RE: Multilink rear suspension for a W123?
Maybe when I get down to the junkyard I'll take a tape measure and see how compatible the two designs are. No offense to your efforts - you seem to have one of the more worked 123s this side of Finland - but at the development level that the OM617 is at, even a stock Goodwrench 350 will likely blow it out of the water as far as power output. I'm thinking that the squat is going to make the car hard to get to hook, and likely to lose traction (possibly in a real bad way) putting power down mid corner. No 123 I can think of even approached the 200hp mark from the factory, much less 3 or 4. So I can't say that I think the engineers had this covered, and as I pointed out before, almost all platforms that used an STA type rear suspension did so for one generation only. Some, like the RX7, didn't even bother with the STAs, moving from a five link solid axle to multilink directly. I'd have to say there's a reason for that.
Although, I don't know for sure that a stiffer set of springs wouldn't make it manageable, if not entirely cure it. If someone wants to chime in here about that, it would help me and pretty much all of us out. I'd like to think there's a silver bullet out there that might make the idea of an 'easy' 250 hp OM617a feasible, and if so, then quite a few of y'all might be wondering the same thing that I am now.
If I didn't live in Kalifornia, I'd probably just find a W124 with a bad motor for cheap and V8 that. It would be quite a bit easier from a pure performance standpoint, but then again, I could do the same thing to a second gen RX7 and it would be a bolt in affair with a better return on the performance side. The 123 appeals because of what I'm considering with 'Project Blasphemy' - stealth, and the complete lack of a need to have the car inspected. I might be able to find a 124 that someone pulled the diesel from for another project, which would accomplish some of the same ends, but the vibe is different on those cars, as is the electronics setup. The 123 to me is a good bridge between old and new - good chassis and decent suspension but still simple and easy to work on, before the manufacturers decided they'd rather make the cars harder for the regular guy to work on (more money for the dealerships, and you sell more new cars if there are fewer old ones running around), ie built in obsolescence.
