50 - 11-29-2010, 12:58 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 11-30-2010, 09:44 PM
RE: Turbo 616 powered Astro Van build - by 300D50 - 11-30-2010, 09:49 PM
RE: Turbo 616 powered Astro Van build - by Captain America - 11-30-2010, 04:45 PM
RE: Turbo 616 powered Astro Van build - by 300D50 - 12-05-2010, 07:05 AM
RE: Turbo 616 powered Astro Van build - by dropnosky - 12-05-2010, 08:02 AM
RE: Turbo 616 powered Astro Van build - by 300D50 - 12-05-2010, 03:06 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 12-19-2010, 09:05 PM
RE: Turbo 616 powered Astro Van build - by 300D50 - 12-19-2010, 09:36 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 12-20-2010, 08:03 AM
RE: Turbo 616 powered Astro Van build - by Diesel-Wiking - 12-21-2010, 02:53 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 12-23-2010, 12:06 PM
RE: Turbo 616 powered Astro Van build - by ben2go - 12-21-2010, 02:58 PM
RE: Turbo 616 powered Astro Van build - by ben2go - 12-23-2010, 05:35 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 12-24-2010, 06:19 PM
RE: Turbo 616 powered Astro Van build - by ben2go - 12-24-2010, 10:08 PM
RE: Turbo 616 powered Astro Van build - by garage - 02-26-2011, 03:43 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 02-28-2011, 09:01 AM
RE: Turbo 616 powered Astro Van build - by willbhere4u - 02-28-2011, 11:45 AM
RE: Turbo 616 powered Astro Van build - by dropnosky - 02-28-2011, 12:50 PM
RE: Turbo 616 powered Astro Van build - by garage - 02-28-2011, 03:38 PM
RE: Turbo 616 powered Astro Van build - by willbhere4u - 02-28-2011, 01:21 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 05-06-2011, 05:41 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 07-06-2011, 11:00 AM
RE: Turbo 616 powered Astro Van build - by ben2go - 07-06-2011, 07:08 PM
RE: Turbo 616 powered Astro Van build - by srbsmartie - 09-08-2011, 10:12 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 09-09-2011, 08:28 AM
RE: Turbo 616 powered Astro Van build - by dropnosky - 10-03-2011, 03:21 PM
RE: Turbo 616 powered Astro Van build - by DeliveryValve - 10-03-2011, 07:14 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 10-05-2011, 04:37 PM
RE: Turbo 616 powered Astro Van build - by DeliveryValve - 10-05-2011, 06:43 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 10-05-2011, 07:33 PM
RE: Turbo 616 powered Astro Van build - by DeliveryValve - 10-06-2011, 10:48 AM
RE: Turbo 616 powered Astro Van build - by ben2go - 10-03-2011, 05:20 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 10-03-2011, 06:31 PM
RE: Turbo 616 powered Astro Van build - by Purplecomputer - 10-06-2011, 10:40 AM
RE: Turbo 616 powered Astro Van build - by dropnosky - 10-06-2011, 10:54 AM
RE: Turbo 616 powered Astro Van build - by DeliveryValve - 10-06-2011, 11:23 AM
RE: Turbo 616 powered Astro Van build - by Purplecomputer - 10-06-2011, 05:46 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 10-06-2011, 06:38 PM
RE: Turbo 616 powered Astro Van build - by yankneck696 - 10-06-2011, 07:41 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 10-25-2011, 10:20 AM
RE: Turbo 616 powered Astro Van build - by Purplecomputer - 10-25-2011, 10:38 AM
RE: Turbo 616 powered Astro Van build - by dropnosky - 10-25-2011, 10:50 AM
RE: Turbo 616 powered Astro Van build - by 300D50 - 10-25-2011, 03:26 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 10-25-2011, 03:33 PM
RE: Turbo 616 powered Astro Van build - by 300D50 - 10-25-2011, 03:36 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 10-28-2011, 08:41 PM
RE: Turbo 616 powered Astro Van build - by OM616 - 12-30-2011, 04:50 PM
RE: Turbo 616 powered Astro Van build - by DeliveryValve - 10-28-2011, 09:01 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 10-28-2011, 09:23 PM
RE: Turbo 616 powered Astro Van build - by DeliveryValve - 10-29-2011, 01:01 AM
RE: Turbo 616 powered Astro Van build - by dropnosky - 10-29-2011, 08:07 AM
RE: Turbo 616 powered Astro Van build - by willbhere4u - 10-29-2011, 11:09 AM
RE: Turbo 616 powered Astro Van build - by dropnosky - 10-31-2011, 07:20 AM
RE: Turbo 616 powered Astro Van build - by willbhere4u - 10-31-2011, 10:31 AM
RE: Turbo 616 powered Astro Van build - by yankneck696 - 10-31-2011, 03:15 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 10-31-2011, 03:32 PM
RE: Turbo 616 powered Astro Van build - by DeliveryValve - 11-01-2011, 03:52 AM
RE: Turbo 616 powered Astro Van build - by dropnosky - 11-02-2011, 02:40 PM
RE: Turbo 616 powered Astro Van build - by yankneck696 - 11-02-2011, 05:21 PM
RE: Turbo 616 powered Astro Van build - by ben2go - 11-02-2011, 06:41 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 11-09-2011, 06:27 PM
RE: Turbo 616 powered Astro Van build - by Purplecomputer - 11-09-2011, 09:01 PM
RE: Turbo 616 powered Astro Van build - by Captain America - 11-14-2011, 01:26 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 02-13-2012, 09:20 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 06-15-2012, 10:06 AM
RE: Turbo 616 powered Astro Van build - by Purplecomputer - 06-15-2012, 10:34 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 06-15-2012, 02:12 PM
