STD Tuning Engine Holset HX35 Install info on om603
  • 4 Vote(s) - 4.5 Average
jonbobshinigin
08-10-2010, 11:48 AM #1
(Originally this post for for an HY35 install, but as you read you will see why I changed to using an HX35)
I am planning on installing my HY35 and W140 Euro Manifold onto my stock 1987 300TDT. I would like to install this and get some numbers; at least do some runs of my iPhone's "Dynolicious" program which has accurately assessed my car at 145HP and clocks my 0-60. Better than nothing! Then I would like to add a 3" straight pipe and run numbers again. All of which will be documented on this site.
This is my first time doing something like this. I will be doing it at a friends shop most likely and he knows quite a bit about turbos and is a good mechanic. I also have access to a Fab shop and people that can weld, cut, plasma table, shear, brake, etc.
Parts list (feel free to add):
- Gasket for Exhaust Manifold to Head
- Gasket for Turbo to Manifold
- Bolts and Nuts for Manifold and Turbo (Do I need these?)
Questions:
- Since the Euro manifold put the Turbo on top, will I need to re-clock the turbo for ports to aim proper direction?
- How will I need to accommodate for an oil line? My guess is the the stock ones will not line up.
- What is the best way to connect the 4" downpipe to my existing exhaust?
- On the intake size, where can I find the tubing I need to go from Air Filter to Intake Port?
- Eventually I will put in an Intercooler, but in the meantime, how do I get the Crossover pipe to connect to HY35?
See signature for car profile:
This post was last modified: 08-23-2010, 03:24 PM by jonbobshinigin.
1987 300TDT - 260,000 Miles
jonbobshinigin
Questions:
Messages In This Thread
Holset HX35 Install info on om603 - by jonbobshinigin - 08-10-2010, 11:48 AM
RE: Holset HY35 Install info on om603 - by muuris - 08-10-2010, 12:55 PM
RE: Holset HY35 Install info on om603 - by ForcedInduction - 08-10-2010, 05:29 PM
RE: Holset HY35 Install info on om603 - by jonbobshinigin - 08-10-2010, 01:26 PM
RE: Holset HY35 Install info on om603 - by muuris - 08-11-2010, 01:21 PM
RE: Holset HY35 Install info on om603 - by jeemu - 08-11-2010, 01:58 PM
RE: Holset HY35 Install info on om603 - by jonbobshinigin - 08-11-2010, 02:10 PM
RE: Holset HY35 Install info on om603 - by muuris - 08-12-2010, 01:21 PM
RE: Holset HY35 Install info on om603 - by jonbobshinigin - 08-12-2010, 01:52 PM
RE: Holset HY35 Install info on om603 - by jonbobshinigin - 08-16-2010, 01:01 AM
RE: Holset HY35 Install info on om603 - by jeemu - 08-16-2010, 05:31 AM
RE: Holset HY35 Install info on om603 - by ForcedInduction - 08-16-2010, 06:45 AM
RE: Holset HY35 Install info on om603 - by 95e300dez - 08-16-2010, 10:10 AM
RE: Holset HY35 Install info on om603 - by gsxr - 08-16-2010, 01:41 PM
RE: Holset HY35 Install info on om603 - by jonbobshinigin - 08-16-2010, 02:28 PM
RE: Holset HY35 Install info on om603 - by ForcedInduction - 08-16-2010, 03:19 PM
RE: Holset HY35 Install info on om603 - by jeemu - 08-18-2010, 02:05 PM
RE: Holset HY35 Install info on om603 - by ForcedInduction - 08-18-2010, 04:04 PM
RE: Holset HY35 Install info on om603 - by 95e300dez - 08-18-2010, 04:44 PM
RE: Holset HY35 Install info on om603 - by jeemu - 08-18-2010, 04:53 PM
RE: Holset HY35 Install info on om603 - by ForcedInduction - 08-18-2010, 05:03 PM
