STD Tuning Engine Holset HX35 Install info on om603
  • 4 Vote(s) - 4.5 Average
08-20-2010, 04:42 PM #62
(08-20-2010, 07:15 AM)muuris I haven't had HY35 in mine
Then why are you on a "have you done it yourself" rampage?
Quote:It makes a hell of an ugly noise, the engine dies for few seconds (smokes blue, shakes, no power etc). When this happens under hard acceleration (small gear) it may even stall the engine. After a minute everything is ok and engine runs normally.
Sounds like the pressure is affecting the old hardened stem seals and they're binding or allowing liquid oil to get through.
What is the spring-rate of the original springs and the stronger ones you installed? I can't find the specs in my OM604/5/6 FSM.
Do you know the spring-rate of VNT equipped engines like the OM647/8?
OM617
589N=132lb
OM60x
790N=177lb
This post was last modified: 08-20-2010, 04:54 PM by ForcedInduction.
OM617
589N=132lb
OM60x
790N=177lb
Messages In This Thread
Holset HX35 Install info on om603 - by jonbobshinigin - 08-10-2010, 11:48 AM
RE: Holset HY35 Install info on om603 - by muuris - 08-10-2010, 12:55 PM
RE: Holset HY35 Install info on om603 - by ForcedInduction - 08-10-2010, 05:29 PM
RE: Holset HY35 Install info on om603 - by jonbobshinigin - 08-10-2010, 01:26 PM
RE: Holset HY35 Install info on om603 - by muuris - 08-11-2010, 01:21 PM
RE: Holset HY35 Install info on om603 - by jeemu - 08-11-2010, 01:58 PM
RE: Holset HY35 Install info on om603 - by jonbobshinigin - 08-11-2010, 02:10 PM
RE: Holset HY35 Install info on om603 - by muuris - 08-12-2010, 01:21 PM
RE: Holset HY35 Install info on om603 - by jonbobshinigin - 08-12-2010, 01:52 PM
RE: Holset HY35 Install info on om603 - by jonbobshinigin - 08-16-2010, 01:01 AM
RE: Holset HY35 Install info on om603 - by jeemu - 08-16-2010, 05:31 AM
RE: Holset HY35 Install info on om603 - by ForcedInduction - 08-16-2010, 06:45 AM
RE: Holset HY35 Install info on om603 - by 95e300dez - 08-16-2010, 10:10 AM
RE: Holset HY35 Install info on om603 - by gsxr - 08-16-2010, 01:41 PM
RE: Holset HY35 Install info on om603 - by jonbobshinigin - 08-16-2010, 02:28 PM
RE: Holset HY35 Install info on om603 - by ForcedInduction - 08-16-2010, 03:19 PM
RE: Holset HY35 Install info on om603 - by jeemu - 08-18-2010, 02:05 PM
RE: Holset HY35 Install info on om603 - by ForcedInduction - 08-18-2010, 04:04 PM
RE: Holset HY35 Install info on om603 - by 95e300dez - 08-18-2010, 04:44 PM
RE: Holset HY35 Install info on om603 - by jeemu - 08-18-2010, 04:53 PM
RE: Holset HY35 Install info on om603 - by ForcedInduction - 08-18-2010, 05:03 PM
RE: Holset HY35 Install info on om603 - by jeemu - 08-18-2010, 05:21 PM
RE: Holset HY35 Install info on om603 - by jonbobshinigin - 08-16-2010, 04:03 PM
RE: Holset HY35 Install info on om603 - by winmutt - 08-16-2010, 05:54 PM
RE: Holset HY35 Install info on om603 - by jonbobshinigin - 08-16-2010, 06:02 PM
RE: Holset HY35 Install info on om603 - by ForcedInduction - 08-16-2010, 06:05 PM
RE: Holset HY35 Install info on om603 - by willbhere4u - 08-16-2010, 08:59 PM
RE: Holset HY35 Install info on om603 - by gsxr - 08-17-2010, 09:58 AM
RE: Holset HY35 Install info on om603 - by jonbobshinigin - 08-17-2010, 10:17 AM
