New Project - Skunkwerks EM9D
  • 3 Vote(s) - 5 Average
Rudolf_Diesel
Ask me if I care...
09-16-2010, 10:10 PM #428
I got the springs for K1 / K2 installed and what a difference! It shifts relatively normal if you just cruise, but get on it and it shifts FIRM, not harsh, but nice and firm. I have not tested with max fuel yet, but it should make a difference their too.
It is too bad that I had to buy an entire kit for $55.00 and I only needed two springs. If any one wants to firm up their trans and needs some springs, I am willing to sell for a few bucks each.
I have also been working on a solution to my bypass valve operation. I was having an issue with the bypass valves fluttering because of the pressure dropping and the valves closing and the cycle repeating - the boost gauge would bounce and you could hear the S/C making a "woo woo woo" sound... as the valve opened and closed.
I designed a new circuit that is working really nice, it is the best it has run since the S/C was installed. It uses two micro switches, one pressure switch, two relays and a solenoid valve to control the vacuum signal. Below is the schematic:
I know what some are saying, you can do that with vacuum valves, you don't need to use all those electrics...well I prefer to use electrcial controls, that is what I do for a living and it is very easy to work with.
As I drive and the boost gets to the set point, CR1 energizes and is held by an aux. set of contacts. SW1 is a reset that is activated when the throttle linkage is at rest - idle. There is an additional switch for WOT that closes the bypass valves and allows for the S/C to pump some air to the turbo. I have also incorporated a switch to bypass the system when I drag race.
Before this the car would cruise on the freeway at 65 and the boost would be at whatever I had the pressure switch set to. Now it will be at 3 psi and when I add fuel the turbo starts to spool and we have boost, If I floor it, the boost comes on instantly from the S/C.
This post was last modified: 09-16-2010, 10:19 PM by Rudolf_Diesel.
Rudolf_Diesel
Messages In This Thread
New Project - Skunkwerks EM9D - by Rudolf_Diesel - 11-18-2009, 09:31 PM
RE: New Project - Top Secret (Skunkwerks) - by willbhere4u - 11-18-2009, 10:24 PM
RE: New Project - Top Secret (Skunkwerks) - by Rudolf_Diesel - 11-18-2009, 10:43 PM
RE: New Project - Top Secret (Skunkwerks) - by ForcedInduction - 11-19-2009, 12:21 AM
RE: New Project - Top Secret (Skunkwerks) - by Rudolf_Diesel - 11-30-2009, 08:17 PM
RE: New Project - Top Secret (Skunkwerks) - by willbhere4u - 11-30-2009, 09:08 PM
RE: New Project - Top Secret (Skunkwerks) - by Rudolf_Diesel - 11-30-2009, 09:21 PM
RE: New Project - Top Secret (Skunkwerks) - by E300TSC - 11-30-2009, 09:53 PM
RE: New Project - Top Secret (Skunkwerks) - by lars - 12-01-2009, 11:27 AM
RE: New Project - Top Secret (Skunkwerks) - by willbhere4u - 12-01-2009, 02:24 PM
RE: New Project - Top Secret (Skunkwerks) - by Rudolf_Diesel - 12-02-2009, 10:06 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 12-14-2009, 09:06 PM
RE: New Project - Skunkwerks EM9D - by willbhere4u - 12-14-2009, 10:32 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 12-16-2009, 09:19 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 12-20-2009, 06:27 PM
RE: New Project - Skunkwerks EM9D - by Kiwibacon - 12-20-2009, 06:54 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 12-20-2009, 07:53 PM
RE: New Project - Skunkwerks EM9D - by Kiwibacon - 12-20-2009, 11:49 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 12-21-2009, 11:30 AM
RE: New Project - Skunkwerks EM9D - by ForcedInduction - 12-21-2009, 12:47 PM
RE: New Project - Skunkwerks EM9D - by HoleshotHolset - 12-22-2009, 10:50 AM
RE: New Project - Skunkwerks EM9D - by Kiwibacon - 12-21-2009, 06:48 PM
RE: New Project - Skunkwerks EM9D - by willbhere4u - 12-21-2009, 02:23 PM
RE: New Project - Skunkwerks EM9D - by GREASY_BEAST - 12-21-2009, 06:08 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 12-21-2009, 09:48 PM
RE: New Project - Skunkwerks EM9D - by GREASY_BEAST - 12-22-2009, 10:36 AM
RE: New Project - Skunkwerks EM9D - by willbhere4u - 12-21-2009, 11:54 PM
RE: New Project - Skunkwerks EM9D - by kamel - 12-22-2009, 02:29 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 12-23-2009, 09:23 AM
RE: New Project - Skunkwerks EM9D - by ForcedInduction - 12-23-2009, 09:30 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 12-23-2009, 10:05 AM
RE: New Project - Skunkwerks EM9D - by DeliveryValve - 12-23-2009, 10:30 AM
RE: New Project - Skunkwerks EM9D - by HoleshotHolset - 12-23-2009, 02:44 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 12-23-2009, 03:44 PM
RE: New Project - Skunkwerks EM9D - by HoleshotHolset - 12-23-2009, 03:56 PM
RE: New Project - Skunkwerks EM9D - by willbhere4u - 12-23-2009, 08:40 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 12-30-2009, 10:37 PM
RE: New Project - Skunkwerks EM9D - by HoleshotHolset - 12-31-2009, 02:34 PM
RE: New Project - Skunkwerks EM9D - by oel_brenner - 12-31-2009, 10:37 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 12-31-2009, 11:32 AM
RE: New Project - Skunkwerks EM9D - by bmwpowere36m3 - 12-31-2009, 01:37 PM
RE: New Project - Skunkwerks EM9D - by willbhere4u - 12-31-2009, 02:57 PM
RE: New Project - Skunkwerks EM9D - by Kozuka - 01-04-2010, 09:01 PM
RE: New Project - Skunkwerks EM9D - by ForcedInduction - 01-04-2010, 09:14 PM
RE: New Project - Skunkwerks EM9D - by Kozuka - 01-04-2010, 09:37 PM
RE: New Project - Skunkwerks EM9D - by ForcedInduction - 01-04-2010, 09:50 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 01-04-2010, 11:42 PM
RE: New Project - Skunkwerks EM9D - by ForcedInduction - 01-05-2010, 12:19 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 01-06-2010, 10:08 AM
RE: New Project - Skunkwerks EM9D - by ForcedInduction - 01-06-2010, 10:25 AM
RE: New Project - Skunkwerks EM9D - by E300TSC - 01-06-2010, 12:06 PM
RE: New Project - Skunkwerks EM9D - by Kiwibacon - 01-06-2010, 03:41 PM
RE: New Project - Skunkwerks EM9D - by E300TSC - 01-06-2010, 04:05 PM
RE: New Project - Skunkwerks EM9D - by ForcedInduction - 01-06-2010, 04:37 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 01-06-2010, 10:43 PM
RE: New Project - Skunkwerks EM9D - by DeliveryValve - 01-07-2010, 05:18 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 01-09-2010, 07:58 PM