RE: Holset HY35 Install info on om603 - by jeemu - 08-18-2010, 05:21 PM
RE: Holset HY35 Install info on om603 - by jonbobshinigin - 08-16-2010, 04:03 PM
RE: Holset HY35 Install info on om603 - by winmutt - 08-16-2010, 05:54 PM
RE: Holset HY35 Install info on om603 - by jonbobshinigin - 08-16-2010, 06:02 PM
RE: Holset HY35 Install info on om603 - by ForcedInduction - 08-16-2010, 06:05 PM
RE: Holset HY35 Install info on om603 - by willbhere4u - 08-16-2010, 08:59 PM
RE: Holset HY35 Install info on om603 - by gsxr - 08-17-2010, 09:58 AM
RE: Holset HY35 Install info on om603 - by jonbobshinigin - 08-17-2010, 10:17 AM
RE: Holset HY35 Install info on om603 - by ForcedInduction - 08-17-2010, 06:12 PM
RE: Holset HY35 Install info on om603 - by gsxr - 08-17-2010, 07:00 PM
RE: Holset HY35 Install info on om603 - by ForcedInduction - 08-17-2010, 07:04 PM
RE: Holset HY35 Install info on om603 - by gsxr - 08-17-2010, 07:17 PM
RE: Holset HY35 Install info on om603 - by ForcedInduction - 08-17-2010, 07:28 PM
RE: Holset HY35 Install info on om603 - by jonbobshinigin - 08-18-2010, 02:19 PM
RE: Holset HY35 Install info on om603 - by 95e300dez - 08-18-2010, 03:01 PM
RE: Holset HY35 Install info on om603 - by jeemu - 08-18-2010, 03:13 PM
RE: Holset HY35 Install info on om603 - by ForcedInduction - 08-18-2010, 05:28 PM
RE: Holset HY35 Install info on om603 - by jeemu - 08-18-2010, 05:30 PM
RE: Holset HY35 Install info on om603 - by ForcedInduction - 08-19-2010, 06:56 AM
RE: Holset HY35 Install info on om603 - by jonbobshinigin - 08-18-2010, 09:51 PM
RE: Holset HY35 Install info on om603 - by MJF - 08-18-2010, 10:27 PM
RE: Holset HY35 Install info on om603 - by jonbobshinigin - 08-18-2010, 10:47 PM
RE: Holset HY35 Install info on om603 - by muuris - 08-19-2010, 09:04 AM
RE: Holset HY35 Install info on om603 - by ForcedInduction - 08-19-2010, 02:12 PM
RE: Holset HY35 Install info on om603 - by HughF_UK - 08-19-2010, 10:03 AM
RE: Holset HY35 Install info on om603 - by muuris - 08-19-2010, 12:20 PM
RE: Holset HY35 Install info on om603 - by jeemu - 08-19-2010, 05:15 PM
RE: Holset HY35 Install info on om603 - by gsxr - 08-19-2010, 05:29 PM
RE: Holset HY35 Install info on om603 - by 95e300dez - 08-19-2010, 06:55 PM
RE: Holset HY35 Install info on om603 - by jonbobshinigin - 08-19-2010, 09:12 PM
RE: Holset HY35 Install info on om603 - by winmutt - 08-20-2010, 05:40 AM
RE: Holset HY35 Install info on om603 - by 95e300dez - 08-19-2010, 10:52 PM
RE: Holset HY35 Install info on om603 - by muuris - 08-19-2010, 11:11 PM
RE: Holset HY35 Install info on om603 - by ForcedInduction - 08-20-2010, 06:44 AM
RE: Holset HY35 Install info on om603 - by muuris - 08-20-2010, 07:15 AM
RE: Holset HY35 Install info on om603 - by Alastair E - 08-20-2010, 08:53 AM
RE: Holset HY35 Install info on om603 - by ForcedInduction - 08-20-2010, 04:42 PM
RE: Holset HY35 Install info on om603 - by jeemu - 08-20-2010, 04:54 PM
RE: Holset HY35 Install info on om603 - by ForcedInduction - 08-20-2010, 04:56 PM
RE: Holset HY35 Install info on om603 - by jeemu - 08-20-2010, 05:00 PM
RE: Holset HY35 Install info on om603 - by Alastair E - 08-20-2010, 03:41 AM
RE: Holset HY35 Install info on om603 - by jeemu - 08-20-2010, 01:30 PM
RE: Holset HY35 Install info on om603 - by Alastair E - 08-20-2010, 03:01 PM
RE: Holset HY35 Install info on om603 - by jeemu - 08-20-2010, 03:36 PM
