STD Other Projects Turbo 616 powered Astro Van build
  • 5 Vote(s) - 4.2 Average
12-20-2010, 08:03 AM #30
(12-19-2010, 09:36 PM)300D50 Leme know if you need help with the remote filter, seems like it's easy enough to do. Smile
As for flywheel hitting fasteners, just shave down the heads a bit as needed with a grinder/lathe.
All in all, looks like you're going good so far.
I might be able to space the oil filter straight out from the block to provide the clearance needed, depends on the room inside the hatch. I have a feeling the oil filter might not work like that. Thanks for the offer, I might take you up on that depending on how I resolve this.
I want to make sure that the flywheel is at the correct depth in relation to the adapter plate, different fastners would work, and also I can probably use an extra exterior mounting ring on the inside of the flywheel to space it out a bit. Dont think it will be too bad to deal with, hopefully with minimal work.
Messages In This Thread
Turbo 616 powered Astro Van build - by dropnosky - 11-07-2010, 01:57 PM
RE: Turbo 616 powered Astro Van build - by 300D50 - 11-07-2010, 02:45 PM
RE: Turbo 616 powered Astro Van build - by mike-81-240d - 11-07-2010, 02:49 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 11-07-2010, 04:34 PM
RE: Turbo 616 powered Astro Van build - by 300D50 - 11-07-2010, 04:52 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 11-07-2010, 05:00 PM
RE: Turbo 616 powered Astro Van build - by ben2go - 11-07-2010, 05:04 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 11-07-2010, 05:10 PM
RE: Turbo 616 powered Astro Van build - by 300D50 - 11-07-2010, 05:14 PM
RE: Turbo 616 powered Astro Van build - by DeliveryValve - 11-07-2010, 09:22 PM
RE: Turbo 616 powered Astro Van build - by ben2go - 11-07-2010, 11:27 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 11-24-2010, 02:45 PM
RE: Turbo 616 powered Astro Van build - by ben2go - 11-24-2010, 03:27 PM
RE: Turbo 616 powered Astro Van build - by 300D50 - 11-24-2010, 06:40 PM
RE: Turbo 616 powered Astro Van build - by ben2go - 11-25-2010, 12:03 AM
RE: Turbo 616 powered Astro Van build - by willbhere4u - 11-25-2010, 12:08 AM
RE: Turbo 616 powered Astro Van build - by 300D50 - 11-25-2010, 12:47 AM
RE: Turbo 616 powered Astro Van build - by dropnosky - 11-26-2010, 10:45 PM
RE: Turbo 616 powered Astro Van build - by 300D50 - 11-26-2010, 10:54 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 11-29-2010, 09:24 AM
RE: Turbo 616 powered Astro Van build - by 300D50 - 11-29-2010, 12:58 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 11-30-2010, 09:44 PM
RE: Turbo 616 powered Astro Van build - by 300D50 - 11-30-2010, 09:49 PM
RE: Turbo 616 powered Astro Van build - by Captain America - 11-30-2010, 04:45 PM
RE: Turbo 616 powered Astro Van build - by 300D50 - 12-05-2010, 07:05 AM
RE: Turbo 616 powered Astro Van build - by dropnosky - 12-05-2010, 08:02 AM
RE: Turbo 616 powered Astro Van build - by 300D50 - 12-05-2010, 03:06 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 12-19-2010, 09:05 PM
RE: Turbo 616 powered Astro Van build - by 300D50 - 12-19-2010, 09:36 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 12-20-2010, 08:03 AM
RE: Turbo 616 powered Astro Van build - by Diesel-Wiking - 12-21-2010, 02:53 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 12-23-2010, 12:06 PM
RE: Turbo 616 powered Astro Van build - by ben2go - 12-21-2010, 02:58 PM
RE: Turbo 616 powered Astro Van build - by ben2go - 12-23-2010, 05:35 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 12-24-2010, 06:19 PM
RE: Turbo 616 powered Astro Van build - by ben2go - 12-24-2010, 10:08 PM
RE: Turbo 616 powered Astro Van build - by garage - 02-26-2011, 03:43 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 02-28-2011, 09:01 AM
RE: Turbo 616 powered Astro Van build - by willbhere4u - 02-28-2011, 11:45 AM
RE: Turbo 616 powered Astro Van build - by dropnosky - 02-28-2011, 12:50 PM
RE: Turbo 616 powered Astro Van build - by garage - 02-28-2011, 03:38 PM
RE: Turbo 616 powered Astro Van build - by willbhere4u - 02-28-2011, 01:21 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 05-06-2011, 05:41 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 07-06-2011, 11:00 AM
RE: Turbo 616 powered Astro Van build - by ben2go - 07-06-2011, 07:08 PM
RE: Turbo 616 powered Astro Van build - by srbsmartie - 09-08-2011, 10:12 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 09-09-2011, 08:28 AM
RE: Turbo 616 powered Astro Van build - by dropnosky - 10-03-2011, 03:21 PM
RE: Turbo 616 powered Astro Van build - by DeliveryValve - 10-03-2011, 07:14 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 10-05-2011, 04:37 PM
