  • 1 Votes - 4 Average
Turbo funny Noise?
Turbo funny Noise?
ok the other day as i was awaitg the gaskets for the turbo drain i had the kkk turbo already installed and ready to go on the car. by accident when i sat down on my chair to eat i started my car from the remote start button. luckily my fiance said she heard something running in the driveway. To my surpise when i opend the garage the car had pumped 5 quarts of oil on the pavers below from the turbo drain!! and i shut it down right away.
I changed the oil as it only had 3 quarts in the pan. Is there any way the turbo could be damaged if the car was running for a coupl mintues without the turbo drain on top of the turbo connected?
the kkk makes more noise then the stock turbo i had. is this normal?
02-09-2010 05:50 PM
RE: Turbo funny Noise?
If it was sitting at idle it probably wouldn't hurt it but keep an eye on the sound and make sure it doesn't change over time
the turbo doesn't spin very fast at idle so any oil at all should do the job
that line is the turbo feed line the drain is on the bottom
(This post was last modified: 02-09-2010 06:45 PM by willbhere4u.)
02-09-2010 06:44 PM
It sounds like a supercharger now but thats only on acceleration and every time i get on the gas pedal.. When im crusing its fine. It just that i never hrard the stock turbo now the kkk sounds like a supercharger whine.
I forgot to mention that this only happens under a load like when im driving. When i have the car idle and give it gas its sound normal like my t3 did. but under a load i get loud whining/screeching sound from the passenger side above the dash.
quote='willbhere4u' pid='10557' dateline='1265759073']
[/quote]
(This post was last modified: 02-09-2010 09:17 PM by W116Lorinser.)
02-09-2010 07:51 PM
(02-09-2010 07:51 PM)W116Lorinser Wrote:  I forgot to mention that this only happens under a load like when im driving. When i have the car idle and give it gas its sound normal like my t3 did. but under a load i get loud whining/screeching sound from the passenger side above the dash.
can you post a recording? also: what kind of intake are you running? is it stock or a open element?
as far as the difference between idle and normal, that is because the turbo doesnt make boost unless it is under load (more exhaust energy to spool it up)
02-11-2010 09:51 PM
Im also getting alot of exhaust smoke? I never had any before on my t3. Does this mean the turbos done?
uote='SurfRodder' pid='10591' dateline='1265943064']
[/quote]
02-12-2010 01:55 PM