RE: Holset HY35 Install info on om603 - by gsxr - 08-20-2010, 05:04 PM
RE: Holset HY35 Install info on om603 - by ForcedInduction - 08-20-2010, 05:05 PM
RE: Holset HY35 Install info on om603 - by jeemu - 08-20-2010, 05:26 PM
RE: Holset HY35 Install info on om603 - by ForcedInduction - 08-21-2010, 03:13 PM
RE: Holset HY35 Install info on om603 - by jeemu - 08-21-2010, 04:42 PM
RE: Holset HY35 Install info on om603 - by ForcedInduction - 08-22-2010, 02:48 PM
RE: Holset HY35 Install info on om603 - by jonbobshinigin - 08-21-2010, 08:08 PM
RE: Holset HY35 Install info on om603 - by muuris - 08-22-2010, 01:38 AM
RE: Holset HY35 Install info on om603 - by jonbobshinigin - 08-22-2010, 03:28 PM
RE: Holset HY35 Install info on om603 - by ForcedInduction - 08-22-2010, 03:35 PM
RE: Holset HY35 Install info on om603 - by muuris - 08-23-2010, 08:17 AM
RE: Holset HY35 Install info on om603 - by mbenzo300td - 08-23-2010, 01:30 AM
RE: Holset HY35 Install info on om603 - by jonbobshinigin - 08-23-2010, 04:02 AM
RE: Holset HY35 Install info on om603 - by jonbobshinigin - 08-23-2010, 08:43 AM
RE: Holset HY35 Install info on om603 - by Alastair E - 08-23-2010, 10:08 AM
RE: Holset HY35 Install info on om603 - by ForcedInduction - 08-23-2010, 05:58 PM
RE: Holset HY35 Install info on om603 - by jonbobshinigin - 08-23-2010, 10:19 AM
RE: Holset HY35 Install info on om603 - by jeemu - 08-23-2010, 11:34 AM
RE: Holset HY35 Install info on om603 - by mbenzo300td - 08-23-2010, 12:10 PM
RE: Holset HY35 Install info on om603 - by George3soccer - 08-23-2010, 12:11 PM
RE: Holset HY35 Install info on om603 - by jonbobshinigin - 08-23-2010, 12:51 PM
RE: Holset HY35 Install info on om603 - by mbenzo300td - 08-23-2010, 04:34 PM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 08-23-2010, 04:52 PM
RE: Holset HX35 Install info on om603 - by George3soccer - 08-23-2010, 04:54 PM
RE: Holset HX35 Install info on om603 - by 95e300dez - 08-23-2010, 09:20 PM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 08-23-2010, 09:38 PM
RE: Holset HX35 Install info on om603 - by muuris - 08-24-2010, 12:27 AM
RE: Holset HX35 Install info on om603 - by ForcedInduction - 08-24-2010, 07:08 AM
RE: Holset HX35 Install info on om603 - by Alastair E - 08-24-2010, 04:05 AM
RE: Holset HX35 Install info on om603 - by jeemu - 08-24-2010, 07:14 AM
RE: Holset HX35 Install info on om603 - by Rudolf_Diesel - 08-24-2010, 07:20 AM
RE: Holset HX35 Install info on om603 - by muuris - 08-24-2010, 08:38 AM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 08-24-2010, 08:53 AM
RE: Holset HX35 Install info on om603 - by jeemu - 08-24-2010, 10:27 AM
RE: Holset HX35 Install info on om603 - by mbenzo300td - 08-24-2010, 01:01 PM
RE: Holset HX35 Install info on om603 - by jeemu - 08-24-2010, 01:39 PM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 08-24-2010, 02:25 PM
RE: Holset HX35 Install info on om603 - by jeemu - 08-24-2010, 02:33 PM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 08-24-2010, 03:01 PM
RE: Holset HX35 Install info on om603 - by jeemu - 08-24-2010, 03:10 PM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 08-24-2010, 06:58 PM
RE: Holset HX35 Install info on om603 - by gsxr - 08-24-2010, 09:40 PM
RE: Holset HX35 Install info on om603 - by aaa - 08-24-2010, 10:16 PM
RE: Holset HX35 Install info on om603 - by jeemu - 08-25-2010, 01:27 AM
