STD Tuning Engine Electronic variable vane control
  • 1 Vote(s) - 4 Average
Tymbrymi
Klatta Klatta
185
01-30-2009, 02:47 PM #34
(01-30-2009, 02:08 PM)winmutt To bad they are idgits.
You're in a generous mood today Angel
(01-21-2009, 02:55 PM)winmutt So these are K type Thermocouplers I am almost certain of it. Even though I was getting a change in resistance it appears the K type thermocouplers generate micro voltages. I can't interface with the Arduino directly but I *can* get one of these (http://reprap.org/bin/view/Main/Thermocouple_Sensor_1_0) and free up an analog port.
Forget those analog sensors (that board still sent an analog signal to your micro)... check out this one. Thermocouple straight to digital SPI/I2C serial bus.
http://www.maxim-ic.com/quick_view2.cfm/qv_pk/3149/t/al
You can get the PCB made for dirt cheap (no need for a 100+ board run for personal stuff) http://www.batchpcb.com/
Also check out the parent company of Batch PCB... www.sparkfun.com It's a really awesome site.
(01-21-2009, 02:55 PM)winmutt I don't understand why I can't use it as a thermistor as it is providing a change in resistance
If it was providing a change in resistance you would apply a voltage and measure the voltage drop using a voltage divider. All you do with a thermocouple is measure the voltage. You don't actually apply any at all. The thermocouple actually generates its own voltage due to the contact with two different metals.
This post was last modified: 01-30-2009, 03:27 PM by Tymbrymi.
John Robbins
Tymbrymi
John Robbins
Messages In This Thread
Electronic variable vane control - by winmutt - 01-08-2009, 05:47 PM
RE: Electronic doodads - by winmutt - 01-08-2009, 06:13 PM
RE: Electronic doodads - by Gross Polluter - 01-09-2009, 02:22 AM
RE: Electronic doodads - by ForcedInduction - 01-09-2009, 04:03 AM
RE: Electronic doodads - by winmutt - 01-09-2009, 08:10 AM
RE: Electronic doodads - by winmutt - 01-09-2009, 09:11 AM
RE: Electronic doodads - by Gross Polluter - 01-09-2009, 09:41 AM
RE: Electronic doodads - by GREASY_BEAST - 01-09-2009, 10:54 AM
RE: Electronic doodads - by winmutt - 01-09-2009, 11:05 AM
RE: Electronic doodads - by GREASY_BEAST - 01-09-2009, 01:10 PM
RE: Electronic doodads - by winmutt - 01-09-2009, 02:55 PM
RE: Electronic doodads - by oel_brenner - 01-10-2009, 01:02 PM
RE: Electronic doodads - by GREASY_BEAST - 01-11-2009, 12:45 PM
RE: Electronic doodads - by tantank79 - 01-12-2009, 01:21 AM
RE: Electronic doodads - by Telecommbrkr - 01-11-2009, 10:37 PM
RE: Electronic doodads - by winmutt - 01-12-2009, 10:20 AM
RE: Electronic doodads - by ForcedInduction - 01-12-2009, 02:01 AM
RE: Electronic doodads - by oel_brenner - 01-12-2009, 07:56 PM
RE: Electronic doodads - by winmutt - 01-12-2009, 08:49 PM
RE: Electronic doodads - by oel_brenner - 01-12-2009, 09:03 PM
RE: Electronic doodads - by winmutt - 01-12-2009, 09:40 PM
RE: Electronic doodads - by GREASY_BEAST - 01-14-2009, 03:05 PM
RE: Electronic doodads - by oel_brenner - 01-14-2009, 11:41 PM
RE: Electronic doodads - by Gross Polluter - 01-15-2009, 01:57 AM
RE: Electronic doodads - by Tymbrymi - 01-30-2009, 01:54 PM
RE: Electronic doodads - by winmutt - 01-14-2009, 05:21 PM
RE: Electronic doodads - by winmutt - 01-15-2009, 10:06 AM
RE: Electronic doodads - by winmutt - 01-20-2009, 10:29 PM
RE: Electronic doodads - by winmutt - 01-20-2009, 11:16 PM
RE: Electronic doodads - by winmutt - 01-21-2009, 02:55 PM
RE: Electronic doodads - by cannonballSDL - 01-25-2009, 04:02 AM
RE: Electronic doodads - by winmutt - 01-26-2009, 10:37 AM
RE: Electronic doodads - by winmutt - 01-30-2009, 02:08 PM
RE: Electronic doodads - by Tymbrymi - 01-30-2009, 02:47 PM
RE: Electronic doodads - by ForcedInduction - 03-17-2009, 07:25 PM
