I've contacted ATS to see if it would be possible to enter my 300D for some 1/4 fun-run drags on August 1-2. By then I should have most everything done except a Myna pump, water injection and internal transmission modifications.
1982 300D VNT Modifications: M-Pump, Holset HE341Ve VGT turbo, A/W intercooler, W115 300D intake, straight pipe exhaust, #265 nozzles, 2-micron Baldwin fuel filter, W126 Gen-II 300mm brakes, battery relocated to the trunk, HVAC systems removed, 15mm rear sway bar, 3.46 diff, Mobil1 15W-50 synthetic oil and Galant front seat. Down for Holsetification.
Quote:Forced-
The Sunday portion will be open to diesels in general so you don't have to have a truck to race. Look forward to seeing you out there!
---Please include previous text in return emails---
Thanks
Matt http://www.ATSdiesel.com
Matt@ATSdiesel.com
Since the current pump needs replacing, I'm planning on swapping in the "stock" M-Pump and turning it up. If I can find a 98-99 E300's pump for cheap I might have an injection shop swap in the elements and calibrate it.
Well, at this rate the Holset won't be ready for the race and the M-pump won't have the 6mm elements. I don't want to put the GT22V on the 300 since its working so damn well on the 240 I don't want to disturb it.
I'll probably just max out the m-pump, turn up the T3's boost and increase the modulator pressure. Although I'm not sure if I even want to bother without the Holset.
Are you going out to bandimere? in Co I might show up there for the hell of it. I don't think my 240 will be set up by then though!
1980 240d stainless brake lines w116 vented brakes Bilstein HD shocks euro lights with HID's and Hella 500 fog lights 16X8 wheels off an SL awaiting 616 turbo 4spd conversion! pwr windows, man sunroof
I started installing the Rajay turbo on my 240 today and if I can get it running in time I'll bring it up and run it! What needs to be done for tech inspection I think I need a water reservoir bottle any thing else I should worry about?
(07-16-2009 05:11 PM)willbhere4u Wrote: hay F.I. do you know what has to be done to the car to get it through tech??? for the drag race? I think it needs an overflow boodle for the rad? thanks Will
I've never been part of the races, but what I've read so far for a street car to pass is an overflow bottle (I'm not sure if I need one since it uses an expansion tank), a battery tie down, a working neutral safety switch, seatbelts and good tires.
neutral safety being an automatic? my car is stick and will start with the clutch out? I think it was built like that though! I will have to fix my battery tie down!!!
see if you can find out if we have to preregister or if we can do it when we get on the 2nd and what is the fee o get in? thanks will
1958 MB 219 6cyl duel carbs with wabasto sunroof
(This post was last modified: 07-16-2009 06:48 PM by willbhere4u.)
(07-16-2009 06:46 PM)willbhere4u Wrote: neutral safety being an automatic? my car is stick and will start with the clutch out? I think it was built like that though!
My 240D is the same way so I think it would be acceptable since its factory.
Quote:I will have to fix my battery tie down!!!
Good luck finding one! I have only come across one set in the junkyard. If you do need one, I have 1 spare. Worst case, I have some cargo straps.
Quote:see if you can find out if we have to preregister or if we can do it when we get on the 2nd and what is the fee o get in?
The 300D is finally track-legal. Last August I had to use an old washer bottle as a catchcan because the track requires a 16+oz coolant container, even if the system is an expansion tank type.
The bracket is from an early-80's Mazda RX-7 and the tank is from a 90's Mitsubishi Montero. Its bolted to one of the old battery tray mount holes.
Note: Don't worry, green is only for the intercooler circuit. The engine uses the correct yellow.
