injector nozzle question
btrapr
I know I have seen some posts where VW injectors were used...
My question is do the VW nozzles themselvs for like a 1.6 or 1.9 diesel?
I have seen these listed for VW
The DN0SD265 nozzle
I thought I might be able to use these in my Mercedes 617?
I also saw some posts about the 240 nozzles
Does anyone have a source for these?
*How would you rate the Monark nozzles against these?
thanks
in Advance
1984 300SD- 260K-
1982 300SD *both SD's are white with Navy interior!
1984 Chevrolet M1008- 1 1/4 ton 4x4 with "J" code 6.2l N/A
1990 Chevrolet Suburban 4x4- 6.2l with Banks sidewinder turbo
| 03-07-2010 10:54 PM |
RE: injector nozzle question
DN0SD265 is an MB nozzle used in OM601/2/3 engines, not VW.
240/ nozzles are technically better in the 61x engines, but the prespray hole clogs easily.
There is no significant advantage to using either except quieter idle with the 240/ nozzles. Injectors are not a limitation on IDI engines like they are DI engines since there are no orifice holes to inject through.
The VW parts used are just the 2-stage injector bodies themselves, MB nozzles were installed.
| 03-07-2010 11:02 PM |
btrapr
[b]Thanks ForcedInduction  !
I thought that was true about the 265's but I found a guy that has them but he listed them for VW...
I have a set of Monarks in the wagon and they seem to work well...got a set of 240's out of the wagon that look pretty good just not sure how to really check them...I thought about putting the 240's in my 240D...
*I have two of those early 5cyl n/a manifolds on the way. I want to add some items to my 300SD...the others one will be going into my 240d 4spd manual car when I put a 617turbo in it...
1984 300SD- 260K-
(This post was last modified: 03-08-2010 10:15 AM by btrapr.)
| 03-08-2010 10:12 AM |
(03-08-2010 10:12 AM)btrapr Wrote: I thought about putting the 240's in my 240D.
It should have them from the factory.
| 03-08-2010 03:44 PM |