RE: Electronic doodads - by Tymbrymi - 03-18-2009, 07:51 AM
RE: Electronic doodads - by ForcedInduction - 03-18-2009, 07:59 AM
RE: Electronic doodads - by GREASY_BEAST - 03-18-2009, 09:13 AM
RE: Electronic doodads - by Tymbrymi - 03-19-2009, 08:36 AM
RE: Electronic doodads - by GREASY_BEAST - 03-19-2009, 11:45 AM
RE: Electronic doodads - by GREASY_BEAST - 03-21-2009, 09:54 AM
RE: Electronic doodads - by Tymbrymi - 03-23-2009, 07:40 AM
RE: Electronic doodads - by GREASY_BEAST - 03-23-2009, 10:41 AM
RE: Electronic doodads - by winmutt - 03-17-2009, 07:41 PM
RE: Electronic doodads - by ForcedInduction - 03-17-2009, 07:44 PM
RE: Electronic doodads - by winmutt - 03-17-2009, 07:47 PM
RE: Electronic doodads - by winmutt - 03-18-2009, 03:02 PM
RE: Electronic doodads - by 300SD81 - 03-23-2009, 10:10 AM
RE: Electronic doodads - by Tymbrymi - 03-25-2009, 08:17 AM
RE: Electronic doodads - by 300SD81 - 03-23-2009, 06:45 PM
RE: Electronic doodads - by winmutt - 03-24-2009, 10:08 AM
RE: Electronic doodads - by Gross Polluter - 03-24-2009, 02:54 PM
RE: Electronic doodads - by winmutt - 09-04-2009, 10:31 AM
RE: Electronic doodads - by 300SD81 - 03-29-2009, 11:53 AM
RE: Electronic doodads - by 300SD81 - 04-09-2009, 10:23 AM
RE: Electronic doodads - by oel_brenner - 04-20-2009, 10:54 PM
RE: Electronic doodads - by 300SD81 - 04-20-2009, 11:40 PM
RE: Electronic doodads - by ForcedInduction - 04-21-2009, 05:45 PM
RE: Electronic doodads - by oel_brenner - 04-21-2009, 10:06 PM
RE: Electronic doodads - by oel_brenner - 04-29-2009, 10:41 PM
RE: Electronic doodads - by oel_brenner - 04-30-2009, 10:48 PM
RE: Electronic doodads - by Gross Polluter - 06-05-2009, 03:55 PM
RE: Electronic doodads - by winmutt - 09-03-2009, 01:27 PM
RE: Electronic doodads - by Tymbrymi - 09-03-2009, 01:36 PM
RE: Electronic doodads - by winmutt - 09-03-2009, 02:25 PM
RE: Electronic doodads - by tomnik - 09-04-2009, 06:15 AM
RE: Electronic variable vane control - by winmutt - 09-04-2009, 08:27 AM
RE: Electronic variable vane control - by Tymbrymi - 09-04-2009, 01:33 PM
RE: Electronic variable vane control - by winmutt - 09-04-2009, 03:21 PM
RE: Electronic variable vane control - by winmutt - 01-22-2011, 10:21 PM
RE: Electronic variable vane control - by aaa - 01-22-2011, 10:53 PM
RE: Electronic variable vane control - by winmutt - 01-22-2011, 11:38 PM
RE: Electronic variable vane control - by Spaceraver - 01-23-2011, 12:08 PM
RE: Electronic variable vane control - by winmutt - 01-23-2011, 03:55 PM
RE: Electronic variable vane control - by winmutt - 01-24-2011, 09:25 AM
RE: Electronic variable vane control - by aaa - 01-24-2011, 05:04 PM
RE: Electronic variable vane control - by Spaceraver - 01-25-2011, 04:53 AM
RE: Electronic variable vane control - by winmutt - 01-25-2011, 09:40 AM
RE: Electronic variable vane control - by 300D50 - 01-25-2011, 12:01 PM
RE: Electronic variable vane control - by winmutt - 01-25-2011, 05:45 PM
RE: Electronic variable vane control - by MTUPower - 01-25-2011, 07:15 PM
RE: Electronic variable vane control - by aaa - 01-25-2011, 07:21 PM
RE: Electronic variable vane control - by winmutt - 01-26-2011, 06:28 PM
RE: Electronic variable vane control - by tomnik - 01-27-2011, 12:45 AM
RE: Electronic variable vane control - by Syncro_G - 01-27-2011, 10:17 AM
RE: Electronic variable vane control - by 300D50 - 01-27-2011, 10:43 AM
RE: Electronic variable vane control - by aaa - 02-01-2011, 08:01 PM
RE: Electronic variable vane control - by winmutt - 03-04-2011, 09:38 PM
RE: Electronic variable vane control - by 300D50 - 03-04-2011, 11:45 PM
RE: Electronic variable vane control - by winmutt - 03-07-2011, 10:14 AM
RE: Electronic variable vane control - by 300D50 - 03-07-2011, 02:46 PM