RE: Holset HX35 Install info on om603 - by ForcedInduction - 08-25-2010, 06:20 AM
RE: Holset HX35 Install info on om603 - by muuris - 08-25-2010, 08:06 AM
RE: Holset HX35 Install info on om603 - by muuris - 08-26-2010, 04:21 AM
RE: Holset HX35 Install info on om603 - by ForcedInduction - 08-26-2010, 08:02 AM
RE: Holset HX35 Install info on om603 - by muuris - 08-26-2010, 08:31 AM
RE: Holset HX35 Install info on om603 - by winmutt - 08-26-2010, 08:58 AM
RE: Holset HX35 Install info on om603 - by tomnik - 08-26-2010, 09:28 AM
RE: Holset HX35 Install info on om603 - by muuris - 08-26-2010, 09:35 AM
RE: Holset HX35 Install info on om603 - by ForcedInduction - 08-26-2010, 05:10 PM
RE: Holset HX35 Install info on om603 - by muuris - 08-27-2010, 01:06 AM
RE: Holset HX35 Install info on om603 - by ForcedInduction - 08-27-2010, 05:35 AM
RE: Holset HX35 Install info on om603 - by gsxr - 08-25-2010, 08:44 AM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 08-24-2010, 10:19 PM
RE: Holset HX35 Install info on om603 - by gsxr - 08-24-2010, 10:54 PM
RE: Holset HX35 Install info on om603 - by winmutt - 08-25-2010, 04:34 PM
RE: Holset HX35 Install info on om603 - by jeemu - 08-25-2010, 04:46 PM
RE: Holset HX35 Install info on om603 - by ForcedInduction - 08-25-2010, 07:15 PM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 08-25-2010, 06:54 PM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 08-25-2010, 07:55 PM
RE: Holset HX35 Install info on om603 - by gsxr - 08-25-2010, 09:17 PM
RE: Holset HX35 Install info on om603 - by Captain America - 08-26-2010, 12:47 AM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 08-31-2010, 10:48 PM
RE: Holset HX35 Install info on om603 - by George3soccer - 09-01-2010, 09:05 AM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 09-01-2010, 01:55 PM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 10-29-2010, 12:59 PM
RE: Holset HX35 Install info on om603 - by willbhere4u - 10-29-2010, 01:39 PM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 10-29-2010, 01:44 PM
RE: Holset HX35 Install info on om603 - by willbhere4u - 10-29-2010, 04:34 PM
RE: Holset HX35 Install info on om603 - by E300TSC - 10-30-2010, 07:12 AM
RE: Holset HX35 Install info on om603 - by ForcedInduction - 10-30-2010, 07:52 AM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 10-30-2010, 03:33 PM
RE: Holset HX35 Install info on om603 - by ForcedInduction - 10-30-2010, 04:01 PM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 10-30-2010, 05:31 PM
RE: Holset HX35 Install info on om603 - by willbhere4u - 10-30-2010, 08:06 PM
RE: Holset HX35 Install info on om603 - by ForcedInduction - 10-30-2010, 11:03 PM
RE: Holset HX35 Install info on om603 - by willbhere4u - 10-30-2010, 11:18 PM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 10-30-2010, 11:29 PM
RE: Holset HX35 Install info on om603 - by ForcedInduction - 10-30-2010, 11:53 PM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 11-01-2010, 10:54 AM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 01-08-2011, 04:47 PM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 02-07-2011, 10:46 AM
RE: Holset HX35 Install info on om603 - by casioqv - 02-07-2011, 03:05 PM
RE: Holset HX35 Install info on om603 - by winmutt - 02-07-2011, 03:00 PM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 02-07-2011, 03:09 PM
