STD Tuning Engine Electronic variable vane control
  • 1 Vote(s) - 4 Average
01-12-2009, 09:40 PM #21
(01-12-2009, 09:03 PM)oel_brenner
(01-12-2009, 08:49 PM)winmutt
(01-12-2009, 07:56 PM)oel_brenner all of this is assuming we have (or can get) the CAN-bus protocol specifics for the electronic OM606 pump, and related sensors. but even if we can't just sniff them off the bus and document it yourself.
If you moved the oil can you could control the rack with a voice coil. It wouldnt be easy by a far shot. With an '85 you can read rack position though. I was outside earlier this evening trying to figure out how the sensor works. Someone around here had a post of how it operated. Forced?
How many HP does that vac pump pull you think? Smile
are you talking about retrofitting EMS onto a OM603 / OM61x
(non-electronic) engine ?
I was talking about running an already all electronic OM606 engine with a stand-alone open-source controller. Using CB comm protocols.
I don't think I will do it but the possibility is there. Does the OM606 control the rack electronically?
Messages In This Thread
Electronic variable vane control - by winmutt - 01-08-2009, 05:47 PM
RE: Electronic doodads - by winmutt - 01-08-2009, 06:13 PM
RE: Electronic doodads - by Gross Polluter - 01-09-2009, 02:22 AM
RE: Electronic doodads - by ForcedInduction - 01-09-2009, 04:03 AM
RE: Electronic doodads - by winmutt - 01-09-2009, 08:10 AM
RE: Electronic doodads - by winmutt - 01-09-2009, 09:11 AM
RE: Electronic doodads - by Gross Polluter - 01-09-2009, 09:41 AM
RE: Electronic doodads - by GREASY_BEAST - 01-09-2009, 10:54 AM
RE: Electronic doodads - by winmutt - 01-09-2009, 11:05 AM
RE: Electronic doodads - by GREASY_BEAST - 01-09-2009, 01:10 PM
RE: Electronic doodads - by winmutt - 01-09-2009, 02:55 PM
RE: Electronic doodads - by oel_brenner - 01-10-2009, 01:02 PM
RE: Electronic doodads - by GREASY_BEAST - 01-11-2009, 12:45 PM
RE: Electronic doodads - by tantank79 - 01-12-2009, 01:21 AM
RE: Electronic doodads - by Telecommbrkr - 01-11-2009, 10:37 PM
RE: Electronic doodads - by winmutt - 01-12-2009, 10:20 AM
RE: Electronic doodads - by ForcedInduction - 01-12-2009, 02:01 AM
RE: Electronic doodads - by oel_brenner - 01-12-2009, 07:56 PM
RE: Electronic doodads - by winmutt - 01-12-2009, 08:49 PM
RE: Electronic doodads - by oel_brenner - 01-12-2009, 09:03 PM
RE: Electronic doodads - by winmutt - 01-12-2009, 09:40 PM
RE: Electronic doodads - by GREASY_BEAST - 01-14-2009, 03:05 PM
RE: Electronic doodads - by oel_brenner - 01-14-2009, 11:41 PM
RE: Electronic doodads - by Gross Polluter - 01-15-2009, 01:57 AM
RE: Electronic doodads - by Tymbrymi - 01-30-2009, 01:54 PM
RE: Electronic doodads - by winmutt - 01-14-2009, 05:21 PM
RE: Electronic doodads - by winmutt - 01-15-2009, 10:06 AM
RE: Electronic doodads - by winmutt - 01-20-2009, 10:29 PM
RE: Electronic doodads - by winmutt - 01-20-2009, 11:16 PM
RE: Electronic doodads - by winmutt - 01-21-2009, 02:55 PM
RE: Electronic doodads - by cannonballSDL - 01-25-2009, 04:02 AM
RE: Electronic doodads - by winmutt - 01-26-2009, 10:37 AM
RE: Electronic doodads - by winmutt - 01-30-2009, 02:08 PM
RE: Electronic doodads - by Tymbrymi - 01-30-2009, 02:47 PM
RE: Electronic doodads - by ForcedInduction - 03-17-2009, 07:25 PM
RE: Electronic doodads - by Tymbrymi - 03-18-2009, 07:51 AM
RE: Electronic doodads - by ForcedInduction - 03-18-2009, 07:59 AM
RE: Electronic doodads - by GREASY_BEAST - 03-18-2009, 09:13 AM
RE: Electronic doodads - by Tymbrymi - 03-19-2009, 08:36 AM
