STD Tuning Engine OM603 semi-super pump testing, fitted with Bosch 6.0mm elements
jeemu
457
12-25-2010, 04:57 AM #14
(12-25-2010, 04:41 AM)diesel_fitter
(12-25-2010, 04:23 AM)jeemu My friend test 6mm elements on om603 with Garrett GT32 he get 232hp/415nm. This was 2007.
Awesome Jeemu. Thanks for posting! Can you comment on the spool?
No, just remember at he say it spools wery fast.
He used 1.7bar boost. max hp/4300rpm and max nm/2800rpm
jeemu
Messages In This Thread
OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by gsxr - 12-22-2010, 01:07 PM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by winmutt - 12-22-2010, 01:26 PM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by E300TSC - 12-23-2010, 05:22 PM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by winmutt - 12-29-2010, 09:38 PM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by jonbobshinigin - 12-23-2010, 03:23 PM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by gsxr - 12-23-2010, 03:50 PM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by tomnik - 12-24-2010, 02:23 AM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by ForcedInduction - 12-24-2010, 08:55 AM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by 300D50 - 12-23-2010, 06:27 PM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by gsxr - 12-24-2010, 03:56 PM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by George3soccer - 12-24-2010, 08:09 PM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by gsxr - 12-24-2010, 09:52 PM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by jeemu - 12-25-2010, 04:23 AM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by diesel_fitter - 12-25-2010, 04:41 AM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by jeemu - 12-25-2010, 04:57 AM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by diesel_fitter - 12-25-2010, 05:18 AM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by gsxr - 12-25-2010, 11:51 AM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by MJF - 12-25-2010, 12:26 PM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by gsxr - 12-26-2010, 04:30 PM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by George3soccer - 12-26-2010, 03:11 PM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by MJF - 12-26-2010, 05:13 PM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by jeemu - 12-26-2010, 05:33 PM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by MJF - 12-26-2010, 06:17 PM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by jonbobshinigin - 12-30-2010, 05:18 PM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by gsxr - 12-30-2010, 06:20 PM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by jonbobshinigin - 12-30-2010, 07:45 PM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by tomnik - 12-31-2010, 01:49 AM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by willbhere4u - 12-31-2010, 11:05 AM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by gsxr - 03-01-2011, 10:40 PM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by gsxr - 03-05-2011, 04:17 PM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by E300TSC - 03-05-2011, 10:18 PM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by gsxr - 03-08-2011, 04:47 PM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by babymog - 03-18-2011, 10:32 AM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by E300TSC - 03-18-2011, 12:05 PM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by babymog - 03-18-2011, 01:33 PM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by E300TSC - 03-18-2011, 09:42 PM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by gsxr - 03-18-2011, 09:53 PM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by E300TSC - 03-18-2011, 09:57 PM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by tomnik - 03-19-2011, 01:08 AM
