STD Tuning Engine Electronic variable vane control
  • 1 Vote(s) - 4 Average
Gross Polluter
01-09-2009, 02:22 AM #3
At that point why not adapt a second VR sensor into the IP and code something similar to an RIV tool into the microcontroller? It would be much, much more accurate than the millivolt method for setting or checking pump timing. All you'd have to do is calculate RPM based on the crank sensor then use time differential between the crank pulse and IP pulse to calculate pump timing.
This post was last modified: 01-09-2009, 02:23 AM by Gross Polluter.
Gross Polluter
Messages In This Thread
Electronic variable vane control - by winmutt - 01-08-2009, 05:47 PM
RE: Electronic doodads - by winmutt - 01-08-2009, 06:13 PM
RE: Electronic doodads - by Gross Polluter - 01-09-2009, 02:22 AM
RE: Electronic doodads - by ForcedInduction - 01-09-2009, 04:03 AM
RE: Electronic doodads - by winmutt - 01-09-2009, 08:10 AM
RE: Electronic doodads - by winmutt - 01-09-2009, 09:11 AM
RE: Electronic doodads - by Gross Polluter - 01-09-2009, 09:41 AM
RE: Electronic doodads - by GREASY_BEAST - 01-09-2009, 10:54 AM
RE: Electronic doodads - by winmutt - 01-09-2009, 11:05 AM
RE: Electronic doodads - by GREASY_BEAST - 01-09-2009, 01:10 PM
RE: Electronic doodads - by winmutt - 01-09-2009, 02:55 PM
RE: Electronic doodads - by oel_brenner - 01-10-2009, 01:02 PM
RE: Electronic doodads - by GREASY_BEAST - 01-11-2009, 12:45 PM
RE: Electronic doodads - by tantank79 - 01-12-2009, 01:21 AM
RE: Electronic doodads - by Telecommbrkr - 01-11-2009, 10:37 PM
RE: Electronic doodads - by winmutt - 01-12-2009, 10:20 AM
RE: Electronic doodads - by ForcedInduction - 01-12-2009, 02:01 AM
RE: Electronic doodads - by oel_brenner - 01-12-2009, 07:56 PM
RE: Electronic doodads - by winmutt - 01-12-2009, 08:49 PM
RE: Electronic doodads - by oel_brenner - 01-12-2009, 09:03 PM
RE: Electronic doodads - by winmutt - 01-12-2009, 09:40 PM
RE: Electronic doodads - by GREASY_BEAST - 01-14-2009, 03:05 PM
RE: Electronic doodads - by oel_brenner - 01-14-2009, 11:41 PM
RE: Electronic doodads - by Gross Polluter - 01-15-2009, 01:57 AM
RE: Electronic doodads - by Tymbrymi - 01-30-2009, 01:54 PM
RE: Electronic doodads - by winmutt - 01-14-2009, 05:21 PM
RE: Electronic doodads - by winmutt - 01-15-2009, 10:06 AM
RE: Electronic doodads - by winmutt - 01-20-2009, 10:29 PM
RE: Electronic doodads - by winmutt - 01-20-2009, 11:16 PM
RE: Electronic doodads - by winmutt - 01-21-2009, 02:55 PM
RE: Electronic doodads - by cannonballSDL - 01-25-2009, 04:02 AM
RE: Electronic doodads - by winmutt - 01-26-2009, 10:37 AM
RE: Electronic doodads - by winmutt - 01-30-2009, 02:08 PM
RE: Electronic doodads - by Tymbrymi - 01-30-2009, 02:47 PM
RE: Electronic doodads - by ForcedInduction - 03-17-2009, 07:25 PM
RE: Electronic doodads - by Tymbrymi - 03-18-2009, 07:51 AM
RE: Electronic doodads - by ForcedInduction - 03-18-2009, 07:59 AM
RE: Electronic doodads - by GREASY_BEAST - 03-18-2009, 09:13 AM
RE: Electronic doodads - by Tymbrymi - 03-19-2009, 08:36 AM
RE: Electronic doodads - by GREASY_BEAST - 03-19-2009, 11:45 AM
RE: Electronic doodads - by GREASY_BEAST - 03-21-2009, 09:54 AM
RE: Electronic doodads - by Tymbrymi - 03-23-2009, 07:40 AM
RE: Electronic doodads - by GREASY_BEAST - 03-23-2009, 10:41 AM