RE: New Project - Skunkwerks EM9D - by DeliveryValve - 01-09-2010, 09:41 PM
RE: New Project - Skunkwerks EM9D - by DeliveryValve - 01-10-2010, 03:22 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 01-10-2010, 10:29 AM
RE: New Project - Skunkwerks EM9D - by DeliveryValve - 01-10-2010, 01:30 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 01-23-2010, 05:57 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 02-07-2010, 09:30 AM
RE: New Project - Skunkwerks EM9D - by willbhere4u - 02-07-2010, 05:48 PM
RE: New Project - Skunkwerks EM9D - by GREASY_BEAST - 02-07-2010, 05:56 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 02-25-2010, 11:31 PM
RE: New Project - Skunkwerks EM9D - by tomnik - 02-26-2010, 01:06 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 02-26-2010, 07:09 AM
RE: New Project - Skunkwerks EM9D - by capflya - 02-27-2010, 10:40 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 02-28-2010, 07:12 PM
RE: New Project - Skunkwerks EM9D - by DeliveryValve - 03-06-2010, 12:20 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 03-06-2010, 09:29 AM
RE: New Project - Skunkwerks EM9D - by DeliveryValve - 03-06-2010, 11:42 PM
RE: New Project - Skunkwerks EM9D - by capflya - 03-02-2010, 08:05 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 03-05-2010, 10:18 PM
RE: New Project - Skunkwerks EM9D - by capflya - 03-24-2010, 07:09 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 03-24-2010, 08:13 PM
RE: New Project - Skunkwerks EM9D - by willbhere4u - 03-05-2010, 11:55 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 03-07-2010, 06:06 PM
RE: New Project - Skunkwerks EM9D - by willbhere4u - 03-07-2010, 09:21 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 03-07-2010, 09:40 PM
RE: New Project - Skunkwerks EM9D - by ForcedInduction - 03-07-2010, 09:59 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 03-07-2010, 10:04 PM
RE: New Project - Skunkwerks EM9D - by winmutt - 03-08-2010, 08:27 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 03-08-2010, 08:39 PM
RE: New Project - Skunkwerks EM9D - by willbhere4u - 03-08-2010, 11:21 PM
RE: New Project - Skunkwerks EM9D - by supercharged3.0 - 03-15-2010, 03:32 PM
RE: New Project - Skunkwerks EM9D - by ForcedInduction - 03-15-2010, 07:05 PM
RE: New Project - Skunkwerks EM9D - by supercharged3.0 - 03-15-2010, 08:45 PM
RE: New Project - Skunkwerks EM9D - by ForcedInduction - 03-15-2010, 08:50 PM
RE: New Project - Skunkwerks EM9D - by supercharged3.0 - 03-15-2010, 11:05 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 03-15-2010, 05:02 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 03-15-2010, 08:52 PM
RE: New Project - Skunkwerks EM9D - by Biohazard - 03-18-2010, 10:40 AM
RE: New Project - Skunkwerks EM9D - by supercharged3.0 - 03-20-2010, 08:58 PM
RE: New Project - Skunkwerks EM9D - by DrewGerhan - 03-20-2010, 10:13 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 03-20-2010, 10:25 PM
RE: New Project - Skunkwerks EM9D - by supercharged3.0 - 03-20-2010, 11:47 PM
RE: New Project - Skunkwerks EM9D - by George3soccer - 03-24-2010, 09:54 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 03-24-2010, 10:54 PM
RE: New Project - Skunkwerks EM9D - by dropnosky - 03-25-2010, 07:39 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 04-03-2010, 02:11 PM
RE: New Project - Skunkwerks EM9D - by willbhere4u - 04-03-2010, 03:48 PM
RE: New Project - Skunkwerks EM9D - by ForcedInduction - 04-03-2010, 05:17 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 04-03-2010, 07:04 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 04-05-2010, 07:20 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 04-11-2010, 03:19 PM
RE: New Project - Skunkwerks EM9D - by meareweird - 04-13-2010, 10:28 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 04-17-2010, 07:13 PM
RE: New Project - Skunkwerks EM9D - by Kiwibacon - 04-17-2010, 08:23 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 04-17-2010, 08:57 PM
RE: New Project - Skunkwerks EM9D - by Biohazard - 04-18-2010, 12:48 PM
RE: New Project - Skunkwerks EM9D - by supercharged3.0 - 04-19-2010, 10:51 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 04-20-2010, 09:33 AM
RE: New Project - Skunkwerks EM9D - by ForcedInduction - 04-20-2010, 10:56 AM
RE: New Project - Skunkwerks EM9D - by Kozuka - 04-20-2010, 11:52 AM
RE: New Project - Skunkwerks EM9D - by willbhere4u - 04-20-2010, 01:19 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 04-20-2010, 09:58 PM
RE: New Project - Skunkwerks EM9D - by willbhere4u - 04-21-2010, 01:19 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 04-22-2010, 09:55 PM
RE: New Project - Skunkwerks EM9D - by DeliveryValve - 04-28-2010, 09:03 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 04-28-2010, 09:29 PM
RE: New Project - Skunkwerks EM9D - by MTUPower - 05-22-2010, 08:54 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 05-22-2010, 09:01 PM
RE: New Project - Skunkwerks EM9D - by George3soccer - 04-23-2010, 10:54 AM
RE: New Project - Skunkwerks EM9D - by Rcdevil - 04-24-2010, 09:16 PM
RE: New Project - Skunkwerks EM9D - by Kozuka - 04-24-2010, 09:36 PM
RE: New Project - Skunkwerks EM9D - by Rcdevil - 04-25-2010, 09:57 AM
RE: New Project - Skunkwerks EM9D - by winmutt - 04-28-2010, 08:53 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 04-28-2010, 06:50 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 05-02-2010, 09:03 PM
RE: New Project - Skunkwerks EM9D - by George3soccer - 05-03-2010, 09:41 AM
RE: New Project - Skunkwerks EM9D - by meareweird - 05-04-2010, 08:39 AM
RE: New Project - Skunkwerks EM9D - by supercharged3.0 - 05-05-2010, 01:00 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 05-05-2010, 07:17 AM
RE: New Project - Skunkwerks EM9D - by supercharged3.0 - 05-05-2010, 11:36 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 05-07-2010, 10:10 PM
RE: New Project - Skunkwerks EM9D - by DeliveryValve - 05-08-2010, 12:18 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 05-08-2010, 06:23 PM
RE: New Project - Skunkwerks EM9D - by supercharged3.0 - 05-20-2010, 07:54 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 05-20-2010, 09:17 PM
RE: New Project - Skunkwerks EM9D - by DeliveryValve - 05-21-2010, 11:21 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 05-21-2010, 12:33 PM
RE: New Project - Skunkwerks EM9D - by willbhere4u - 05-20-2010, 10:36 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 05-22-2010, 06:50 PM
