Coilovers
Turbo Wannabe
Coilovers
Ive seen pics of a w123 wagon, and a w116 with coilover setups.
Is this a option on some models... that could be swapped over?
Or a fully custom job?
-Betsy 1979 240D- WVO/Diesel mix, 4speed, Freeflowing intake, Straight pipe, ADA adjusted, Stage 3weight reduction, Extra in-line fuel filter, Auxiliary fuel tank, Roof rack, Steel wheels, 195/70R14 tires.. And a lead foot...
09-13-2009 04:37 PM
RE: Coilovers
(09-13-2009 04:37 PM)garage Wrote:  Ive seen pics of a w123 wagon, and a w116 with coilover setups.
where did you see this?
'83 300D **4 speed ** stainless flex oil cooler and brake lines ** powder coated valve cover, oil tower, and injection lines ** manual climate control ** better stereo ** homemade intake and monstercraftsman oil separator ** EGR Delete ** Euros and clear corners ** 4 light brake mod ** Vogtland 50mm drop front springs ** Lesjofors S600 drop rear springs ** 16" rims ** late model 126 brake spindles, rotors and calipers ** full suspension rehab ** Bilstein HDs ** AL129X alternator ** 1/0 starter and charging cables ** late W126 front seats and rear seat back
'87 Cherokee w/4.9L stroker motor
'94 Stealth TT -track car to be
'96 Mitsu 3KGT VR4 bit a show lotsa go
09-13-2009 07:17 PM
Turbo Wannabe
RE: Coilovers
I cannot remember where i saw the wagon at, when i fing it ill post it.
As far as the 116
http://www.topklasse.net.au/forums/showt...php?t=1636
2nd and 3rd picture.
Locked diff too!
hehe
09-13-2009 08:45 PM
ForcedInduction Online
RE: Coilovers
Those aren't coilovers, those are shocks inside the springs. The stock configuration.
(This post was last modified: 09-13-2009 09:29 PM by ForcedInduction.)
09-13-2009 09:29 PM
RE: Coilovers
(09-13-2009 08:45 PM)garage Wrote:  ...
OT- I dig the w116 wagon...
.jpg  W116Wagon.jpg (Size: 235 KB / Downloads: 389)
Addicted to W1xx and 617s Tongue
[Image: 973.gif]
09-14-2009 05:40 AM
Turbo Wannabe
RE: Coilovers
(09-13-2009 09:29 PM)ForcedInduction Wrote:  Those aren't coilovers, those are shocks inside the springs. The stock configuration.
If thats stock configuration, why isnt my 116 like that?
I have shocks besides the coil.
I know right, talk about rare.
(This post was last modified: 09-14-2009 12:22 PM by garage.)
09-14-2009 12:21 PM
RE: Coilovers
(09-14-2009 12:21 PM)garage Wrote:  If thats stock configuration, why isnt my 116 like that?
On the front, yes.
09-14-2009 12:50 PM
Turbo Wannabe
RE: Coilovers
Geez, well im just talking nonsense then.
Your right.
Well has that been heard of at all on these cars(coilovers)??
09-14-2009 03:05 PM
charmalu Offline
RE: Coilovers
(09-13-2009 08:45 PM)garage Wrote:  I cannot remember where i saw the wagon at, when i fing it ill post it.
As far as the 116
Locked diff too!
hehe
That 4th picture looks like the Aluminium trailing arms from a W126.
these were discussed over on Peachparts a while back. thought the
consenses was they wouldn`t fit.
Were they available for the w123 in other markets?
Charlie
09-18-2009 09:26 PM
winmutt Online
RE: Coilovers
This is a 116.
09-19-2009 06:52 AM
RE: Coilovers
Actually, if someone were willing to do the research, I'm pretty sure one could cobble together a coilover system for these cars using coilovers designed for other applications. It would be a matter of getting the right spring length figured out and mounting it. As far as shock settings and spring rates go you have your pick. I had a cheap set of Korean K-sport coilovers on my SE-R and it was a phenomenal difference in a car that had very good essentials from the factory already. Although the K-sports had pillow ball mounts, built in camber plates and came with Heim jointed endlinks for the rear sway bar, too.
I think that if someone were willing to do the homework, this is quite feasible for our cars and would certainly be a step up from cutting springs and whatnot.
10-04-2009 11:49 PM
RE: Coilovers
What are people's thoughts on using the existing shock mounts as coilover mounting points?
02-17-2010 05:30 PM
Secondaries Offline
RE: Coilovers
(02-17-2010 05:30 PM)tantank79 Wrote:  What are people's thoughts on using the existing shock mounts as coilover mounting points?
Generally not a good idea. Shock mounting points were meant to be used only for damping, not for load bearing. The A-arms and trailing arms were probably designed to have the spring mounted in its cup only. There are other ways to get coil over adjustability, though...
02-17-2010 11:03 PM
RE: Coilovers
(02-17-2010 11:03 PM)Secondaries Wrote:  There are other ways to get coil over adjustability, though...
Like...?
02-18-2010 09:16 AM
RE: Coilovers
Look up some GM G bodies and the like with coilovers, while the systems are far from identical it's still upper and lower A's and the adaptation process would be similar.
That would be something to look into...adapting a QA1 coilover kit from another application.
02-18-2010 10:55 AM
Secondaries Offline
RE: Coilovers
Like...?
Building an adaptor that fits into the spring cup, and accepts universal coilover sleeves, is pretty simple. 2 5/8" coilover springs are cheap and plentiful. http://www.stockcarproducts.com and Summit both have everything you'd need as far as the coilover parts.
02-19-2010 02:00 AM
RE: Coilovers
Like...?
Ok, that is basically what I have been thinking about as well, but wanted to hear your ideas. I'm considering making adapters/towers that bolt into holes where the spring cups are originally bolted into the lower control arm and drilling a few holes in the upper spring seat area of the body.
(This post was last modified: 02-19-2010 12:35 PM by tantank79.)
02-19-2010 12:34 PM
RE: Coilovers
What about on a wagon? The SLS shock mounting points were designed for load bearing.
(02-17-2010 11:03 PM)Secondaries Wrote:  Generally not a good idea. Shock mounting points were meant to be used only for damping, not for load bearing.
02-25-2010 11:32 PM