RE: Turbo 616 powered Astro Van build - by Purplecomputer - 06-15-2012, 05:14 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 06-27-2012, 10:47 AM
RE: Turbo 616 powered Astro Van build - by aaa - 06-27-2012, 11:21 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 06-27-2012, 11:31 AM
RE: Turbo 616 powered Astro Van build - by aaa - 06-27-2012, 11:40 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 06-27-2012, 02:09 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 06-27-2012, 01:36 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 09-26-2012, 01:28 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 09-26-2012, 01:56 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-27-2012, 04:27 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 01-16-2013, 11:30 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 01-16-2013, 12:48 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 01-16-2013, 03:44 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 01-17-2013, 04:19 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 01-31-2013, 04:32 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 02-14-2013, 05:49 PM
RE: Turbo 616 powered Astro Van build - by aaa - 02-15-2013, 09:27 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 02-15-2013, 10:51 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 02-15-2013, 10:07 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 02-15-2013, 11:17 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 02-15-2013, 11:36 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 02-15-2013, 12:44 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 02-15-2013, 02:22 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 02-15-2013, 03:42 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 02-15-2013, 04:03 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 03-15-2013, 04:56 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 03-21-2013, 08:53 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 04-04-2013, 06:34 PM
RE: Turbo 616 powered Astro Van build - by DeliveryValve - 04-05-2013, 01:12 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 04-05-2013, 07:59 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 04-05-2013, 08:10 AM
RE: Turbo 616 powered Astro Van build - by Ksteen2 - 04-05-2013, 09:04 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 04-05-2013, 09:12 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 04-05-2013, 09:18 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 04-05-2013, 11:45 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 04-05-2013, 03:46 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 04-12-2013, 08:27 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 04-12-2013, 09:00 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 04-12-2013, 09:07 AM
RE: Turbo 616 powered Astro Van build - by DeliveryValve - 04-12-2013, 09:45 AM
RE: Turbo 616 powered Astro Van build - by ben2go - 04-12-2013, 10:23 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 04-13-2013, 02:31 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 04-13-2013, 05:24 PM
RE: Turbo 616 powered Astro Van build - by DeliveryValve - 04-13-2013, 05:42 PM
RE: Turbo 616 powered Astro Van build - by ben2go - 04-13-2013, 10:21 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 04-15-2013, 05:54 AM
RE: Turbo 616 powered Astro Van build - by DeliveryValve - 04-15-2013, 10:47 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 04-15-2013, 11:01 AM
RE: Turbo 616 powered Astro Van build - by DeliveryValve - 04-15-2013, 11:19 AM
RE: Turbo 616 powered Astro Van build - by maxypriest - 04-15-2013, 12:25 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 04-17-2013, 03:14 PM
RE: Turbo 616 powered Astro Van build - by willbhere4u - 04-17-2013, 03:29 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 04-17-2013, 03:35 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 04-18-2013, 08:38 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 04-18-2013, 01:54 PM
RE: Turbo 616 powered Astro Van build - by Purplecomputer - 04-18-2013, 08:42 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 04-19-2013, 06:00 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 04-20-2013, 05:16 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 04-22-2013, 03:03 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 04-22-2013, 03:51 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 04-23-2013, 08:23 AM
RE: Turbo 616 powered Astro Van build - by raysorenson - 04-23-2013, 10:47 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 04-27-2013, 10:15 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 05-17-2013, 08:28 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 05-21-2013, 02:25 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 05-21-2013, 03:23 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 05-22-2013, 05:49 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 05-22-2013, 06:50 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 05-23-2013, 05:23 PM
RE: Turbo 616 powered Astro Van build - by MFSuper90 - 05-22-2013, 08:49 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 05-23-2013, 08:11 AM