RE: Electronic doodads - by GREASY_BEAST - 03-19-2009, 11:45 AM
RE: Electronic doodads - by GREASY_BEAST - 03-21-2009, 09:54 AM
RE: Electronic doodads - by Tymbrymi - 03-23-2009, 07:40 AM
RE: Electronic doodads - by GREASY_BEAST - 03-23-2009, 10:41 AM
RE: Electronic doodads - by winmutt - 03-17-2009, 07:41 PM
RE: Electronic doodads - by ForcedInduction - 03-17-2009, 07:44 PM
RE: Electronic doodads - by winmutt - 03-17-2009, 07:47 PM
RE: Electronic doodads - by winmutt - 03-18-2009, 03:02 PM
RE: Electronic doodads - by 300SD81 - 03-23-2009, 10:10 AM
RE: Electronic doodads - by Tymbrymi - 03-25-2009, 08:17 AM
RE: Electronic doodads - by 300SD81 - 03-23-2009, 06:45 PM
RE: Electronic doodads - by winmutt - 03-24-2009, 10:08 AM
RE: Electronic doodads - by Gross Polluter - 03-24-2009, 02:54 PM
RE: Electronic doodads - by winmutt - 09-04-2009, 10:31 AM
RE: Electronic doodads - by 300SD81 - 03-29-2009, 11:53 AM
RE: Electronic doodads - by 300SD81 - 04-09-2009, 10:23 AM
RE: Electronic doodads - by oel_brenner - 04-20-2009, 10:54 PM
RE: Electronic doodads - by 300SD81 - 04-20-2009, 11:40 PM
RE: Electronic doodads - by ForcedInduction - 04-21-2009, 05:45 PM
RE: Electronic doodads - by oel_brenner - 04-21-2009, 10:06 PM
RE: Electronic doodads - by oel_brenner - 04-29-2009, 10:41 PM
RE: Electronic doodads - by oel_brenner - 04-30-2009, 10:48 PM
RE: Electronic doodads - by Gross Polluter - 06-05-2009, 03:55 PM
RE: Electronic doodads - by winmutt - 09-03-2009, 01:27 PM
RE: Electronic doodads - by Tymbrymi - 09-03-2009, 01:36 PM
RE: Electronic doodads - by winmutt - 09-03-2009, 02:25 PM
RE: Electronic doodads - by tomnik - 09-04-2009, 06:15 AM
RE: Electronic variable vane control - by winmutt - 09-04-2009, 08:27 AM
RE: Electronic variable vane control - by Tymbrymi - 09-04-2009, 01:33 PM
RE: Electronic variable vane control - by winmutt - 09-04-2009, 03:21 PM
RE: Electronic variable vane control - by winmutt - 01-22-2011, 10:21 PM
RE: Electronic variable vane control - by aaa - 01-22-2011, 10:53 PM
RE: Electronic variable vane control - by winmutt - 01-22-2011, 11:38 PM
RE: Electronic variable vane control - by Spaceraver - 01-23-2011, 12:08 PM
RE: Electronic variable vane control - by winmutt - 01-23-2011, 03:55 PM
RE: Electronic variable vane control - by winmutt - 01-24-2011, 09:25 AM
RE: Electronic variable vane control - by aaa - 01-24-2011, 05:04 PM
RE: Electronic variable vane control - by Spaceraver - 01-25-2011, 04:53 AM
RE: Electronic variable vane control - by winmutt - 01-25-2011, 09:40 AM
RE: Electronic variable vane control - by 300D50 - 01-25-2011, 12:01 PM
RE: Electronic variable vane control - by winmutt - 01-25-2011, 05:45 PM
RE: Electronic variable vane control - by MTUPower - 01-25-2011, 07:15 PM
RE: Electronic variable vane control - by aaa - 01-25-2011, 07:21 PM
RE: Electronic variable vane control - by winmutt - 01-26-2011, 06:28 PM
RE: Electronic variable vane control - by tomnik - 01-27-2011, 12:45 AM
RE: Electronic variable vane control - by Syncro_G - 01-27-2011, 10:17 AM
RE: Electronic variable vane control - by 300D50 - 01-27-2011, 10:43 AM
RE: Electronic variable vane control - by aaa - 02-01-2011, 08:01 PM
RE: Electronic variable vane control - by winmutt - 03-04-2011, 09:38 PM
RE: Electronic variable vane control - by 300D50 - 03-04-2011, 11:45 PM
RE: Electronic variable vane control - by winmutt - 03-07-2011, 10:14 AM
RE: Electronic variable vane control - by 300D50 - 03-07-2011, 02:46 PM
 7 Guest(s)
 7 Guest(s)