RE: Holset HY35 Install info on om603 - by ForcedInduction - 08-17-2010, 06:12 PM
RE: Holset HY35 Install info on om603 - by gsxr - 08-17-2010, 07:00 PM
RE: Holset HY35 Install info on om603 - by ForcedInduction - 08-17-2010, 07:04 PM
RE: Holset HY35 Install info on om603 - by gsxr - 08-17-2010, 07:17 PM
RE: Holset HY35 Install info on om603 - by ForcedInduction - 08-17-2010, 07:28 PM
RE: Holset HY35 Install info on om603 - by jonbobshinigin - 08-18-2010, 02:19 PM
RE: Holset HY35 Install info on om603 - by 95e300dez - 08-18-2010, 03:01 PM
RE: Holset HY35 Install info on om603 - by jeemu - 08-18-2010, 03:13 PM
RE: Holset HY35 Install info on om603 - by ForcedInduction - 08-18-2010, 05:28 PM
RE: Holset HY35 Install info on om603 - by jeemu - 08-18-2010, 05:30 PM
RE: Holset HY35 Install info on om603 - by ForcedInduction - 08-19-2010, 06:56 AM
RE: Holset HY35 Install info on om603 - by jonbobshinigin - 08-18-2010, 09:51 PM
RE: Holset HY35 Install info on om603 - by MJF - 08-18-2010, 10:27 PM
RE: Holset HY35 Install info on om603 - by jonbobshinigin - 08-18-2010, 10:47 PM
RE: Holset HY35 Install info on om603 - by muuris - 08-19-2010, 09:04 AM
RE: Holset HY35 Install info on om603 - by ForcedInduction - 08-19-2010, 02:12 PM
RE: Holset HY35 Install info on om603 - by HughF_UK - 08-19-2010, 10:03 AM
RE: Holset HY35 Install info on om603 - by muuris - 08-19-2010, 12:20 PM
RE: Holset HY35 Install info on om603 - by jeemu - 08-19-2010, 05:15 PM
RE: Holset HY35 Install info on om603 - by gsxr - 08-19-2010, 05:29 PM
RE: Holset HY35 Install info on om603 - by 95e300dez - 08-19-2010, 06:55 PM
RE: Holset HY35 Install info on om603 - by jonbobshinigin - 08-19-2010, 09:12 PM
RE: Holset HY35 Install info on om603 - by winmutt - 08-20-2010, 05:40 AM
RE: Holset HY35 Install info on om603 - by 95e300dez - 08-19-2010, 10:52 PM
RE: Holset HY35 Install info on om603 - by muuris - 08-19-2010, 11:11 PM
RE: Holset HY35 Install info on om603 - by ForcedInduction - 08-20-2010, 06:44 AM
RE: Holset HY35 Install info on om603 - by muuris - 08-20-2010, 07:15 AM
RE: Holset HY35 Install info on om603 - by Alastair E - 08-20-2010, 08:53 AM
RE: Holset HY35 Install info on om603 - by ForcedInduction - 08-20-2010, 04:42 PM
RE: Holset HY35 Install info on om603 - by jeemu - 08-20-2010, 04:54 PM
RE: Holset HY35 Install info on om603 - by ForcedInduction - 08-20-2010, 04:56 PM
RE: Holset HY35 Install info on om603 - by jeemu - 08-20-2010, 05:00 PM
RE: Holset HY35 Install info on om603 - by Alastair E - 08-20-2010, 03:41 AM
RE: Holset HY35 Install info on om603 - by jeemu - 08-20-2010, 01:30 PM
RE: Holset HY35 Install info on om603 - by Alastair E - 08-20-2010, 03:01 PM
RE: Holset HY35 Install info on om603 - by jeemu - 08-20-2010, 03:36 PM
RE: Holset HY35 Install info on om603 - by gsxr - 08-20-2010, 05:04 PM
RE: Holset HY35 Install info on om603 - by ForcedInduction - 08-20-2010, 05:05 PM
RE: Holset HY35 Install info on om603 - by jeemu - 08-20-2010, 05:26 PM
RE: Holset HY35 Install info on om603 - by ForcedInduction - 08-21-2010, 03:13 PM
RE: Holset HY35 Install info on om603 - by jeemu - 08-21-2010, 04:42 PM
RE: Holset HY35 Install info on om603 - by ForcedInduction - 08-22-2010, 02:48 PM