RE: Turbo 616 powered Astro Van build - by waz - 05-23-2013, 09:44 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 05-23-2013, 10:12 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 05-24-2013, 05:01 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 05-29-2013, 09:52 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 05-29-2013, 10:30 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 05-29-2013, 01:29 PM
RE: Turbo 616 powered Astro Van build - by DeliveryValve - 05-29-2013, 11:51 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 05-29-2013, 02:25 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 05-29-2013, 05:06 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 05-29-2013, 08:24 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 05-31-2013, 10:41 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 05-31-2013, 11:51 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 06-06-2013, 12:35 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 06-06-2013, 03:09 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 06-11-2013, 05:14 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 06-18-2013, 05:42 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 06-19-2013, 05:12 PM
RE: Turbo 616 powered Astro Van build - by maxypriest - 06-21-2013, 07:37 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 06-22-2013, 05:00 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 06-22-2013, 07:56 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 06-22-2013, 08:25 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 06-26-2013, 03:17 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 06-27-2013, 04:49 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 06-27-2013, 10:21 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 07-02-2013, 10:08 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 07-02-2013, 10:52 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 07-02-2013, 03:28 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 07-03-2013, 10:51 AM
RE: Turbo 616 powered Astro Van build - by OM616 - 07-04-2013, 02:19 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 07-04-2013, 02:33 PM
RE: Turbo 616 powered Astro Van build - by OM616 - 07-04-2013, 04:35 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 07-05-2013, 09:41 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 07-11-2013, 03:10 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 07-11-2013, 04:36 PM
RE: Turbo 616 powered Astro Van build - by Purplecomputer - 07-12-2013, 01:10 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 07-15-2013, 04:42 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 07-16-2013, 06:47 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 07-17-2013, 08:53 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 07-17-2013, 08:56 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 07-18-2013, 10:17 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 07-19-2013, 10:15 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 07-24-2013, 06:05 AM
RE: Turbo 616 powered Astro Van build - by Purplecomputer - 07-24-2013, 11:22 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 07-24-2013, 08:03 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 07-25-2013, 10:19 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 08-07-2013, 10:44 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 08-07-2013, 12:17 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 08-07-2013, 12:43 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 08-07-2013, 02:10 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 08-14-2013, 06:55 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 08-15-2013, 10:08 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 08-15-2013, 02:01 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 08-15-2013, 03:20 PM
RE: Turbo 616 powered Astro Van build - by DeliveryValve - 08-16-2013, 01:39 AM
RE: Turbo 616 powered Astro Van build - by Ksteen2 - 08-16-2013, 02:33 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 08-16-2013, 07:17 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 08-16-2013, 07:51 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 08-16-2013, 08:29 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 08-22-2013, 11:32 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 08-22-2013, 01:47 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 08-22-2013, 05:27 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 08-28-2013, 08:44 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 08-28-2013, 09:35 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 08-28-2013, 12:00 PM
RE: Turbo 616 powered Astro Van build - by Ksteen2 - 09-04-2013, 03:12 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 09-04-2013, 08:10 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 09-04-2013, 02:41 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 10-10-2013, 07:55 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 10-22-2013, 08:44 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 10-22-2013, 12:50 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 11-25-2013, 09:40 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 11-25-2013, 06:00 PM
