STD Tuning Engine OM603 semi-super pump testing, fitted with Bosch 6.0mm elements
tomnik
12-24-2010, 02:23 AM #7
(12-23-2010, 03:50 PM)gsxr I'm still trying to wrap my head around why boost wouldn't build when I adjusted the setscrew in 1 turn too far. I'd have thought that if the wastegate was stuck closed, it would build boost (off idle) just as fast, not slower. ?????
Tongue
stuck open?
Tom
tomnik
Tongue
stuck open?
Tom
Messages In This Thread
OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by gsxr - 12-22-2010, 01:07 PM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by winmutt - 12-22-2010, 01:26 PM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by E300TSC - 12-23-2010, 05:22 PM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by winmutt - 12-29-2010, 09:38 PM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by jonbobshinigin - 12-23-2010, 03:23 PM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by gsxr - 12-23-2010, 03:50 PM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by tomnik - 12-24-2010, 02:23 AM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by ForcedInduction - 12-24-2010, 08:55 AM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by 300D50 - 12-23-2010, 06:27 PM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by gsxr - 12-24-2010, 03:56 PM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by George3soccer - 12-24-2010, 08:09 PM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by gsxr - 12-24-2010, 09:52 PM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by jeemu - 12-25-2010, 04:23 AM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by diesel_fitter - 12-25-2010, 04:41 AM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by jeemu - 12-25-2010, 04:57 AM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by diesel_fitter - 12-25-2010, 05:18 AM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by gsxr - 12-25-2010, 11:51 AM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by MJF - 12-25-2010, 12:26 PM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by gsxr - 12-26-2010, 04:30 PM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by George3soccer - 12-26-2010, 03:11 PM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by MJF - 12-26-2010, 05:13 PM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by jeemu - 12-26-2010, 05:33 PM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by MJF - 12-26-2010, 06:17 PM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by jonbobshinigin - 12-30-2010, 05:18 PM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by gsxr - 12-30-2010, 06:20 PM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by jonbobshinigin - 12-30-2010, 07:45 PM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by tomnik - 12-31-2010, 01:49 AM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by willbhere4u - 12-31-2010, 11:05 AM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by gsxr - 03-01-2011, 10:40 PM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by gsxr - 03-05-2011, 04:17 PM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by E300TSC - 03-05-2011, 10:18 PM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by gsxr - 03-08-2011, 04:47 PM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by babymog - 03-18-2011, 10:32 AM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by E300TSC - 03-18-2011, 12:05 PM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by babymog - 03-18-2011, 01:33 PM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by E300TSC - 03-18-2011, 09:42 PM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by gsxr - 03-18-2011, 09:53 PM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by E300TSC - 03-18-2011, 09:57 PM
RE: OM603 semi-super pump testing, fitted with Bosch 6.0mm elements - by tomnik - 03-19-2011, 01:08 AM
