dual mass flywheel with pilot bearing removed
unaleman
I recently bought a 1994 e250d flywheel from UK e-bay with the idea that I would install it my 1987 300d with a five speed I salvaged from a 300e.
In the meantime I have been replacing a bad slave cylinder on a 1989 190e 2.6 with five speed. Soo... because I was not able to loosen the line to the slave, I ended up with the trans out of the car and, lo and behold, a dual mass flywheel that can not be turned. It also turns out that the flywheel I bought from the UK is also a dual mass flywheel. It is lighter than and has a pressure plate that is not as heavy duty as the 2.6 dual mass flywheel.
Since the five speed I have has the longer input shaft, I want to know if anyone has removed the pilot bearing from the center of a dual-mass and put the pilot bearing in the center of the crank shaft, old-style.
Can I install a '94 e250d dual mass flywheel, in the '87 300d with ('86) 5-speed with long input shaft?
| 03-02-2010 08:09 PM |
unaleman
RE: dual mass flywheel with pilot bearing removed
clarification. what I want to do is remove the pilot bearing from the e250d flywheel, which will allow the longer shaft of my '86 five speed to project through and engage with the pilot bearing that I will put in the crankshaft end as if it were a single mass flywheel application. I have the single mass flywheel from the 300e but most seem to think that the diesel flywheels weigh more and that diesel engines (om603 in my case) need the greater mass for idle and bottom end power which is why I was surprised to see that the 2.6 dual mass flywheel is heavier than the e250d dual mass and the pressure plate from the 2.6 is built heavier also. Maybe, as the 240d flywheel is not as heavy as the unobtanium 300d om617 flywheel, the e250d om602 five cylinder flywheel is not as stout as a om603 6 cylinder flywheel. The guy at the brake and clutch place knew by the solid disc that the flywheel was dual mass and when he looked up the car(2.6) he said that a clutch kit was 440.00.. flywheel, disc and throwout bearing which again was a surprise because my indie said just the flywheel was 770.00 I will try to post pics soon. thanks again for all thoughts and advice.
| 03-02-2010 10:21 PM |