RE: New Project - Skunkwerks EM9D - by willbhere4u - 05-22-2010, 07:28 PM
RE: New Project - Skunkwerks EM9D - by DeliveryValve - 05-22-2010, 07:56 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 05-22-2010, 08:14 PM
RE: New Project - Skunkwerks EM9D - by E300TSC - 05-23-2010, 06:54 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 05-23-2010, 05:59 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 05-24-2010, 06:37 PM
RE: New Project - Skunkwerks EM9D - by winmutt - 05-24-2010, 07:58 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 05-24-2010, 08:03 PM
RE: New Project - Skunkwerks EM9D - by ForcedInduction - 05-25-2010, 02:49 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 05-25-2010, 07:15 AM
RE: New Project - Skunkwerks EM9D - by capflya - 05-25-2010, 02:00 AM
RE: New Project - Skunkwerks EM9D - by George3soccer - 05-25-2010, 10:50 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 05-25-2010, 11:16 AM
RE: New Project - Skunkwerks EM9D - by yankneck696 - 05-25-2010, 04:11 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 05-27-2010, 08:19 PM
RE: New Project - Skunkwerks EM9D - by winmutt - 05-28-2010, 07:51 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 05-28-2010, 08:52 AM
RE: New Project - Skunkwerks EM9D - by E300TSC - 05-28-2010, 09:54 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 05-28-2010, 04:25 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 05-31-2010, 02:01 PM
RE: New Project - Skunkwerks EM9D - by E300TSC - 06-01-2010, 08:14 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 06-01-2010, 08:35 AM
RE: New Project - Skunkwerks EM9D - by E300TSC - 06-01-2010, 10:10 AM
RE: New Project - Skunkwerks EM9D - by willbhere4u - 06-01-2010, 01:26 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 06-02-2010, 08:02 PM
RE: New Project - Skunkwerks EM9D - by Deni - 06-03-2010, 04:15 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 06-03-2010, 06:10 AM
RE: New Project - Skunkwerks EM9D - by ForcedInduction - 06-03-2010, 06:15 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 06-03-2010, 06:30 AM
RE: New Project - Skunkwerks EM9D - by winmutt - 06-03-2010, 07:33 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 06-03-2010, 08:02 AM
RE: New Project - Skunkwerks EM9D - by supercharged3.0 - 06-03-2010, 10:55 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 06-03-2010, 11:46 PM
RE: New Project - Skunkwerks EM9D - by ForcedInduction - 06-04-2010, 05:35 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 06-04-2010, 06:38 AM
RE: New Project - Skunkwerks EM9D - by ForcedInduction - 06-04-2010, 07:19 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 06-04-2010, 08:13 AM
RE: New Project - Skunkwerks EM9D - by Kozuka - 06-05-2010, 01:41 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 06-05-2010, 03:25 PM
RE: New Project - Skunkwerks EM9D - by squirrelmaster - 06-05-2010, 04:47 PM
RE: New Project - Skunkwerks EM9D - by ForcedInduction - 06-05-2010, 05:16 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 06-05-2010, 05:46 PM
RE: New Project - Skunkwerks EM9D - by andrecorreia - 06-05-2010, 07:52 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 06-06-2010, 07:10 PM
RE: New Project - Skunkwerks EM9D - by DeliveryValve - 06-06-2010, 08:30 PM
RE: New Project - Skunkwerks EM9D - by dropnosky - 06-06-2010, 07:45 PM
RE: New Project - Skunkwerks EM9D - by tomnik - 06-06-2010, 11:19 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 06-07-2010, 06:07 AM
RE: New Project - Skunkwerks EM9D - by willbhere4u - 06-07-2010, 09:40 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 06-07-2010, 10:31 AM
RE: New Project - Skunkwerks EM9D - by willbhere4u - 06-07-2010, 12:27 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 06-07-2010, 08:08 PM
RE: New Project - Skunkwerks EM9D - by andrecorreia - 06-08-2010, 07:22 PM
RE: New Project - Skunkwerks EM9D - by willbhere4u - 06-08-2010, 10:31 PM
RE: New Project - Skunkwerks EM9D - by supercharged3.0 - 06-12-2010, 08:45 PM
RE: New Project - Skunkwerks EM9D - by tomnik - 06-19-2010, 09:25 AM
RE: New Project - Skunkwerks EM9D - by supercharged3.0 - 06-16-2010, 11:35 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 06-17-2010, 08:13 AM
RE: New Project - Skunkwerks EM9D - by Biohazard - 06-19-2010, 05:44 PM
RE: New Project - Skunkwerks EM9D - by supercharged3.0 - 07-01-2010, 09:28 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 07-01-2010, 10:09 PM
RE: New Project - Skunkwerks EM9D - by Captain America - 07-04-2010, 03:45 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 07-04-2010, 09:25 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 07-10-2010, 09:17 PM
RE: New Project - Skunkwerks EM9D - by willbhere4u - 07-10-2010, 10:43 PM
RE: New Project - Skunkwerks EM9D - by Captain America - 07-11-2010, 05:12 AM
RE: New Project - Skunkwerks EM9D - by squirrelmaster - 07-14-2010, 05:58 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 07-14-2010, 06:01 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 07-14-2010, 09:38 PM
RE: New Project - Skunkwerks EM9D - by Captain America - 07-15-2010, 10:01 AM
RE: New Project - Skunkwerks EM9D - by supercharged3.0 - 07-15-2010, 11:09 PM
RE: New Project - Skunkwerks EM9D - by mike-81-240d - 07-21-2010, 02:03 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 07-25-2010, 12:55 PM
RE: New Project - Skunkwerks EM9D - by garage - 07-25-2010, 12:58 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 07-25-2010, 01:06 PM
RE: New Project - Skunkwerks EM9D - by garage - 07-25-2010, 01:21 PM
RE: New Project - Skunkwerks EM9D - by Captain America - 07-26-2010, 09:48 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 07-26-2010, 10:19 AM
RE: New Project - Skunkwerks EM9D - by Captain America - 07-26-2010, 03:20 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 07-26-2010, 04:43 PM
RE: New Project - Skunkwerks EM9D - by Captain America - 07-26-2010, 02:28 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 07-26-2010, 03:01 PM
RE: New Project - Skunkwerks EM9D - by Captain America - 07-26-2010, 05:11 PM
RE: New Project - Skunkwerks EM9D - by ConnClark - 07-27-2010, 02:41 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 07-27-2010, 03:44 PM
RE: New Project - Skunkwerks EM9D - by Captain America - 07-27-2010, 06:11 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 07-27-2010, 06:14 PM