RE: Turbo 616 powered Astro Van build - by DeliveryValve - 10-05-2011, 06:43 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 10-05-2011, 07:33 PM
RE: Turbo 616 powered Astro Van build - by DeliveryValve - 10-06-2011, 10:48 AM
RE: Turbo 616 powered Astro Van build - by ben2go - 10-03-2011, 05:20 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 10-03-2011, 06:31 PM
RE: Turbo 616 powered Astro Van build - by Purplecomputer - 10-06-2011, 10:40 AM
RE: Turbo 616 powered Astro Van build - by dropnosky - 10-06-2011, 10:54 AM
RE: Turbo 616 powered Astro Van build - by DeliveryValve - 10-06-2011, 11:23 AM
RE: Turbo 616 powered Astro Van build - by Purplecomputer - 10-06-2011, 05:46 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 10-06-2011, 06:38 PM
RE: Turbo 616 powered Astro Van build - by yankneck696 - 10-06-2011, 07:41 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 10-25-2011, 10:20 AM
RE: Turbo 616 powered Astro Van build - by Purplecomputer - 10-25-2011, 10:38 AM
RE: Turbo 616 powered Astro Van build - by dropnosky - 10-25-2011, 10:50 AM
RE: Turbo 616 powered Astro Van build - by 300D50 - 10-25-2011, 03:26 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 10-25-2011, 03:33 PM
RE: Turbo 616 powered Astro Van build - by 300D50 - 10-25-2011, 03:36 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 10-28-2011, 08:41 PM
RE: Turbo 616 powered Astro Van build - by OM616 - 12-30-2011, 04:50 PM
RE: Turbo 616 powered Astro Van build - by DeliveryValve - 10-28-2011, 09:01 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 10-28-2011, 09:23 PM
RE: Turbo 616 powered Astro Van build - by DeliveryValve - 10-29-2011, 01:01 AM
RE: Turbo 616 powered Astro Van build - by dropnosky - 10-29-2011, 08:07 AM
RE: Turbo 616 powered Astro Van build - by willbhere4u - 10-29-2011, 11:09 AM
RE: Turbo 616 powered Astro Van build - by dropnosky - 10-31-2011, 07:20 AM
RE: Turbo 616 powered Astro Van build - by willbhere4u - 10-31-2011, 10:31 AM
RE: Turbo 616 powered Astro Van build - by yankneck696 - 10-31-2011, 03:15 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 10-31-2011, 03:32 PM
RE: Turbo 616 powered Astro Van build - by DeliveryValve - 11-01-2011, 03:52 AM
RE: Turbo 616 powered Astro Van build - by dropnosky - 11-02-2011, 02:40 PM
RE: Turbo 616 powered Astro Van build - by yankneck696 - 11-02-2011, 05:21 PM
RE: Turbo 616 powered Astro Van build - by ben2go - 11-02-2011, 06:41 PM
RE: Turbo 616 powered Astro Van build - by dropnosky - 11-09-2011, 06:27 PM
RE: Turbo 616 powered Astro Van build - by Purplecomputer - 11-09-2011, 09:01 PM
RE: Turbo 616 powered Astro Van build - by Captain America - 11-14-2011, 01:26 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 02-13-2012, 09:20 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 06-15-2012, 10:06 AM
RE: Turbo 616 powered Astro Van build - by Purplecomputer - 06-15-2012, 10:34 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 06-15-2012, 02:12 PM
RE: Turbo 616 powered Astro Van build - by Purplecomputer - 06-15-2012, 05:14 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 06-27-2012, 10:47 AM
RE: Turbo 616 powered Astro Van build - by aaa - 06-27-2012, 11:21 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 06-27-2012, 11:31 AM
RE: Turbo 616 powered Astro Van build - by aaa - 06-27-2012, 11:40 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 06-27-2012, 02:09 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 06-27-2012, 01:36 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 09-26-2012, 01:28 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 09-26-2012, 01:56 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-27-2012, 04:27 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 01-16-2013, 11:30 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 01-16-2013, 12:48 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 01-16-2013, 03:44 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 01-17-2013, 04:19 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 01-31-2013, 04:32 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 02-14-2013, 05:49 PM
RE: Turbo 616 powered Astro Van build - by aaa - 02-15-2013, 09:27 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 02-15-2013, 10:51 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 02-15-2013, 10:07 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 02-15-2013, 11:17 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 02-15-2013, 11:36 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 02-15-2013, 12:44 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 02-15-2013, 02:22 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 02-15-2013, 03:42 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 02-15-2013, 04:03 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 03-15-2013, 04:56 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 03-21-2013, 08:53 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 04-04-2013, 06:34 PM