RE: Holset HY35 Install info on om603 - by jonbobshinigin - 08-21-2010, 08:08 PM
RE: Holset HY35 Install info on om603 - by muuris - 08-22-2010, 01:38 AM
RE: Holset HY35 Install info on om603 - by jonbobshinigin - 08-22-2010, 03:28 PM
RE: Holset HY35 Install info on om603 - by ForcedInduction - 08-22-2010, 03:35 PM
RE: Holset HY35 Install info on om603 - by muuris - 08-23-2010, 08:17 AM
RE: Holset HY35 Install info on om603 - by mbenzo300td - 08-23-2010, 01:30 AM
RE: Holset HY35 Install info on om603 - by jonbobshinigin - 08-23-2010, 04:02 AM
RE: Holset HY35 Install info on om603 - by jonbobshinigin - 08-23-2010, 08:43 AM
RE: Holset HY35 Install info on om603 - by Alastair E - 08-23-2010, 10:08 AM
RE: Holset HY35 Install info on om603 - by ForcedInduction - 08-23-2010, 05:58 PM
RE: Holset HY35 Install info on om603 - by jonbobshinigin - 08-23-2010, 10:19 AM
RE: Holset HY35 Install info on om603 - by jeemu - 08-23-2010, 11:34 AM
RE: Holset HY35 Install info on om603 - by mbenzo300td - 08-23-2010, 12:10 PM
RE: Holset HY35 Install info on om603 - by George3soccer - 08-23-2010, 12:11 PM
RE: Holset HY35 Install info on om603 - by jonbobshinigin - 08-23-2010, 12:51 PM
RE: Holset HY35 Install info on om603 - by mbenzo300td - 08-23-2010, 04:34 PM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 08-23-2010, 04:52 PM
RE: Holset HX35 Install info on om603 - by George3soccer - 08-23-2010, 04:54 PM
RE: Holset HX35 Install info on om603 - by 95e300dez - 08-23-2010, 09:20 PM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 08-23-2010, 09:38 PM
RE: Holset HX35 Install info on om603 - by muuris - 08-24-2010, 12:27 AM
RE: Holset HX35 Install info on om603 - by ForcedInduction - 08-24-2010, 07:08 AM
RE: Holset HX35 Install info on om603 - by Alastair E - 08-24-2010, 04:05 AM
RE: Holset HX35 Install info on om603 - by jeemu - 08-24-2010, 07:14 AM
RE: Holset HX35 Install info on om603 - by Rudolf_Diesel - 08-24-2010, 07:20 AM
RE: Holset HX35 Install info on om603 - by muuris - 08-24-2010, 08:38 AM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 08-24-2010, 08:53 AM
RE: Holset HX35 Install info on om603 - by jeemu - 08-24-2010, 10:27 AM
RE: Holset HX35 Install info on om603 - by mbenzo300td - 08-24-2010, 01:01 PM
RE: Holset HX35 Install info on om603 - by jeemu - 08-24-2010, 01:39 PM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 08-24-2010, 02:25 PM
RE: Holset HX35 Install info on om603 - by jeemu - 08-24-2010, 02:33 PM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 08-24-2010, 03:01 PM
RE: Holset HX35 Install info on om603 - by jeemu - 08-24-2010, 03:10 PM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 08-24-2010, 06:58 PM
RE: Holset HX35 Install info on om603 - by gsxr - 08-24-2010, 09:40 PM
RE: Holset HX35 Install info on om603 - by aaa - 08-24-2010, 10:16 PM
RE: Holset HX35 Install info on om603 - by jeemu - 08-25-2010, 01:27 AM
RE: Holset HX35 Install info on om603 - by ForcedInduction - 08-25-2010, 06:20 AM
RE: Holset HX35 Install info on om603 - by muuris - 08-25-2010, 08:06 AM
RE: Holset HX35 Install info on om603 - by muuris - 08-26-2010, 04:21 AM
RE: Holset HX35 Install info on om603 - by ForcedInduction - 08-26-2010, 08:02 AM