RE: New Project - Skunkwerks EM9D - by Captain America - 07-27-2010, 10:50 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 07-28-2010, 12:42 AM
RE: New Project - Skunkwerks EM9D - by Captain America - 07-28-2010, 01:26 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 07-28-2010, 07:24 AM
RE: New Project - Skunkwerks EM9D - by Captain America - 07-28-2010, 12:48 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 07-29-2010, 08:39 AM
RE: New Project - Skunkwerks EM9D - by Captain America - 07-29-2010, 11:02 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 07-29-2010, 09:59 PM
RE: New Project - Skunkwerks EM9D - by Captain America - 07-29-2010, 11:39 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 07-30-2010, 09:17 AM
RE: New Project - Skunkwerks EM9D - by ForcedInduction - 07-30-2010, 10:28 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 07-30-2010, 10:54 AM
RE: New Project - Skunkwerks EM9D - by ForcedInduction - 07-30-2010, 06:45 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 07-31-2010, 07:56 AM
RE: New Project - Skunkwerks EM9D - by ForcedInduction - 07-31-2010, 08:01 AM
RE: New Project - Skunkwerks EM9D - by ForcedInduction - 07-30-2010, 05:10 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 07-30-2010, 05:16 AM
RE: New Project - Skunkwerks EM9D - by yankneck696 - 07-30-2010, 05:27 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 07-30-2010, 06:05 AM
RE: New Project - Skunkwerks EM9D - by Biohazard - 07-30-2010, 09:12 AM
RE: New Project - Skunkwerks EM9D - by Captain America - 07-30-2010, 09:53 AM
RE: New Project - Skunkwerks EM9D - by Captain America - 07-30-2010, 01:13 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 07-30-2010, 03:49 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 07-31-2010, 08:09 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 08-01-2010, 02:13 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 08-01-2010, 04:28 PM
RE: New Project - Skunkwerks EM9D - by winmutt - 08-01-2010, 07:31 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 08-01-2010, 08:51 PM
RE: New Project - Skunkwerks EM9D - by Captain America - 08-01-2010, 11:58 PM
RE: New Project - Skunkwerks EM9D - by meareweird - 08-03-2010, 11:39 AM
RE: New Project - Skunkwerks EM9D - by dropnosky - 08-03-2010, 01:13 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 08-03-2010, 02:17 PM
RE: New Project - Skunkwerks EM9D - by squirrelmaster - 08-04-2010, 04:23 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 08-04-2010, 05:37 PM
RE: New Project - Skunkwerks EM9D - by Biohazard - 08-04-2010, 05:59 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 08-04-2010, 06:32 PM
RE: New Project - Skunkwerks EM9D - by supercharged3.0 - 08-07-2010, 12:33 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 08-07-2010, 11:03 PM
RE: New Project - Skunkwerks EM9D - by willbhere4u - 08-08-2010, 12:27 AM
RE: New Project - Skunkwerks EM9D - by supercharged3.0 - 08-08-2010, 01:06 AM
RE: New Project - Skunkwerks EM9D - by Biohazard - 08-08-2010, 02:38 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 08-10-2010, 07:38 PM
RE: New Project - Skunkwerks EM9D - by Alastair E - 08-08-2010, 05:06 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 08-08-2010, 07:59 AM
RE: New Project - Skunkwerks EM9D - by ForcedInduction - 08-08-2010, 05:41 AM
RE: New Project - Skunkwerks EM9D - by squirrelmaster - 08-08-2010, 03:00 PM
RE: New Project - Skunkwerks EM9D - by yankneck696 - 08-08-2010, 04:26 PM
RE: New Project - Skunkwerks EM9D - by Captain America - 08-08-2010, 06:51 PM
RE: New Project - Skunkwerks EM9D - by Biohazard - 08-08-2010, 06:55 PM
RE: New Project - Skunkwerks EM9D - by tomnik - 08-09-2010, 12:02 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 08-09-2010, 07:23 AM
RE: New Project - Skunkwerks EM9D - by Biohazard - 08-09-2010, 12:20 AM
RE: New Project - Skunkwerks EM9D - by yankneck696 - 08-09-2010, 05:43 AM
RE: New Project - Skunkwerks EM9D - by HughF_UK - 08-09-2010, 10:28 AM
RE: New Project - Skunkwerks EM9D - by DervTuning - 08-10-2010, 12:24 PM
RE: New Project - Skunkwerks EM9D - by HughF_UK - 08-11-2010, 04:32 AM
RE: New Project - Skunkwerks EM9D - by tomnik - 08-10-2010, 02:04 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 08-10-2010, 02:14 PM
RE: New Project - Skunkwerks EM9D - by Captain America - 08-10-2010, 02:31 PM
RE: New Project - Skunkwerks EM9D - by DervTuning - 08-11-2010, 11:16 AM
RE: New Project - Skunkwerks EM9D - by altamonte - 08-10-2010, 03:31 PM
RE: New Project - Skunkwerks EM9D - by Biohazard - 08-11-2010, 08:52 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 08-11-2010, 04:04 PM
RE: New Project - Skunkwerks EM9D - by ForcedInduction - 08-11-2010, 07:22 PM
RE: New Project - Skunkwerks EM9D - by ID240D - 08-11-2010, 05:15 PM
RE: New Project - Skunkwerks EM9D - by willbhere4u - 08-11-2010, 05:24 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 08-11-2010, 05:44 PM
RE: New Project - Skunkwerks EM9D - by DeliveryValve - 08-11-2010, 07:21 PM
RE: New Project - Skunkwerks EM9D - by Captain America - 08-11-2010, 06:34 PM
RE: New Project - Skunkwerks EM9D - by ConnClark - 08-11-2010, 06:40 PM
RE: New Project - Skunkwerks EM9D - by Captain America - 08-11-2010, 11:15 PM
RE: New Project - Skunkwerks EM9D - by garage - 08-11-2010, 07:28 PM
RE: New Project - Skunkwerks EM9D - by dropnosky - 08-11-2010, 08:14 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 08-11-2010, 08:15 PM
RE: New Project - Skunkwerks EM9D - by willbhere4u - 08-11-2010, 10:33 PM
RE: New Project - Skunkwerks EM9D - by E300TSC - 08-12-2010, 04:57 AM
RE: New Project - Skunkwerks EM9D - by meareweird - 08-12-2010, 08:41 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 08-12-2010, 01:51 PM
RE: New Project - Skunkwerks EM9D - by Captain America - 08-12-2010, 02:13 PM
RE: New Project - Skunkwerks EM9D - by ID240D - 08-12-2010, 06:06 PM
RE: New Project - Skunkwerks EM9D - by supercharged3.0 - 08-13-2010, 12:55 AM
RE: New Project - Skunkwerks EM9D - by SurfRodder - 08-13-2010, 02:47 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 08-16-2010, 10:13 PM
RE: New Project - Skunkwerks EM9D - by supercharged3.0 - 08-16-2010, 10:53 PM
RE: New Project - Skunkwerks EM9D - by willbhere4u - 08-17-2010, 09:59 AM
RE: New Project - Skunkwerks EM9D - by ConnClark - 08-17-2010, 10:21 AM