RE: Turbo 616 powered Astro Van build - by DeliveryValve - 04-05-2013, 01:12 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 04-05-2013, 07:59 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 04-05-2013, 08:10 AM
RE: Turbo 616 powered Astro Van build - by Ksteen2 - 04-05-2013, 09:04 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 04-05-2013, 09:12 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 04-05-2013, 09:18 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 04-05-2013, 11:45 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 04-05-2013, 03:46 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 04-12-2013, 08:27 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 04-12-2013, 09:00 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 04-12-2013, 09:07 AM
RE: Turbo 616 powered Astro Van build - by DeliveryValve - 04-12-2013, 09:45 AM
RE: Turbo 616 powered Astro Van build - by ben2go - 04-12-2013, 10:23 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 04-13-2013, 02:31 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 04-13-2013, 05:24 PM
RE: Turbo 616 powered Astro Van build - by DeliveryValve - 04-13-2013, 05:42 PM
RE: Turbo 616 powered Astro Van build - by ben2go - 04-13-2013, 10:21 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 04-15-2013, 05:54 AM
RE: Turbo 616 powered Astro Van build - by DeliveryValve - 04-15-2013, 10:47 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 04-15-2013, 11:01 AM
RE: Turbo 616 powered Astro Van build - by DeliveryValve - 04-15-2013, 11:19 AM
RE: Turbo 616 powered Astro Van build - by maxypriest - 04-15-2013, 12:25 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 04-17-2013, 03:14 PM
RE: Turbo 616 powered Astro Van build - by willbhere4u - 04-17-2013, 03:29 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 04-17-2013, 03:35 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 04-18-2013, 08:38 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 04-18-2013, 01:54 PM
RE: Turbo 616 powered Astro Van build - by Purplecomputer - 04-18-2013, 08:42 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 04-19-2013, 06:00 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 04-20-2013, 05:16 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 04-22-2013, 03:03 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 04-22-2013, 03:51 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 04-23-2013, 08:23 AM
RE: Turbo 616 powered Astro Van build - by raysorenson - 04-23-2013, 10:47 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 04-27-2013, 10:15 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 05-17-2013, 08:28 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 05-21-2013, 02:25 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 05-21-2013, 03:23 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 05-22-2013, 05:49 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 05-22-2013, 06:50 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 05-23-2013, 05:23 PM
RE: Turbo 616 powered Astro Van build - by MFSuper90 - 05-22-2013, 08:49 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 05-23-2013, 08:11 AM
RE: Turbo 616 powered Astro Van build - by waz - 05-23-2013, 09:44 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 05-23-2013, 10:12 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 05-24-2013, 05:01 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 05-29-2013, 09:52 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 05-29-2013, 10:30 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 05-29-2013, 01:29 PM
RE: Turbo 616 powered Astro Van build - by DeliveryValve - 05-29-2013, 11:51 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 05-29-2013, 02:25 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 05-29-2013, 05:06 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 05-29-2013, 08:24 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 05-31-2013, 10:41 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 05-31-2013, 11:51 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 06-06-2013, 12:35 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 06-06-2013, 03:09 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 06-11-2013, 05:14 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 06-18-2013, 05:42 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 06-19-2013, 05:12 PM
