STD Tuning Engine Garrett 712120 VNT Hella 6NW 008 412 actuator.
  • 2 Vote(s) - 5 Average
Biohazard
Smokin like a champ!
376
12-01-2010, 10:53 AM #87
(11-05-2009, 10:32 AM)Tymbrymi
(11-03-2009, 04:01 PM)300SD81 I think this is the basic idea of how the code is gonna work:
1. try to maintain X psi of boost
if boost > X, open vanes unless fully opened
if boost < X, close unless fully closed
2. if exhaust pressure too high, open vanes even if boost < X
3. if egt too high, fully open vanes, sound alarm
For optimal fuel economy, and if you have gobs of free time, the ideal thing to do would be to calculate engine load and only generate enough boost needed for that load. That would require LOTS of tuning though.
Ok, so I am about as new to coding/computer control stuff as you can get (playing with Parallax BasicStamp board), but this has me about 13 different ways of excited! I know I'm quoting an older post, but this may be relevant. Innovate has just released a wideband O2 kit that is programable for use with diesel.
http://www.innovatemotorsports.com/products/MTXL.php
Think it would be possible to use the 0-1v or 0-5v output from the gauge to help control vane position (airflow) based on an actual AFR/engine load? For example, use the 0-5v gauge output to tell the computer to tell the actuator to increase airflow when it's rich, and decrease airflow when it's lean. You could set it to just about any AFR you want if I'm not mistaken; or even different AFR for different conditions. Cruise at a very lean AFR and set a slightly richer AFR for WOT?
Biohazard
Messages In This Thread
Garrett 712120 VNT Hella 6NW 008 412 actuator. - by tomnik - 08-18-2009, 09:13 AM
RE: electronic actuator? - by Tymbrymi - 08-25-2009, 01:15 PM
RE: electronic actuator? - by tomnik - 08-27-2009, 07:15 AM
RE: electronic actuator? - by winmutt - 09-01-2009, 09:01 AM
RE: electronic actuator? - by Tymbrymi - 09-01-2009, 09:28 AM
RE: electronic actuator? - by winmutt - 09-01-2009, 03:51 PM
RE: electronic actuator? - by tomnik - 09-01-2009, 09:49 AM
RE: electronic actuator? - by Tymbrymi - 09-03-2009, 08:31 AM
RE: electronic actuator? - by winmutt - 09-03-2009, 01:18 PM
RE: electronic actuator? - by Tymbrymi - 09-03-2009, 01:32 PM
RE: electronic actuator? - by winmutt - 09-03-2009, 02:23 PM
RE: Garrett VNT Hella actuator. - by winmutt - 09-04-2009, 08:21 AM
RE: Garrett VNT Hella actuator. - by Tymbrymi - 09-04-2009, 11:30 AM
RE: Garrett VNT Hella actuator. - by winmutt - 09-04-2009, 03:17 PM
RE: Garrett VNT Hella actuator. - by winmutt - 09-04-2009, 12:29 PM
RE: Garrett VNT Hella actuator. - by Tymbrymi - 09-04-2009, 01:36 PM
RE: Garrett VNT Hella actuator. - by winmutt - 09-05-2009, 10:26 AM
RE: Garrett VNT Hella actuator. - by Tymbrymi - 09-05-2009, 10:14 PM
RE: Garrett VNT Hella actuator. - by winmutt - 10-22-2009, 11:22 PM
RE: Garrett VNT Hella actuator. - by Tymbrymi - 10-23-2009, 09:55 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 09-05-2009, 10:49 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 09-08-2009, 10:12 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 09-08-2009, 02:21 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Tymbrymi - 09-09-2009, 08:38 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 09-09-2009, 10:28 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 09-10-2009, 08:02 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by ForcedInduction - 09-14-2009, 04:09 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 10-19-2009, 02:29 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 10-20-2009, 10:51 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 10-23-2009, 01:41 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Tymbrymi - 10-23-2009, 03:51 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 10-27-2009, 08:42 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Tymbrymi - 10-28-2009, 09:48 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 10-28-2009, 10:34 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 10-27-2009, 11:36 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 10-29-2009, 12:21 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Tymbrymi - 10-29-2009, 02:12 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 10-29-2009, 05:01 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 10-29-2009, 12:38 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 10-29-2009, 02:06 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by piledriver - 10-29-2009, 08:07 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Tymbrymi - 10-29-2009, 09:29 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 10-30-2009, 08:25 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 11-02-2009, 11:25 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 11-03-2009, 03:48 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 11-03-2009, 04:01 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Tymbrymi - 11-05-2009, 10:32 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 11-04-2009, 04:53 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 11-04-2009, 09:36 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 11-05-2009, 12:26 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 11-05-2009, 01:38 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 11-06-2009, 04:22 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by muuris - 01-12-2010, 10:58 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 01-12-2010, 04:07 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by muuris - 01-13-2010, 05:39 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 11-08-2009, 03:40 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 11-09-2009, 02:40 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 11-14-2009, 05:00 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by cell - 11-19-2009, 03:35 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 11-21-2009, 03:32 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by ForcedInduction - 11-21-2009, 05:01 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by nockter - 12-05-2009, 01:40 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 12-07-2009, 02:08 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by lars - 12-08-2009, 05:25 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 12-08-2009, 11:21 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 12-08-2009, 07:19 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 12-14-2009, 03:28 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 01-12-2010, 04:45 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by kmaser - 01-12-2010, 05:52 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by cell - 01-23-2010, 08:09 