RE: New Project - Skunkwerks EM9D - by garage - 08-17-2010, 10:26 AM
RE: New Project - Skunkwerks EM9D - by Captain America - 08-17-2010, 11:46 AM
RE: New Project - Skunkwerks EM9D - by meareweird - 08-17-2010, 03:26 PM
RE: New Project - Skunkwerks EM9D - by ID240D - 08-21-2010, 03:46 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 08-21-2010, 09:26 PM
RE: New Project - Skunkwerks EM9D - by winmutt - 08-22-2010, 08:18 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 08-22-2010, 09:13 AM
RE: New Project - Skunkwerks EM9D - by supercharged3.0 - 08-22-2010, 12:38 PM
RE: New Project - Skunkwerks EM9D - by dropnosky - 08-22-2010, 09:45 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 08-22-2010, 01:51 PM
RE: New Project - Skunkwerks EM9D - by garage - 08-25-2010, 08:24 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 08-25-2010, 10:50 PM
RE: New Project - Skunkwerks EM9D - by garage - 08-25-2010, 11:03 PM
RE: New Project - Skunkwerks EM9D - by meareweird - 08-22-2010, 02:50 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 08-22-2010, 03:08 PM
RE: New Project - Skunkwerks EM9D - by ForcedInduction - 08-22-2010, 02:52 PM
RE: New Project - Skunkwerks EM9D - by ID240D - 08-22-2010, 09:49 PM
RE: New Project - Skunkwerks EM9D - by Captain America - 08-24-2010, 01:49 AM
RE: New Project - Skunkwerks EM9D - by willbhere4u - 08-24-2010, 10:17 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 08-24-2010, 11:04 AM
RE: New Project - Skunkwerks EM9D - by ForcedInduction - 08-24-2010, 07:15 PM
RE: New Project - Skunkwerks EM9D - by Captain America - 08-26-2010, 12:56 AM
RE: New Project - Skunkwerks EM9D - by DeliveryValve - 08-26-2010, 02:05 AM
RE: New Project - Skunkwerks EM9D - by Captain America - 08-26-2010, 12:01 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 08-26-2010, 09:41 PM
RE: New Project - Skunkwerks EM9D - by Captain America - 08-26-2010, 10:59 PM
RE: New Project - Skunkwerks EM9D - by ForcedInduction - 08-27-2010, 05:37 AM
RE: New Project - Skunkwerks EM9D - by Captain America - 08-27-2010, 09:51 AM
RE: New Project - Skunkwerks EM9D - by Captain America - 08-30-2010, 03:20 PM
RE: New Project - Skunkwerks EM9D - by meareweird - 08-30-2010, 06:08 PM
RE: New Project - Skunkwerks EM9D - by willbhere4u - 08-31-2010, 05:21 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 09-01-2010, 10:55 PM
RE: New Project - Skunkwerks EM9D - by Captain America - 09-02-2010, 12:25 AM
RE: New Project - Skunkwerks EM9D - by Captain America - 09-03-2010, 10:26 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 09-03-2010, 11:14 AM
RE: New Project - Skunkwerks EM9D - by dropnosky - 09-03-2010, 11:26 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 09-03-2010, 11:31 AM
RE: New Project - Skunkwerks EM9D - by DervTuning - 09-03-2010, 11:27 AM
RE: New Project - Skunkwerks EM9D - by DeliveryValve - 09-03-2010, 11:39 AM
RE: New Project - Skunkwerks EM9D - by winmutt - 09-03-2010, 12:07 PM
RE: New Project - Skunkwerks EM9D - by Graminal95 - 09-03-2010, 01:56 PM
RE: New Project - Skunkwerks EM9D - by George3soccer - 09-03-2010, 02:59 PM
RE: New Project - Skunkwerks EM9D - by ForcedInduction - 09-03-2010, 06:49 PM
RE: New Project - Skunkwerks EM9D - by MJF - 09-03-2010, 07:08 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 09-03-2010, 07:41 PM
RE: New Project - Skunkwerks EM9D - by E300TSC - 09-03-2010, 08:11 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 09-03-2010, 10:21 PM
RE: New Project - Skunkwerks EM9D - by willbhere4u - 09-03-2010, 10:06 PM
RE: New Project - Skunkwerks EM9D - by BriZZell Dride - 09-03-2010, 10:42 PM
RE: New Project - Skunkwerks EM9D - by ForcedInduction - 09-04-2010, 06:12 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 09-04-2010, 06:10 PM
RE: New Project - Skunkwerks EM9D - by BriZZell Dride - 09-04-2010, 10:49 PM
RE: New Project - Skunkwerks EM9D - by ForcedInduction - 09-05-2010, 02:53 AM
RE: New Project - Skunkwerks EM9D - by BriZZell Dride - 09-05-2010, 09:48 PM
RE: New Project - Skunkwerks EM9D - by dropnosky - 09-05-2010, 12:55 PM
RE: New Project - Skunkwerks EM9D - by supercharged3.0 - 09-04-2010, 03:35 AM
RE: New Project - Skunkwerks EM9D - by BriZZell Dride - 09-04-2010, 11:01 AM
RE: New Project - Skunkwerks EM9D - by E300TSC - 09-04-2010, 02:55 PM
RE: New Project - Skunkwerks EM9D - by Deni - 09-05-2010, 03:01 AM
RE: New Project - Skunkwerks EM9D - by ForcedInduction - 09-05-2010, 03:47 AM
RE: New Project - Skunkwerks EM9D - by Deni - 09-05-2010, 03:55 AM
RE: New Project - Skunkwerks EM9D - by ForcedInduction - 09-05-2010, 04:00 AM
RE: New Project - Skunkwerks EM9D - by Deni - 09-05-2010, 04:18 AM
RE: New Project - Skunkwerks EM9D - by ForcedInduction - 09-05-2010, 05:11 AM
RE: New Project - Skunkwerks EM9D - by MJF - 09-05-2010, 07:12 AM
RE: New Project - Skunkwerks EM9D - by ForcedInduction - 09-05-2010, 07:29 AM
RE: New Project - Skunkwerks EM9D - by Deni - 09-05-2010, 03:20 PM
RE: New Project - Skunkwerks EM9D - by garage - 09-05-2010, 05:38 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 09-05-2010, 05:44 PM
RE: New Project - Skunkwerks EM9D - by MJF - 09-05-2010, 06:30 PM
RE: New Project - Skunkwerks EM9D - by Deni - 09-06-2010, 03:00 AM
RE: New Project - Skunkwerks EM9D - by tomnik - 09-06-2010, 05:31 AM
RE: New Project - Skunkwerks EM9D - by BriZZell Dride - 09-06-2010, 07:57 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 09-06-2010, 04:47 PM
RE: New Project - Skunkwerks EM9D - by ConnClark - 09-07-2010, 12:01 PM
RE: New Project - Skunkwerks EM9D - by meareweird - 09-08-2010, 05:26 PM
RE: New Project - Skunkwerks EM9D - by ForcedInduction - 09-08-2010, 05:50 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 09-08-2010, 07:33 PM
RE: New Project - Skunkwerks EM9D - by winmutt - 09-08-2010, 08:40 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 09-08-2010, 08:45 PM
RE: New Project - Skunkwerks EM9D - by E300TSC - 09-09-2010, 06:02 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 09-09-2010, 07:12 AM
RE: New Project - Skunkwerks EM9D - by Captain America - 09-09-2010, 09:50 AM
RE: New Project - Skunkwerks EM9D - by ForcedInduction - 09-09-2010, 09:59 AM
RE: New Project - Skunkwerks EM9D - by Captain America - 09-09-2010, 02:09 PM
RE: New Project - Skunkwerks EM9D - by E300TSC - 09-09-2010, 05:59 PM
RE: New Project - Skunkwerks EM9D - by Captain America - 09-10-2010, 02:21 PM