RE: Turbo 616 powered Astro Van build - by maxypriest - 06-21-2013, 07:37 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 06-22-2013, 05:00 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 06-22-2013, 07:56 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 06-22-2013, 08:25 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 06-26-2013, 03:17 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 06-27-2013, 04:49 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 06-27-2013, 10:21 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 07-02-2013, 10:08 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 07-02-2013, 10:52 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 07-02-2013, 03:28 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 07-03-2013, 10:51 AM
RE: Turbo 616 powered Astro Van build - by OM616 - 07-04-2013, 02:19 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 07-04-2013, 02:33 PM
RE: Turbo 616 powered Astro Van build - by OM616 - 07-04-2013, 04:35 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 07-05-2013, 09:41 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 07-11-2013, 03:10 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 07-11-2013, 04:36 PM
RE: Turbo 616 powered Astro Van build - by Purplecomputer - 07-12-2013, 01:10 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 07-15-2013, 04:42 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 07-16-2013, 06:47 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 07-17-2013, 08:53 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 07-17-2013, 08:56 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 07-18-2013, 10:17 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 07-19-2013, 10:15 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 07-24-2013, 06:05 AM
RE: Turbo 616 powered Astro Van build - by Purplecomputer - 07-24-2013, 11:22 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 07-24-2013, 08:03 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 07-25-2013, 10:19 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 08-07-2013, 10:44 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 08-07-2013, 12:17 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 08-07-2013, 12:43 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 08-07-2013, 02:10 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 08-14-2013, 06:55 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 08-15-2013, 10:08 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 08-15-2013, 02:01 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 08-15-2013, 03:20 PM
RE: Turbo 616 powered Astro Van build - by DeliveryValve - 08-16-2013, 01:39 AM
RE: Turbo 616 powered Astro Van build - by Ksteen2 - 08-16-2013, 02:33 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 08-16-2013, 07:17 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 08-16-2013, 07:51 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 08-16-2013, 08:29 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 08-22-2013, 11:32 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 08-22-2013, 01:47 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 08-22-2013, 05:27 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 08-28-2013, 08:44 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 08-28-2013, 09:35 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 08-28-2013, 12:00 PM
RE: Turbo 616 powered Astro Van build - by Ksteen2 - 09-04-2013, 03:12 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 09-04-2013, 08:10 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 09-04-2013, 02:41 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 10-10-2013, 07:55 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 10-22-2013, 08:44 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 10-22-2013, 12:50 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 11-25-2013, 09:40 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 11-25-2013, 06:00 PM
RE: Turbo 616 powered Astro Van build - by willbhere4u - 11-26-2013, 11:31 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-03-2013, 05:18 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-05-2013, 09:34 AM
RE: Turbo 616 powered Astro Van build - by Purplecomputer - 12-05-2013, 09:43 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-05-2013, 11:52 AM
RE: Turbo 616 powered Astro Van build - by willbhere4u - 12-05-2013, 12:14 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-05-2013, 01:27 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-05-2013, 04:39 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 12-05-2013, 04:50 PM