RE: Holset HX35 Install info on om603 - by casioqv - 02-07-2011, 03:13 PM
RE: Holset HX35 Install info on om603 - by ForcedInduction - 02-07-2011, 04:01 PM
RE: Holset HX35 Install info on om603 - by casioqv - 02-07-2011, 04:17 PM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 02-07-2011, 04:07 PM
RE: Holset HX35 Install info on om603 - by ForcedInduction - 02-08-2011, 05:09 AM
RE: Holset HX35 Install info on om603 - by casioqv - 02-08-2011, 02:18 PM
RE: Holset HX35 Install info on om603 - by ForcedInduction - 02-08-2011, 02:32 PM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 02-08-2011, 10:42 AM
RE: Holset HX35 Install info on om603 - by ForcedInduction - 02-08-2011, 01:37 PM
RE: Holset HX35 Install info on om603 - by winmutt - 02-08-2011, 10:49 AM
RE: Holset HX35 Install info on om603 - by jeemu - 02-08-2011, 03:28 PM
RE: Holset HX35 Install info on om603 - by gsxr - 02-09-2011, 06:00 PM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 03-08-2011, 11:57 AM
RE: Holset HX35 Install info on om603 - by winmutt - 03-08-2011, 12:18 PM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 03-08-2011, 12:43 PM
RE: Holset HX35 Install info on om603 - by gsxr - 03-08-2011, 04:55 PM
RE: Holset HX35 Install info on om603 - by winmutt - 03-09-2011, 10:38 AM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 03-09-2011, 04:40 PM
RE: Holset HX35 Install info on om603 - by frodes - 03-12-2011, 10:03 AM
RE: Holset HX35 Install info on om603 - by ForcedInduction - 03-12-2011, 10:27 AM
RE: Holset HX35 Install info on om603 - by frodes - 03-12-2011, 12:28 PM
RE: Holset HX35 Install info on om603 - by ForcedInduction - 03-13-2011, 01:24 AM
RE: Holset HX35 Install info on om603 - by gsxr - 03-13-2011, 10:56 AM
RE: Holset HX35 Install info on om603 - by frodes - 03-13-2011, 02:29 PM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 03-13-2011, 12:14 AM
RE: Holset HX35 Install info on om603 - by wlockerb - 03-13-2011, 03:31 AM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 03-13-2011, 11:49 AM
RE: Holset HX35 Install info on om603 - by gsxr - 03-13-2011, 11:55 AM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 03-13-2011, 03:09 PM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 03-13-2011, 11:17 PM
RE: Holset HX35 Install info on om603 - by gsxr - 03-14-2011, 06:24 PM
RE: Holset HX35 Install info on om603 - by frodes - 03-24-2011, 09:02 AM
RE: Holset HX35 Install info on om603 - by Einar - 03-30-2011, 10:48 AM
RE: Holset HX35 Install info on om603 - by frodes - 03-30-2011, 03:07 PM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 08-23-2011, 10:00 PM
RE: Holset HX35 Install info on om603 - by winmutt - 08-24-2011, 05:46 AM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 08-24-2011, 08:52 AM
RE: Holset HX35 Install info on om603 - by winmutt - 08-24-2011, 09:08 AM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 08-24-2011, 09:25 AM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 04-08-2018, 12:48 PM
RE: Holset HX35 Install info on om603 - by awsrock - 04-08-2018, 05:49 PM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 04-08-2018, 11:14 PM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 05-19-2018, 11:57 PM
RE: Holset HX35 Install info on om603 - by awsrock - 05-20-2018, 01:39 AM
RE: Holset HX35 Install info on om603 - by jonbobshinigin - 05-22-2018, 05:33 PM
