I was just thinking, if you wanted to take weight savings to a certain extent before things became truly stupid, that's what I'd look into. I'm going to pull the AC parts off of my car pretty soon, I'd like to get the heater working for the winter though (is the blower itself as craptacular as the controls seem to be? No heat in the winter in the high desert sucks!)
Considering how kinda porky these cars are (a similar sized Volvo 240 or 740 is quite a bit lighter), and how limited tuning options are for maximizing power, weight reduction makes quite a bit of sense as a pursuit to get the most out of these cars. However, real life also intrudes, so I was looking at how to drop weight without having to strip out the back seat and all. I'm sure someone would be cool with having a stripped out 123 for max performance.
Recalling the sticker shock of VW 'Euro-spec' parts, how many pounds of flesh does a pair of Euro-style bumpers go for?
Since discovering that one of my favorite five speeds is very compatible with the OM motors, I've even had this thought: want max performance from a OM powered car? Wish MB had built a lightweight, cheap, swappable chassis for these motors? Well, MB didn't, but Toyota did.
I bought a brown on brown 83 Celica awhile back for use as a beater, and remembered that these were the basis for the contemporary Supras of the day. Only they weighed less, and had a five-linked rear axle rather than a semi trailing arm IRS (I liked the axle better - handled similarly, but STA IRS designs launch from a stop like shit, either hopping the wheels or gaining too much camber and laying down 1" stripes from 7" tires!). They're completely sleeper, especially in brown, but a satisfying drive, even with a truck motor like the 22R. I wanted to use one for a V8 swap (think 7/8 scale Camaro but with better steering and a factory five link instead of four), but it would work equally well with the OM617. They have enough room for a straight six, weigh less than 3k pounds fully equipped, have an aftermarket following that actually trumps the contemporary Supra so you can get upgrade parts for the chassis and suspension. Use Supra spec tires (225 60 14, I think) on Supra rims (14x7, about 13 lbs per rim), which might even come as part of the bargain as they were common on these cars. Four wheel discs are standard, and your HVAC might even still work!
Properly swapped, and applying the same kind of weight saving techniques as you'd use on a 123, this car would easily trounce our cars in the performance department. 3k is probably as stripped as you could get with a 123 and still want to drive it daily. My Celica was about 2800lbs with an iron 22RE in it's nose, spare tire and jack, all options. You could probably get it down to 2500 without much investment (which is about the weight of a stock MR2 Supercharged). That would make the power of the OM go a lot further, not to mention it having a naturally lower center of gravity and more 'flickability' from it's shorter wheelbase. Even has a degree of better utility if you get a hatchback model. It's not going to be 'bush-taxi tough' like our cars, and for rallying ours would probably be superior, but it's a thought. I'm not positive but if you got an engine from a car the same year or newer as the chassis you want to swap it into, it might even be Cali smog legal.
Even lighter, and certainly a more beautiful car (probably my favorite Japanese design) would be a 240Z. It would take more work, and be more expensive, but it would be quite worthwhile in my opinion. The 240Z only had 140hp stock, so being 10hp off with a stock OM617, but with better torque response, would make for a similar driving experience, which is to say, a very good one. A 2200lb RWD car with a VGT'd OM would be a cool ride, a different take on the 'Scarab' 240Z/350 Chevy setup.
Sigh...another badass car I'll probably never get to build.
(09-05-2009 03:23 AM)kamel Wrote: Wow, you've got some ambition CID. Radio? you mean the turbo? can't live without mine. As far as sunroof goes, sure is nice not having one.
Well, no turbo just yet. I'm barely around to replacing axles at this point, still have the old air filter in place, and have been driving the car sans power steering since June - belt got tossed. Not exactly the budget I like to work with but that will change soon enough. I'll be happy just not having to worry about the CV joint breaking in the back and leaving me stranded.
Ideally, I'd have a VGT'd OM617 swapped into my 240D for use as a daily driver, and another in one of the cars mentioned in the previous post for foolishness. I'll be happy if the 240D just keeps rolling along in the meantime. Keeps me out of trouble.