RE: Turbo 616 powered Astro Van build - by willbhere4u - 12-05-2013, 04:52 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-05-2013, 04:59 PM
RE: Turbo 616 powered Astro Van build - by willbhere4u - 12-05-2013, 05:21 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-05-2013, 05:58 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-06-2013, 07:02 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-07-2013, 05:41 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-08-2013, 05:02 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-09-2013, 06:03 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-10-2013, 02:22 PM
RE: Turbo 616 powered Astro Van build - by willbhere4u - 12-10-2013, 05:24 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-11-2013, 10:12 AM
RE: Turbo 616 powered Astro Van build - by Tito - 12-11-2013, 12:54 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 12-11-2013, 01:12 PM
RE: Turbo 616 powered Astro Van build - by Tito - 12-11-2013, 01:22 PM
RE: Turbo 616 powered Astro Van build - by Jooseppi Luna - 12-11-2013, 02:42 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-11-2013, 02:43 PM
RE: Turbo 616 powered Astro Van build - by Tito - 12-11-2013, 03:17 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-11-2013, 03:23 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-11-2013, 05:53 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-12-2013, 06:11 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 12-12-2013, 07:39 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-12-2013, 09:25 PM
RE: Turbo 616 powered Astro Van build - by willbhere4u - 12-13-2013, 10:22 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-13-2013, 12:29 PM
RE: Turbo 616 powered Astro Van build - by willbhere4u - 12-13-2013, 06:17 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-18-2013, 03:19 PM
RE: Turbo 616 powered Astro Van build - by willbhere4u - 12-18-2013, 03:57 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-19-2013, 09:47 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 12-19-2013, 10:28 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-21-2013, 05:07 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-23-2013, 01:54 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 12-26-2013, 01:37 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 01-06-2014, 02:21 PM
RE: Turbo 616 powered Astro Van build - by Jooseppi Luna - 01-06-2014, 03:23 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 01-06-2014, 01:38 PM
RE: Turbo 616 powered Astro Van build - by willbhere4u - 01-06-2014, 05:27 PM
RE: Turbo 616 powered Astro Van build - by Jooseppi Luna - 01-06-2014, 06:48 PM
RE: Turbo 616 powered Astro Van build - by willbhere4u - 01-07-2014, 12:10 PM
RE: Turbo 616 powered Astro Van build - by Purplecomputer - 01-09-2014, 10:49 AM
RE: Turbo 616 powered Astro Van build - by ben2go - 01-29-2014, 04:06 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 01-25-2014, 05:56 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 01-28-2014, 04:45 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 01-29-2014, 10:30 AM
RE: Turbo 616 powered Astro Van build - by Austincarnut - 01-29-2014, 10:46 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 01-29-2014, 10:48 AM
RE: Turbo 616 powered Astro Van build - by JB3 - 01-29-2014, 01:01 PM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 01-29-2014, 01:52 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 01-30-2014, 09:31 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 01-30-2014, 09:52 AM
RE: Turbo 616 powered Astro Van build - by willbhere4u - 01-29-2014, 02:07 PM
RE: Turbo 616 powered Astro Van build - by willbhere4u - 01-29-2014, 04:36 PM
RE: Turbo 616 powered Astro Van build - by ben2go - 01-29-2014, 10:25 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 01-30-2014, 05:01 PM
RE: Turbo 616 powered Astro Van build - by willbhere4u - 01-31-2014, 10:44 AM
RE: Turbo 616 powered Astro Van build - by _siim_ - 01-31-2014, 02:07 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 08-22-2014, 08:49 AM
RE: Turbo 616 powered Astro Van build - by Simpler=Better - 08-22-2014, 12:01 PM
RE: Turbo 616 powered Astro Van build - by turbojeep - 02-16-2015, 11:37 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 02-19-2015, 02:12 PM
RE: Turbo 616 powered Astro Van build - by Greazzer - 02-19-2015, 09:58 PM
RE: Turbo 616 powered Astro Van build - by Purplecomputer - 02-23-2015, 10:07 AM
RE: Turbo 616 powered Astro Van build - by turbojeep - 02-23-2015, 09:14 PM
RE: Turbo 616 powered Astro Van build - by JB3 - 03-01-2015, 01:38 PM
 8 Guest(s)
 8 Guest(s)
