RE: axle compatibility, 1 piece vs 2 piece on 123/126 chassis
I too prefer annulars for their ease of service, but you have to make dang sure the bolts are torqued properly and preferably with loctite applied.
| 06-10-2010 05:39 AM |
charmalu
(06-09-2010 09:52 PM)dropnosky Wrote: ok great, I have a number of C clips from multiple junk yard homokenetic axle failures until I wised up and just bought some new ones.
The annulars do look way easier to service, im excited that the car has them to begin with, and they are not yet horribly cracked. I give it a few months though.
thanks
I think I might have missled you some in my first post.
The "C" clip should fit snug, true. It is the spacers that can be purchased from the dealer in various thicknesses. I don`t know the range they are in though.
I forgot to mention to use Locktite in my first post.
If any of the Chinese axles are purchased, make sure to double check these bolts. especially if changing from Homo to annular axles. don`t just change them over and think you are good to go.
there were a few member over on Peach Parts that had the bolts loosen up.
Charlie
(This post was last modified: 06-10-2010 10:31 AM by charmalu.)
| 06-10-2010 10:21 AM |
Rudolf_Diesel
So I can order axles for a 300D and use them in my 300SD? It looks like they are the same, I have been searching online and cannot seem to find any SD axles, only 300D - I wonder why?
The car I took the diff out of was a 1981 240D and had one of each style. I want to get the annular style as it looks as easier to service and not have to remove diff cover.
| 07-23-2010 11:38 PM |
Rudolf_Diesel
After doing some research, it looks like the W123 will not work - maybe length differences?
I did find some good information on EPC, the following will work for a 1982 300SD:
- 280S
- 280SE
- 280SEL
- 350SD
- 350SDL
The new replacement axles require a flange for the annular axles and they are all the same part number: A124 357 0289
Off to the Junkyards to do some searching...
(This post was last modified: 07-24-2010 09:52 AM by Rudolf_Diesel.)
| 07-24-2010 09:51 AM |
