Horsepower is just math
RE: OM617 Turbo intake
This is all nice, but its pretty much moot unless the head is ported. I can almost guarantee the flow past the intake valves is less than 336cfm.
The coupler is that shape for a reason. Look at the turbo's compressor housing and you'll see the coupler inlet is the same diameter as it's outlet. Unless you port the compressor housing as well it will greatly increase turbulence, not flow. Porting the housing would alter the A/R and mess with much more than CFM flow.
The W115 manifold eliminates all those restrictions, thats why everyone uses them.
Modifications: M-Pump, Holset HE341Ve VGT turbo, A/W intercooler, W115 300D intake, straight pipe exhaust, #265 nozzles, 2-micron Baldwin fuel filter, W126 Gen-II 300mm brakes, battery relocated to the trunk, HVAC systems removed, 15mm rear sway bar, 3.46 diff, Mobil1 15W-50 synthetic oil and Galant front seat.
Down for Holsetification.
Modifications: OM617.95, 4-speed manual, 2-micron Baldwin BF7591-D fuel filter, ALDA removed, no EGR, 3.07 diff, Amsoil EaBP 90 bypass oil filter, Mobil1 5W-40 synthetic oil.
![[Image: Dieselfuelforlife.gif]](http://members.cox.net/lnewcomb99/Pics/Dieselfuelforlife.gif)
| 06-22-2009 07:35 PM |
(06-23-2009 06:23 PM)Motorhead Wrote: The engine needs a long runner intake manifold
Thats why most of us try to get a W115 manifold.
The Non-turbo W123 manifold can work. I know it clears my 2256V turbo but I'm not sure if it will clear the stock T3 or others.
Quote:what is the latest word on the IP's?
I'm 75% through mounting my M-Pump right now. Later on I'll get the 6mm elements from a 99 E300 pump put into it until I feel like spending $1500 on Myna. The 6mm elements should be able to bring me to around 180hp at the crank (The E300 can do 220hp with a Speedtuning USA chip).
| 06-23-2009 09:20 PM |
Motorhead
(06-23-2009 09:20 PM)ForcedInduction Wrote: (06-23-2009 06:23 PM)Motorhead Wrote: The engine needs a long runner intake manifold
Man that is nice, I guess I will have to locate a factory N/A intake. Who is doing pumps here in the US or do we have to pop the $2+grand and have Myna do it?
Here is a pic of the coupler, when I put it in the intake the ports flowed the following.
Stock coupler: port # 1-139.3, 2-135.3, 3-139.5, 137.0, 5-130.5
Mod coupler : port # 1-159.2, 2-146.0, 3-152.6, 4-150.0, 5-145.0
(This post was last modified: 06-23-2009 10:36 PM by winmutt.)
| 06-23-2009 09:48 PM |
One idea I was working with was using a W115 or N/A intake, cutting off the plenum, getting a generic A/W intercooler and welding the outlet side of the intercooler to the runners as the new plenum.
Using one of these.
Kind of like this guy did (as an example after a quick search).
http://www.patrol4x4.com/forum/showthread.php?t=24057
| 06-24-2009 03:28 PM |
ConnClark
I'm going to be welding an A/W intercooler to my intake manifold when I get rid of my OxCat. I need a new turbo and some aluminum to practice my welding on first.
| 06-24-2009 05:30 PM |
Three; 75-76 W115, 76-81 W123 and Truck/Van (Like the W115 but with a forward pointing inlet).
Just the EGR and non for turbo manifolds.
| 06-25-2009 07:20 PM |
Wrong way. Its a totally different casting. I'll post a picture when I get home.
| 06-25-2009 10:28 PM |
| 06-26-2009 02:11 AM |
Yes, its from the 2/3/409D van/trucks. No, I don't have one.
| 06-26-2009 03:25 PM |
SixSpeed
Hey, what is the best year to snatch the intake from?
I see that there were a few different kinds.
Would a 74-76 300D Non-Turbo be the best way to go? I'm planning on running a small intercooler setup.
-Jack Miles : Tampa : Florida :
1963 Unimog 404 TLF-8 - OM617.951 Powered / 8-Speed / Doka Hardcab
1979 AM General M817 / 5-Ton 6x6 Dump truck / 855cu.in. of Cummins goodness.
Gassers - '79 500SE AMG #126 / '86 190e 2.3-16 / '87 190e 2.3-16 / '89 190e 2.6/5
| 06-30-2009 12:33 PM |
Motorhead
I flushes out as much sludge out of the intake as I could and set it on the flow bench, this intake is a must!
Total flow is 424.4 CFM@28" H2O STOCK
Cyl#1-179, 2-171, 3-167, 4-170, 5-169
The inlet lip had core shift and was thicker on one side than the other so I rolled and blended the lip, I did not spend more than 5 min. on it just to see what it would do.
Total flow after lip roll is 505.2 CFM@28" H2O
Cyl#1-181, 2-173, 3-173, 4-178, 5-170
I will put the intake into the hot tank and see if any cylinders come in better but I think this intake is perfect out of the box, the casting # on it is: R 617 141 02 01 it looks like ForcedInduction's intake.
| 06-30-2009 08:00 PM |
Yeah, MB had their reasons for using it on both the C111-II/III.
Remember that those CFMs are with atmospheric pressure flowing the air. Add a turbo with a 2.0 pressure ratio and I bet those numbers go much higher.
| 07-01-2009 02:55 AM |
Well, we know retarding the cam timing doesn't increase power. Advancing the timing to make up for chain wear brings back significant power. There is only about 2mm squish clearance to work with though.
| 07-01-2009 03:41 PM |
| 07-02-2009 06:34 PM |