RE: New Project - Skunkwerks EM9D - by meareweird - 09-10-2010, 03:40 PM
RE: New Project - Skunkwerks EM9D - by willbhere4u - 09-10-2010, 04:57 PM
RE: New Project - Skunkwerks EM9D - by garage - 09-10-2010, 09:36 PM
RE: New Project - Skunkwerks EM9D - by Captain America - 09-10-2010, 09:43 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 09-11-2010, 02:59 PM
RE: New Project - Skunkwerks EM9D - by ForcedInduction - 09-11-2010, 04:09 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 09-11-2010, 04:12 PM
RE: New Project - Skunkwerks EM9D - by Captain America - 09-11-2010, 05:29 PM
RE: New Project - Skunkwerks EM9D - by willbhere4u - 09-11-2010, 07:36 PM
RE: New Project - Skunkwerks EM9D - by tomnik - 09-12-2010, 01:25 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 09-12-2010, 10:28 AM
RE: New Project - Skunkwerks EM9D - by DeliveryValve - 09-12-2010, 06:49 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 09-13-2010, 09:26 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 09-12-2010, 03:47 PM
RE: New Project - Skunkwerks EM9D - by willbhere4u - 09-13-2010, 11:16 PM
RE: New Project - Skunkwerks EM9D - by Silberpfeil - 09-14-2010, 10:19 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 09-15-2010, 07:13 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 09-15-2010, 09:08 PM
RE: New Project - Skunkwerks EM9D - by DeliveryValve - 09-15-2010, 10:28 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 09-15-2010, 10:34 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 09-16-2010, 10:10 PM
RE: New Project - Skunkwerks EM9D - by ConnClark - 09-17-2010, 12:34 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 09-17-2010, 12:37 PM
RE: New Project - Skunkwerks EM9D - by DeliveryValve - 09-17-2010, 12:22 PM
RE: New Project - Skunkwerks EM9D - by Captain America - 09-17-2010, 02:50 PM
RE: New Project - Skunkwerks EM9D - by ForcedInduction - 09-17-2010, 03:45 PM
RE: New Project - Skunkwerks EM9D - by ConnClark - 09-17-2010, 04:16 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 09-17-2010, 05:29 PM
RE: New Project - Skunkwerks EM9D - by ConnClark - 09-17-2010, 06:55 PM
RE: New Project - Skunkwerks EM9D - by Captain America - 09-17-2010, 05:58 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 09-17-2010, 06:05 PM
RE: New Project - Skunkwerks EM9D - by Captain America - 09-17-2010, 09:15 PM
RE: New Project - Skunkwerks EM9D - by ConnClark - 09-18-2010, 12:11 PM
RE: New Project - Skunkwerks EM9D - by Captain America - 09-18-2010, 02:03 PM
RE: New Project - Skunkwerks EM9D - by DeliveryValve - 09-18-2010, 07:02 PM
RE: New Project - Skunkwerks EM9D - by meareweird - 09-18-2010, 09:51 AM
RE: New Project - Skunkwerks EM9D - by willbhere4u - 09-18-2010, 09:14 PM
RE: New Project - Skunkwerks EM9D - by Captain America - 09-18-2010, 10:01 PM
RE: New Project - Skunkwerks EM9D - by DeliveryValve - 09-19-2010, 05:34 PM
RE: New Project - Skunkwerks EM9D - by yankneck696 - 09-19-2010, 12:17 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 09-19-2010, 02:51 PM
RE: New Project - Skunkwerks EM9D - by E300TSC - 09-19-2010, 04:26 PM
RE: New Project - Skunkwerks EM9D - by ForcedInduction - 09-19-2010, 05:07 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 09-19-2010, 05:13 PM
RE: New Project - Skunkwerks EM9D - by DeliveryValve - 09-19-2010, 05:37 PM
RE: New Project - Skunkwerks EM9D - by E300TSC - 09-19-2010, 05:35 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 09-19-2010, 09:26 PM
RE: New Project - Skunkwerks EM9D - by Telecommbrkr - 09-19-2010, 11:58 PM
RE: New Project - Skunkwerks EM9D - by 400Eric - 09-20-2010, 05:45 AM
RE: New Project - Skunkwerks EM9D - by Captain America - 09-20-2010, 03:11 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 09-20-2010, 04:09 PM
RE: New Project - Skunkwerks EM9D - by garage - 09-20-2010, 08:18 PM
RE: New Project - Skunkwerks EM9D - by 400Eric - 09-21-2010, 03:15 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 09-21-2010, 07:08 AM
RE: New Project - Skunkwerks EM9D - by Captain America - 09-21-2010, 12:44 PM
RE: New Project - Skunkwerks EM9D - by gsxr - 09-20-2010, 09:28 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 09-20-2010, 10:23 AM
RE: New Project - Skunkwerks EM9D - by Captain America - 09-20-2010, 09:09 PM
RE: New Project - Skunkwerks EM9D - by dropnosky - 09-21-2010, 12:15 PM
RE: New Project - Skunkwerks EM9D - by 400Eric - 09-22-2010, 04:17 AM
RE: New Project - Skunkwerks EM9D - by Captain America - 09-22-2010, 09:19 PM
RE: New Project - Skunkwerks EM9D - by J-Sauce - 09-23-2010, 12:38 AM
RE: New Project - Skunkwerks EM9D - by Captain America - 09-23-2010, 01:32 AM
RE: New Project - Skunkwerks EM9D - by J-Sauce - 09-23-2010, 01:49 AM
RE: New Project - Skunkwerks EM9D - by 400Eric - 09-23-2010, 02:30 AM
RE: New Project - Skunkwerks EM9D - by Captain America - 09-23-2010, 02:53 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 09-24-2010, 08:33 AM
RE: New Project - Skunkwerks EM9D - by ConnClark - 09-24-2010, 11:46 AM
RE: New Project - Skunkwerks EM9D - by Captain America - 09-24-2010, 12:11 PM
RE: New Project - Skunkwerks EM9D - by gsxr - 09-24-2010, 09:18 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 09-24-2010, 09:55 AM
RE: New Project - Skunkwerks EM9D - by Captain America - 09-24-2010, 09:52 AM
RE: New Project - Skunkwerks EM9D - by Deni - 09-24-2010, 03:51 PM
RE: New Project - Skunkwerks EM9D - by ForcedInduction - 09-24-2010, 04:59 PM
RE: New Project - Skunkwerks EM9D - by Jtn190D - 09-24-2010, 06:34 PM
RE: New Project - Skunkwerks EM9D - by ForcedInduction - 09-24-2010, 06:44 PM
RE: New Project - Skunkwerks EM9D - by supercharged3.0 - 09-25-2010, 03:13 AM
RE: New Project - Skunkwerks EM9D - by 400Eric - 09-25-2010, 04:53 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 09-25-2010, 09:44 AM
RE: New Project - Skunkwerks EM9D - by dropnosky - 09-25-2010, 11:28 AM
RE: New Project - Skunkwerks EM9D - by ForcedInduction - 09-25-2010, 07:50 PM
RE: New Project - Skunkwerks EM9D - by garage - 09-26-2010, 10:15 AM
RE: New Project - Skunkwerks EM9D - by Deni - 09-25-2010, 10:00 AM
RE: New Project - Skunkwerks EM9D - by 400Eric - 09-26-2010, 02:37 AM
RE: New Project - Skunkwerks EM9D - by willbhere4u - 09-26-2010, 12:36 PM
RE: New Project - Skunkwerks EM9D - by ForcedInduction - 09-26-2010, 01:43 PM
RE: New Project - Skunkwerks EM9D - by willbhere4u - 09-26-2010, 09:19 PM
