Lug bolt info needed
HoleshotHolset Offline
I bought some 18" AMG style (monobloc ?) wheels + nearly new Continental M+S rated tires on Saturday. The bolt pattern + hub center + backspacing all appear compatible with my W210 - but the dang lug bolts are too long.
Any idea what model Merc I should use to look up some aftermarket lug bolts? Febi/Bilstein makes a lot of lug bolts...but I'm not having much luck finding anything but the ~2.5" long OEM lug bolts.
I tried looking up lug bolts for a 1999 E55 AMG - on the assumption that car used these 18" wheels. I'm going to take one of my OEM lug bolts and compare the "thread protrusion" between the OEM wheels and these 18" straight pimpin' rolling stock. The difference was ~1" when I checked on Saturday night - but I want to get a more exact measurement.
Thanks!
Beers,
Matt
'99 W210.025/OM606.962/722.608, 211k - straight piped, "tomnik mod". Total loss - parting out! Confused
'95 W124.131/OM606.910/722.435, 211k - soon to have mechanical OM606.962 with lots of fuel. Cool
'94 Dodge/Cummins - NV5600, P7100, 5-hole x .015" injectors, ~400hp - farm/plow truck
'01 Cummins "ISB 170" (common-rail, 3.9L, 16-valve), Allison LCT-1000 conversion - for sale.
11-02-2009 12:43 PM
RE: Lug bolt info needed
Lakeshore tires has cones and dome heads for cheaper than anywhere else in practically any size.
11-02-2009 02:16 PM
(11-02-2009 02:16 PM)winmutt Wrote:  Lakeshore tires has cones and dome heads for cheaper than anywhere else in practically any size.
Thanks! You're not kidding on the low prices. They have whole sets of them for $20ish - hope they're not Made in China. Smile
Beers,
Matt
11-02-2009 04:30 PM
I took a closer look at the wheels last night.
They're for a car with 14mm lug bolts - not 12mm lug bolts.
Any chance someone makes a 14mm lug bolt with 12mm threads? Smile
I contacted the guy I bought them from and he hasn't responded yet - so I may have the whole set with some really spendy and brand new Continental winter rubber for sale - cheap.
Beers,
Matt
I just called Lakeshore.
The nice dude on the phone said that I should be just fine running these AMG monoblocks (replicas) with 12mm lug bolts. He said that most wheels these days are drilled out to 14mm and that since the wheels are hub centric I will be just fine.
Major relief. Now I need to take some measurements for new (shorter) lug bolts and I'll be all set. I didn't bother last night because I thought the wheels were a lost cause when I discovered they were 14mm instead of 12mm.
I'll keep this thread updated with my results.
Beers,
Matt
(This post was last modified: 11-03-2009 10:07 AM by HoleshotHolset.)
11-03-2009 09:42 AM
Good to hear they are nice in person. Of course at those prices its probably made in China, but then again you get 5 bolts !
11-03-2009 03:50 PM
Here's the lug bolt info I've come up with for the 18" replica monoblocks versus the OEM wheels on my W210:
Required Lug Bolts for 18" wheels:
12mm x 1.5 thread, 17mm head, ball seat, 24mm thread length
OEM Lug Bolts for 16" wheels:
12mm x 1.5 thread, 17mm head, ball seat, 39mm thread length
So far, so good on the 18" monoblocks. My vibration issue mostly disappeared with the "new" wheels/tires...so I must have had some really out of balance rolling stock before. Yikes.
11-16-2009 02:12 PM