RE: Turbo 616 powered Astro Van build - by willbhere4u - 11-26-2013, 11:31 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-03-2013, 05:18 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-05-2013, 09:34 AM
RE: Turbo 616 powered Astro Van build - by Purplecomputer - 12-05-2013, 09:43 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-05-2013, 11:52 AM
RE: Turbo 616 powered Astro Van build - by willbhere4u - 12-05-2013, 12:14 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-05-2013, 01:27 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-05-2013, 04:39 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 12-05-2013, 04:50 PM
RE: Turbo 616 powered Astro Van build - by willbhere4u - 12-05-2013, 04:52 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-05-2013, 04:59 PM
RE: Turbo 616 powered Astro Van build - by willbhere4u - 12-05-2013, 05:21 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-05-2013, 05:58 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-06-2013, 07:02 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-07-2013, 05:41 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-08-2013, 05:02 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-09-2013, 06:03 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-10-2013, 02:22 PM
RE: Turbo 616 powered Astro Van build - by willbhere4u - 12-10-2013, 05:24 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-11-2013, 10:12 AM
RE: Turbo 616 powered Astro Van build - by Tito - 12-11-2013, 12:54 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 12-11-2013, 01:12 PM
RE: Turbo 616 powered Astro Van build - by Tito - 12-11-2013, 01:22 PM
RE: Turbo 616 powered Astro Van build - by Jooseppi Luna - 12-11-2013, 02:42 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-11-2013, 02:43 PM
RE: Turbo 616 powered Astro Van build - by Tito - 12-11-2013, 03:17 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-11-2013, 03:23 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-11-2013, 05:53 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-12-2013, 06:11 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 12-12-2013, 07:39 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-12-2013, 09:25 PM
RE: Turbo 616 powered Astro Van build - by willbhere4u - 12-13-2013, 10:22 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-13-2013, 12:29 PM
RE: Turbo 616 powered Astro Van build - by willbhere4u - 12-13-2013, 06:17 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-18-2013, 03:19 PM
RE: Turbo 616 powered Astro Van build - by willbhere4u - 12-18-2013, 03:57 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-19-2013, 09:47 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 12-19-2013, 10:28 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-21-2013, 05:07 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-23-2013, 01:54 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-26-2013, 01:37 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 01-06-2014, 02:21 PM
RE: Turbo 616 powered Astro Van build - by Jooseppi Luna - 01-06-2014, 03:23 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 01-06-2014, 01:38 PM
RE: Turbo 616 powered Astro Van build - by willbhere4u - 01-06-2014, 05:27 PM
RE: Turbo 616 powered Astro Van build - by Jooseppi Luna - 01-06-2014, 06:48 PM
RE: Turbo 616 powered Astro Van build - by willbhere4u - 01-07-2014, 12:10 PM
RE: Turbo 616 powered Astro Van build - by Purplecomputer - 01-09-2014, 10:49 AM
RE: Turbo 616 powered Astro Van build - by ben2go - 01-29-2014, 04:06 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 01-25-2014, 05:56 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 01-28-2014, 04:45 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 01-29-2014, 10:30 AM
RE: Turbo 616 powered Astro Van build - by Austincarnut - 01-29-2014, 10:46 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 01-29-2014, 10:48 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 01-29-2014, 01:01 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 01-29-2014, 01:52 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 01-30-2014, 09:31 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 01-30-2014, 09:52 AM
RE: Turbo 616 powered Astro Van build - by willbhere4u - 01-29-2014, 02:07 PM
RE: Turbo 616 powered Astro Van build - by willbhere4u - 01-29-2014, 04:36 PM
RE: Turbo 616 powered Astro Van build - by ben2go - 01-29-2014, 10:25 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 01-30-2014, 05:01 PM
RE: Turbo 616 powered Astro Van build - by willbhere4u - 01-31-2014, 10:44 AM
RE: Turbo 616 powered Astro Van build - by _siim_ - 01-31-2014, 02:07 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 08-22-2014, 08:49 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 08-22-2014, 12:01 PM
RE: Turbo 616 powered Astro Van build - by turbojeep - 02-16-2015, 11:37 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 02-19-2015, 02:12 PM
RE: Turbo 616 powered Astro Van build - by Greazzer - 02-19-2015, 09:58 PM
RE: Turbo 616 powered Astro Van build - by Purplecomputer - 02-23-2015, 10:07 AM
RE: Turbo 616 powered Astro Van build - by turbojeep - 02-23-2015, 09:14 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 03-01-2015, 01:38 PM