RE: New Project - Skunkwerks EM9D - by ForcedInduction - 09-26-2010, 09:27 PM
RE: New Project - Skunkwerks EM9D - by turbodeezl - 09-30-2010, 12:48 PM
RE: New Project - Skunkwerks EM9D - by ForcedInduction - 10-02-2010, 05:25 AM
RE: New Project - Skunkwerks EM9D - by willbhere4u - 09-27-2010, 09:25 AM
RE: New Project - Skunkwerks EM9D - by SicNick - 10-01-2010, 05:43 PM
RE: New Project - Skunkwerks EM9D - by Captain America - 10-01-2010, 08:04 PM
RE: New Project - Skunkwerks EM9D - by 400Eric - 10-02-2010, 01:57 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 10-02-2010, 03:43 PM
RE: New Project - Skunkwerks EM9D - by Captain America - 10-02-2010, 02:08 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 10-02-2010, 07:14 PM
RE: New Project - Skunkwerks EM9D - by E300TSC - 10-02-2010, 09:19 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 10-02-2010, 09:26 PM
RE: New Project - Skunkwerks EM9D - by E300TSC - 10-03-2010, 09:23 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 10-03-2010, 09:31 AM
RE: New Project - Skunkwerks EM9D - by ForcedInduction - 10-03-2010, 10:21 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 10-03-2010, 12:18 PM
RE: New Project - Skunkwerks EM9D - by ConnClark - 10-18-2010, 11:32 AM
RE: New Project - Skunkwerks EM9D - by garage - 10-03-2010, 12:55 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 10-03-2010, 01:39 PM
RE: New Project - Skunkwerks EM9D - by garage - 10-03-2010, 02:49 PM
RE: New Project - Skunkwerks EM9D - by Captain America - 10-04-2010, 03:03 PM
RE: New Project - Skunkwerks EM9D - by garage - 10-04-2010, 04:10 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 10-09-2010, 10:57 AM
RE: New Project - Skunkwerks EM9D - by garage - 10-09-2010, 12:24 PM
RE: New Project - Skunkwerks EM9D - by ForcedInduction - 10-09-2010, 01:04 PM
RE: New Project - Skunkwerks EM9D - by dropnosky - 10-09-2010, 08:45 PM
RE: New Project - Skunkwerks EM9D - by Captain America - 10-09-2010, 03:18 PM
RE: New Project - Skunkwerks EM9D - by DeliveryValve - 10-09-2010, 09:54 PM
RE: New Project - Skunkwerks EM9D - by 400Eric - 10-09-2010, 10:59 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 10-10-2010, 04:12 PM
RE: New Project - Skunkwerks EM9D - by garage - 10-10-2010, 04:41 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 10-10-2010, 05:23 PM
RE: New Project - Skunkwerks EM9D - by ForcedInduction - 10-10-2010, 06:08 PM
RE: New Project - Skunkwerks EM9D - by garage - 10-10-2010, 06:50 PM
RE: New Project - Skunkwerks EM9D - by J-Sauce - 10-12-2010, 09:58 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 10-15-2010, 09:17 AM
RE: New Project - Skunkwerks EM9D - by willbhere4u - 10-15-2010, 10:27 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 10-15-2010, 10:42 AM
RE: New Project - Skunkwerks EM9D - by George3soccer - 10-15-2010, 11:02 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 10-15-2010, 12:59 PM
RE: New Project - Skunkwerks EM9D - by willbhere4u - 10-15-2010, 12:52 PM
RE: New Project - Skunkwerks EM9D - by Captain America - 10-15-2010, 02:09 PM
RE: New Project - Skunkwerks EM9D - by willbhere4u - 10-15-2010, 08:35 PM
RE: New Project - Skunkwerks EM9D - by 400Eric - 10-16-2010, 02:16 AM
RE: New Project - Skunkwerks EM9D - by ForcedInduction - 10-16-2010, 05:14 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 10-16-2010, 10:51 AM
RE: New Project - Skunkwerks EM9D - by willbhere4u - 10-16-2010, 12:04 PM
RE: New Project - Skunkwerks EM9D - by 400Eric - 10-16-2010, 11:52 PM
RE: New Project - Skunkwerks EM9D - by Captain America - 10-17-2010, 12:14 AM
RE: New Project - Skunkwerks EM9D - by 400Eric - 10-17-2010, 03:53 AM
RE: New Project - Skunkwerks EM9D - by garage - 10-17-2010, 11:07 AM
RE: New Project - Skunkwerks EM9D - by willbhere4u - 10-17-2010, 11:33 AM
RE: New Project - Skunkwerks EM9D - by Captain America - 10-17-2010, 12:22 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 10-17-2010, 02:05 PM
RE: New Project - Skunkwerks EM9D - by 400Eric - 10-17-2010, 11:55 PM
RE: New Project - Skunkwerks EM9D - by meareweird - 10-22-2010, 04:29 PM
RE: New Project - Skunkwerks EM9D - by garage - 10-22-2010, 06:12 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 10-22-2010, 07:21 PM
RE: New Project - Skunkwerks EM9D - by yankneck696 - 10-22-2010, 07:24 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 10-22-2010, 07:31 PM
RE: New Project - Skunkwerks EM9D - by willbhere4u - 10-22-2010, 08:10 PM
RE: New Project - Skunkwerks EM9D - by Captain America - 10-22-2010, 08:22 PM
RE: New Project - Skunkwerks EM9D - by 400Eric - 10-23-2010, 12:07 AM
RE: New Project - Skunkwerks EM9D - by ForcedInduction - 10-24-2010, 02:52 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 10-24-2010, 03:09 PM
RE: New Project - Skunkwerks EM9D - by garage - 10-23-2010, 10:41 AM
RE: New Project - Skunkwerks EM9D - by willbhere4u - 10-23-2010, 01:01 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 10-24-2010, 09:00 AM
RE: New Project - Skunkwerks EM9D - by willbhere4u - 10-24-2010, 12:10 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 10-24-2010, 12:17 PM
RE: New Project - Skunkwerks EM9D - by ForcedInduction - 10-24-2010, 03:36 PM
RE: New Project - Skunkwerks EM9D - by garage - 10-24-2010, 04:54 PM
RE: New Project - Skunkwerks EM9D - by E300TSC - 10-24-2010, 05:40 PM
RE: New Project - Skunkwerks EM9D - by J-Sauce - 10-24-2010, 09:22 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 10-24-2010, 09:33 PM
RE: New Project - Skunkwerks EM9D - by ForcedInduction - 10-24-2010, 09:39 PM
RE: New Project - Skunkwerks EM9D - by Captain America - 10-24-2010, 09:51 PM
RE: New Project - Skunkwerks EM9D - by gsxr - 10-30-2010, 11:24 AM
RE: New Project - Skunkwerks EM9D - by Captain America - 10-30-2010, 08:56 PM
RE: New Project - Skunkwerks EM9D - by ForcedInduction - 10-30-2010, 10:47 PM
RE: New Project - Skunkwerks EM9D - by 400Eric - 10-25-2010, 03:04 AM
RE: New Project - Skunkwerks EM9D - by Captain America - 10-25-2010, 11:09 AM
RE: New Project - Skunkwerks EM9D - by J-Sauce - 10-25-2010, 01:51 PM
RE: New Project - Skunkwerks EM9D - by J-Sauce - 10-25-2010, 03:08 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 10-25-2010, 03:43 PM
RE: New Project - Skunkwerks EM9D - by Captain America - 10-25-2010, 03:42 PM
RE: New Project - Skunkwerks EM9D - by 400Eric - 02-11-2011, 04:41 AM