RE: Holset HX35 Install info on om603 - by muuris - 08-26-2010, 08:31 AM
RE: Holset HX35 Install info on om603 - by winmutt - 08-26-2010, 08:58 AM
RE: Holset HX35 Install info on om603 - by tomnik - 08-26-2010, 09:28 AM
RE: Holset HX35 Install info on om603 - by muuris - 08-26-2010, 09:35 AM
RE: Holset HX35 Install info on om603 - by ForcedInduction - 08-26-2010, 05:10 PM
RE: Holset HX35 Install info on om603 - by muuris - 08-27-2010, 01:06 AM
RE: Holset HX35 Install info on om603 - by ForcedInduction - 08-27-2010, 05:35 AM
RE: Holset HX35 Install info on om603 - by gsxr - 08-25-2010, 08:44 AM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 08-24-2010, 10:19 PM
RE: Holset HX35 Install info on om603 - by gsxr - 08-24-2010, 10:54 PM
RE: Holset HX35 Install info on om603 - by winmutt - 08-25-2010, 04:34 PM
RE: Holset HX35 Install info on om603 - by jeemu - 08-25-2010, 04:46 PM
RE: Holset HX35 Install info on om603 - by ForcedInduction - 08-25-2010, 07:15 PM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 08-25-2010, 06:54 PM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 08-25-2010, 07:55 PM
RE: Holset HX35 Install info on om603 - by gsxr - 08-25-2010, 09:17 PM
RE: Holset HX35 Install info on om603 - by Captain America - 08-26-2010, 12:47 AM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 08-31-2010, 10:48 PM
RE: Holset HX35 Install info on om603 - by George3soccer - 09-01-2010, 09:05 AM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 09-01-2010, 01:55 PM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 10-29-2010, 12:59 PM
RE: Holset HX35 Install info on om603 - by willbhere4u - 10-29-2010, 01:39 PM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 10-29-2010, 01:44 PM
RE: Holset HX35 Install info on om603 - by willbhere4u - 10-29-2010, 04:34 PM
RE: Holset HX35 Install info on om603 - by E300TSC - 10-30-2010, 07:12 AM
RE: Holset HX35 Install info on om603 - by ForcedInduction - 10-30-2010, 07:52 AM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 10-30-2010, 03:33 PM
RE: Holset HX35 Install info on om603 - by ForcedInduction - 10-30-2010, 04:01 PM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 10-30-2010, 05:31 PM
RE: Holset HX35 Install info on om603 - by willbhere4u - 10-30-2010, 08:06 PM
RE: Holset HX35 Install info on om603 - by ForcedInduction - 10-30-2010, 11:03 PM
RE: Holset HX35 Install info on om603 - by willbhere4u - 10-30-2010, 11:18 PM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 10-30-2010, 11:29 PM
RE: Holset HX35 Install info on om603 - by ForcedInduction - 10-30-2010, 11:53 PM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 11-01-2010, 10:54 AM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 01-08-2011, 04:47 PM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 02-07-2011, 10:46 AM
RE: Holset HX35 Install info on om603 - by casioqv - 02-07-2011, 03:05 PM
RE: Holset HX35 Install info on om603 - by winmutt - 02-07-2011, 03:00 PM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 02-07-2011, 03:09 PM
RE: Holset HX35 Install info on om603 - by casioqv - 02-07-2011, 03:13 PM
RE: Holset HX35 Install info on om603 - by ForcedInduction - 02-07-2011, 04:01 PM