RE: Electronic doodads - by winmutt - 03-17-2009, 07:41 PM
RE: Electronic doodads - by ForcedInduction - 03-17-2009, 07:44 PM
RE: Electronic doodads - by winmutt - 03-17-2009, 07:47 PM
RE: Electronic doodads - by winmutt - 03-18-2009, 03:02 PM
RE: Electronic doodads - by 300SD81 - 03-23-2009, 10:10 AM
RE: Electronic doodads - by Tymbrymi - 03-25-2009, 08:17 AM
RE: Electronic doodads - by 300SD81 - 03-23-2009, 06:45 PM
RE: Electronic doodads - by winmutt - 03-24-2009, 10:08 AM
RE: Electronic doodads - by Gross Polluter - 03-24-2009, 02:54 PM
RE: Electronic doodads - by winmutt - 09-04-2009, 10:31 AM
RE: Electronic doodads - by 300SD81 - 03-29-2009, 11:53 AM
RE: Electronic doodads - by 300SD81 - 04-09-2009, 10:23 AM
RE: Electronic doodads - by oel_brenner - 04-20-2009, 10:54 PM
RE: Electronic doodads - by 300SD81 - 04-20-2009, 11:40 PM
RE: Electronic doodads - by ForcedInduction - 04-21-2009, 05:45 PM
RE: Electronic doodads - by oel_brenner - 04-21-2009, 10:06 PM
RE: Electronic doodads - by oel_brenner - 04-29-2009, 10:41 PM
RE: Electronic doodads - by oel_brenner - 04-30-2009, 10:48 PM
RE: Electronic doodads - by Gross Polluter - 06-05-2009, 03:55 PM
RE: Electronic doodads - by winmutt - 09-03-2009, 01:27 PM
RE: Electronic doodads - by Tymbrymi - 09-03-2009, 01:36 PM
RE: Electronic doodads - by winmutt - 09-03-2009, 02:25 PM
RE: Electronic doodads - by tomnik - 09-04-2009, 06:15 AM
RE: Electronic variable vane control - by winmutt - 09-04-2009, 08:27 AM
RE: Electronic variable vane control - by Tymbrymi - 09-04-2009, 01:33 PM
RE: Electronic variable vane control - by winmutt - 09-04-2009, 03:21 PM
RE: Electronic variable vane control - by winmutt - 01-22-2011, 10:21 PM
RE: Electronic variable vane control - by aaa - 01-22-2011, 10:53 PM
RE: Electronic variable vane control - by winmutt - 01-22-2011, 11:38 PM
RE: Electronic variable vane control - by Spaceraver - 01-23-2011, 12:08 PM
RE: Electronic variable vane control - by winmutt - 01-23-2011, 03:55 PM
RE: Electronic variable vane control - by winmutt - 01-24-2011, 09:25 AM
RE: Electronic variable vane control - by aaa - 01-24-2011, 05:04 PM
RE: Electronic variable vane control - by Spaceraver - 01-25-2011, 04:53 AM
RE: Electronic variable vane control - by winmutt - 01-25-2011, 09:40 AM
RE: Electronic variable vane control - by 300D50 - 01-25-2011, 12:01 PM
RE: Electronic variable vane control - by winmutt - 01-25-2011, 05:45 PM
RE: Electronic variable vane control - by MTUPower - 01-25-2011, 07:15 PM
RE: Electronic variable vane control - by aaa - 01-25-2011, 07:21 PM
RE: Electronic variable vane control - by winmutt - 01-26-2011, 06:28 PM
RE: Electronic variable vane control - by tomnik - 01-27-2011, 12:45 AM
RE: Electronic variable vane control - by Syncro_G - 01-27-2011, 10:17 AM
RE: Electronic variable vane control - by 300D50 - 01-27-2011, 10:43 AM
RE: Electronic variable vane control - by aaa - 02-01-2011, 08:01 PM
RE: Electronic variable vane control - by winmutt - 03-04-2011, 09:38 PM
RE: Electronic variable vane control - by 300D50 - 03-04-2011, 11:45 PM
RE: Electronic variable vane control - by winmutt - 03-07-2011, 10:14 AM
RE: Electronic variable vane control - by 300D50 - 03-07-2011, 02:46 PM