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Kiwibacon - 01-23-2010, 08:23 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by cell - 01-23-2010, 08:25 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 01-26-2010, 04:02 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by ForcedInduction - 02-07-2010, 07:25 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 02-08-2010, 10:41 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by ForcedInduction - 02-11-2010, 02:13 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 02-18-2010, 10:36 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by cell - 02-19-2010, 01:30 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 03-30-2010, 01:19 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by racerxoffl - 10-19-2010, 11:39 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by TB206HDI - 09-23-2010, 02:56 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by dgn555 - 09-23-2010, 02:24 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 09-23-2010, 03:05 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by dgn555 - 10-03-2010, 06:53 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Darqs - 12-01-2010, 03:46 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 12-01-2010, 10:39 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Darqs - 12-02-2010, 02:58 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Tymbrymi - 12-02-2010, 07:48 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Darqs - 12-02-2010, 09:07 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 12-02-2010, 10:03 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Tymbrymi - 12-02-2010, 12:31 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Darqs - 12-08-2010, 06:31 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Biohazard - 12-01-2010, 10:53 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Biohazard - 12-06-2010, 01:32 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Captain America - 12-07-2010, 04:07 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 12-08-2010, 10:25 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Darqs - 12-09-2010, 02:24 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 12-09-2010, 11:32 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Darqs - 12-15-2010, 03:22 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 12-15-2010, 09:14 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Darqs - 12-17-2010, 03:49 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Pali - 04-15-2011, 07:20 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by tomnik - 04-15-2011, 08:03 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Pali - 04-16-2011, 02:44 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Darqs - 04-21-2011, 03:38 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300D50 - 12-15-2010, 09:10 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Biohazard - 12-16-2010, 11:49 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300D50 - 12-16-2010, 11:55 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Biohazard - 12-16-2010, 03:43 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300D50 - 12-16-2010, 06:50 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Biohazard - 12-16-2010, 08:35 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300D50 - 12-17-2010, 11:03 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Biohazard - 12-17-2010, 11:09 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Biohazard - 12-20-2010, 10:21 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Biohazard - 01-16-2011, 10:42 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Darqs - 01-18-2011, 02:37 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Biohazard - 01-18-2011, 09:52 AM
It's the "post your actuator guts" thread now - by aaa - 04-15-2011, 02:41 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by tomnik - 04-17-2011, 11:25 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Pali - 04-18-2011, 01:30 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by tomnik - 04-18-2011, 02:25 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Pali - 04-18-2011, 02:59 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 04-18-2011, 11:47 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 04-18-2011, 09:29 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Pali - 04-19-2011, 02:33 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 04-19-2011, 09:16 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Pali - 04-20-2011, 08:39 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 04-20-2011, 08:48 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Pali - 04-21-2011, 03:01 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Darqs - 07-01-2011, 04:07 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 07-01-2011, 03:57 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Darqs - 07-05-2011, 02:21 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by janus - 01-25-2012, 02:45 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Darqs - 02-20-2012, 04:20 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by janus - 01-29-2012, 11:16 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Rub87 - 01-29-2012, 02:47 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by majesty78 - 01-30-2012, 04:21 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Rub87 - 01-30-2012, 05:03 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by janus - 01-30-2012, 01:45 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by janus - 02-20-2012, 11:13 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Darqs - 02-22-2012, 05:42 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by janus - 07-17-2012, 07:03 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Darqs - 09-25-2012, 03:46 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by janus - 07-18-2012, 05:25 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by raysorenson - 07-18-2012, 10:56 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by janus - 10-09-2013, 08:58 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by pemtek - 11-04-2013, 06:22 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by janus - 11-05-2013, 01:47 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by pemtek - 11-05-2013, 03:49 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Iangiulu - 07-10-2014, 02:06 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Iangiulu - 07-12-2014, 02:42 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Darqs - 12-18-2014, 03:06 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by antonmies - 01-23-2015, 06:43 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by HoleshotHolset - 04-15-2015, 10:37 AM
 16 Guest(s)
 16 Guest(s)