RE: Holset HX35 Install info on om603 - by casioqv - 02-07-2011, 04:17 PM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 02-07-2011, 04:07 PM
RE: Holset HX35 Install info on om603 - by ForcedInduction - 02-08-2011, 05:09 AM
RE: Holset HX35 Install info on om603 - by casioqv - 02-08-2011, 02:18 PM
RE: Holset HX35 Install info on om603 - by ForcedInduction - 02-08-2011, 02:32 PM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 02-08-2011, 10:42 AM
RE: Holset HX35 Install info on om603 - by ForcedInduction - 02-08-2011, 01:37 PM
RE: Holset HX35 Install info on om603 - by winmutt - 02-08-2011, 10:49 AM
RE: Holset HX35 Install info on om603 - by jeemu - 02-08-2011, 03:28 PM
RE: Holset HX35 Install info on om603 - by gsxr - 02-09-2011, 06:00 PM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 03-08-2011, 11:57 AM
RE: Holset HX35 Install info on om603 - by winmutt - 03-08-2011, 12:18 PM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 03-08-2011, 12:43 PM
RE: Holset HX35 Install info on om603 - by gsxr - 03-08-2011, 04:55 PM
RE: Holset HX35 Install info on om603 - by winmutt - 03-09-2011, 10:38 AM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 03-09-2011, 04:40 PM
RE: Holset HX35 Install info on om603 - by frodes - 03-12-2011, 10:03 AM
RE: Holset HX35 Install info on om603 - by ForcedInduction - 03-12-2011, 10:27 AM
RE: Holset HX35 Install info on om603 - by frodes - 03-12-2011, 12:28 PM
RE: Holset HX35 Install info on om603 - by ForcedInduction - 03-13-2011, 01:24 AM
RE: Holset HX35 Install info on om603 - by gsxr - 03-13-2011, 10:56 AM
RE: Holset HX35 Install info on om603 - by frodes - 03-13-2011, 02:29 PM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 03-13-2011, 12:14 AM
RE: Holset HX35 Install info on om603 - by wlockerb - 03-13-2011, 03:31 AM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 03-13-2011, 11:49 AM
RE: Holset HX35 Install info on om603 - by gsxr - 03-13-2011, 11:55 AM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 03-13-2011, 03:09 PM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 03-13-2011, 11:17 PM
RE: Holset HX35 Install info on om603 - by gsxr - 03-14-2011, 06:24 PM
RE: Holset HX35 Install info on om603 - by frodes - 03-24-2011, 09:02 AM
RE: Holset HX35 Install info on om603 - by Einar - 03-30-2011, 10:48 AM
RE: Holset HX35 Install info on om603 - by frodes - 03-30-2011, 03:07 PM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 08-23-2011, 10:00 PM
RE: Holset HX35 Install info on om603 - by winmutt - 08-24-2011, 05:46 AM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 08-24-2011, 08:52 AM
RE: Holset HX35 Install info on om603 - by winmutt - 08-24-2011, 09:08 AM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 08-24-2011, 09:25 AM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 04-08-2018, 12:48 PM
RE: Holset HX35 Install info on om603 - by awsrock - 04-08-2018, 05:49 PM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 04-08-2018, 11:14 PM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 05-19-2018, 11:57 PM
RE: Holset HX35 Install info on om603 - by awsrock - 05-20-2018, 01:39 AM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 05-22-2018, 05:33 PM
 7 Guest(s)
 7 Guest(s)