RE: New Project - Skunkwerks EM9D - by garage - 02-11-2011, 03:31 PM
RE: New Project - Skunkwerks EM9D - by Captain America - 02-11-2011, 04:13 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 10-25-2010, 08:28 PM
RE: New Project - Skunkwerks EM9D - by garage - 10-25-2010, 08:41 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 10-25-2010, 09:24 PM
RE: New Project - Skunkwerks EM9D - by 400Eric - 10-25-2010, 11:08 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 10-26-2010, 07:10 AM
RE: New Project - Skunkwerks EM9D - by ConnClark - 10-26-2010, 12:18 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 10-26-2010, 02:05 PM
RE: New Project - Skunkwerks EM9D - by DeliveryValve - 10-26-2010, 02:38 PM
RE: New Project - Skunkwerks EM9D - by dropnosky - 10-26-2010, 03:16 PM
RE: New Project - Skunkwerks EM9D - by 400Eric - 10-27-2010, 12:55 AM
RE: New Project - Skunkwerks EM9D - by Silberpfeil - 10-27-2010, 09:46 PM
RE: New Project - Skunkwerks EM9D - by Biohazard - 10-26-2010, 12:29 PM
RE: New Project - Skunkwerks EM9D - by Biohazard - 10-26-2010, 08:04 PM
RE: New Project - Skunkwerks EM9D - by J-Sauce - 10-28-2010, 01:31 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 10-28-2010, 07:12 AM
RE: New Project - Skunkwerks EM9D - by Biohazard - 10-28-2010, 02:25 PM
RE: New Project - Skunkwerks EM9D - by yankneck696 - 10-28-2010, 03:12 PM
RE: New Project - Skunkwerks EM9D - by J-Sauce - 10-28-2010, 11:42 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 10-29-2010, 06:12 AM
RE: New Project - Skunkwerks EM9D - by stan - 10-29-2010, 06:34 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 10-29-2010, 06:44 AM
RE: New Project - Skunkwerks EM9D - by ConnClark - 10-29-2010, 10:56 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 10-29-2010, 10:31 AM
RE: New Project - Skunkwerks EM9D - by 400Eric - 10-29-2010, 11:08 PM
RE: New Project - Skunkwerks EM9D - by 400Eric - 10-30-2010, 02:24 AM
RE: New Project - Skunkwerks EM9D - by Captain America - 10-30-2010, 02:43 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 10-30-2010, 07:39 AM
RE: New Project - Skunkwerks EM9D - by willbhere4u - 10-30-2010, 11:20 PM
RE: New Project - Skunkwerks EM9D - by Captain America - 10-31-2010, 01:09 AM
RE: New Project - Skunkwerks EM9D - by 300D50 - 10-31-2010, 03:29 AM
RE: New Project - Skunkwerks EM9D - by gsxr - 10-31-2010, 05:14 PM
RE: New Project - Skunkwerks EM9D - by 300D50 - 10-31-2010, 09:32 PM
RE: New Project - Skunkwerks EM9D - by willbhere4u - 11-01-2010, 09:35 AM
RE: New Project - Skunkwerks EM9D - by 300SD81 - 11-02-2010, 11:48 AM
RE: New Project - Skunkwerks EM9D - by 300D50 - 11-02-2010, 12:06 PM
RE: New Project - Skunkwerks EM9D - by Captain America - 11-02-2010, 08:26 PM
RE: New Project - Skunkwerks EM9D - by 400Eric - 11-06-2010, 03:09 AM
RE: New Project - Skunkwerks EM9D - by garage - 11-25-2010, 01:38 PM
RE: New Project - Skunkwerks EM9D - by supercharged3.0 - 12-03-2010, 11:42 PM
RE: New Project - Skunkwerks EM9D - by 300SD_KY - 12-11-2010, 11:11 AM
RE: New Project - Skunkwerks EM9D - by garage - 12-11-2010, 02:21 PM
RE: New Project - Skunkwerks EM9D - by 400Eric - 12-15-2010, 04:03 AM
RE: New Project - Skunkwerks EM9D - by meareweird - 01-10-2011, 08:58 PM
RE: New Project - Skunkwerks EM9D - by ForcedInduction - 01-11-2011, 12:22 AM
RE: New Project - Skunkwerks EM9D - by supercharged3.0 - 01-11-2011, 01:46 AM
RE: New Project - Skunkwerks EM9D - by Captain America - 01-11-2011, 02:44 AM
RE: New Project - Skunkwerks EM9D - by ben2go - 01-11-2011, 07:45 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 01-11-2011, 08:17 AM
RE: New Project - Skunkwerks EM9D - by gsxr - 01-11-2011, 10:16 AM
RE: New Project - Skunkwerks EM9D - by 300SD_KY - 01-21-2011, 07:16 PM
RE: New Project - Skunkwerks EM9D - by ForcedInduction - 02-12-2011, 06:38 AM
RE: New Project - Skunkwerks EM9D - by 400Eric - 02-11-2011, 11:37 PM
RE: New Project - Skunkwerks EM9D - by Spaceraver - 02-17-2011, 12:26 PM
RE: New Project - Skunkwerks EM9D - by Captain America - 02-17-2011, 05:55 PM
RE: New Project - Skunkwerks EM9D - by ForcedInduction - 02-17-2011, 06:04 PM
RE: New Project - Skunkwerks EM9D - by led-panzer - 02-17-2011, 07:47 PM
RE: New Project - Skunkwerks EM9D - by Captain America - 02-17-2011, 10:49 PM
RE: New Project - Skunkwerks EM9D - by willbhere4u - 02-18-2011, 12:53 PM
RE: New Project - Skunkwerks EM9D - by garage - 02-24-2011, 04:28 PM
RE: New Project - Skunkwerks EM9D - by winmutt - 02-28-2011, 11:38 AM
RE: New Project - Skunkwerks EM9D - by supercharged3.0 - 03-16-2011, 02:08 AM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 03-16-2011, 07:11 AM
RE: New Project - Skunkwerks EM9D - by mike-81-240d - 03-16-2011, 12:38 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 03-16-2011, 01:44 PM
RE: New Project - Skunkwerks EM9D - by ConnClark - 03-16-2011, 01:58 PM
RE: New Project - Skunkwerks EM9D - by winmutt - 03-16-2011, 03:26 PM
RE: New Project - Skunkwerks EM9D - by garage - 03-16-2011, 09:36 AM
RE: New Project - Skunkwerks EM9D - by garage - 04-11-2011, 07:23 PM
RE: New Project - Skunkwerks EM9D - by SurfRodder - 04-11-2011, 11:38 PM
RE: New Project - Skunkwerks EM9D - by led-panzer - 07-13-2011, 09:48 AM
RE: New Project - Skunkwerks EM9D - by Captain America - 07-13-2011, 01:36 PM
RE: New Project - Skunkwerks EM9D - by led-panzer - 07-13-2011, 02:58 PM
RE: New Project - Skunkwerks EM9D - by 300D50 - 07-13-2011, 03:02 PM
RE: New Project - Skunkwerks EM9D - by led-panzer - 07-13-2011, 03:37 PM
RE: New Project - Skunkwerks EM9D - by Captain America - 07-13-2011, 04:27 PM
RE: New Project - Skunkwerks EM9D - by led-panzer - 07-13-2011, 04:52 PM
RE: New Project - Skunkwerks EM9D - by Captain America - 07-14-2011, 02:19 PM
RE: New Project - Skunkwerks EM9D - by Rudolf_Diesel - 07-14-2011, 02:36 PM
RE: New Project - Skunkwerks EM9D - by ben2go - 12-01-2011, 10:51 PM
RE: New Project - Skunkwerks EM9D - by garage - 12-01-2011, 11:27 PM
RE: New Project - Skunkwerks EM9D - by ben2go - 12-01-2011, 11:40 PM
RE: New Project - Skunkwerks EM9D - by garage - 12-02-2011, 09:17 PM
RE: New Project - Skunkwerks EM9D - by Cole - 08-29-2012, 01:22 PM
RE: New Project - Skunkwerks EM9D - by supercharged3.0 - 10-17-2012, 12:29 AM
RE: New Project - Skunkwerks EM9D - by aaa - 10-17-2012, 12:36 AM
RE: New Project - Skunkwerks EM9D - by Hario' - 08-13-2014, 10:55 AM
 15 Guest(s)
 15 Guest(s)
