Current time: 02-09-2012, 02:40 AMHello There, Guest! (Login — Register)
Some simple board rules have been posted. I recommend that you read and follow them so that we can all enjoy this shared resource. Last updated on 3/14/11Board Rules
Had a good score at pick yer part today, pulled a set of w114 euro bumpers, a Momo bmw steering wheel, ford 9", and made a pretty cool discovery. I found a 280c with a full cloth interior in good condition. I may go back if someone wants it or hold onto it for good luck. The w114 was a 220d and had a M-pump if anyones interested. One sad discovery was the pimp my ride 300sd, it was a disgusting pink, had a 1/4" of bondo all over, and a white/fur interior. Turbo was still good though.
I sized up the bumpers and they will fit with minor mods, or someone can trade me a set of 123's.
(01-02-2010 02:28 AM)kamel Wrote: .........One sad discovery was the pimp my ride 300sd, it was a disgusting pink, had a 1/4" of bondo all over, and a white/fur interior. Turbo was still good though.....
I saw that episode, of all the great things they could have done, they come up with that. Those "restore your car in record time" shows are a joke, all they do is promote hack jobs to finish on time, and especially with pimp my ride, stuff that basically has no resale value. Who would buy that car now?
I did like overhaulin' though, still think its a little too quick for a really lasting job if there is any bondo work, but the designs are really tasteful and attractive IMO.
The difference is between seeing a car for personal appreciation or as a public spectacle.
If I remember correctly, they came up with a horrific rotating hood ornament, you should grab those parts if they are still there. Mechanically, might be some interesting parts to have
(This post was last modified: 01-02-2010 01:37 PM by dropnosky.)
Aw, come on dropnosky, you could always drive it home, take some pictures, and make enough money off of eBay and craigslist selling that crap to goofball hoodrats to buy a real car .
Obviously for 'a certain audience'. I love the episode of The Boondocks that has Pimp My Ride on, thought it was a great parody. It's for people for whom the now old school Playstation install was the most mind-blowing automotive modification they'd ever seen...
Having worked in a body shop, I'd say Overhaulin' probably does their homework and gets decent junkyard parts in advance of the show. Once the part is in primer no one on TV can tell it's not the 'fixed' original panel. PMR, on the other hand, I'm sure that bodywork has all of the quality of an "I need my limo back in 8 hours" special. (That's a fun day at work, of course one can always just look for the requisite coke mirror stashed near the driver's seat .)
(01-02-2010 11:43 PM)CID Vicious Wrote: Aw, come on dropnosky, you could always drive it home, take some pictures, and make enough money off of eBay and craigslist selling that crap to goofball hoodrats to buy a real car .
You are right! Ive painted enough of my own cars with spray paint that I really shouldn't knock this car.
I'm sure we all went through the "flat black" stage. Although for me, I thought that you could turtle wax flat black paint to achieve an intoxicated induced form of 'semi-lustre'. Nope, in fact its hard to make a car look worse without actual physical body damage.
Is this pink gem still complete? or has it been stripped of its valuable bling?
Man, if I wasn't concerned with flying under the radar, you guys would have already given me shit about my flat black 240D. Well, that, and I live in the desert, so you can imagine how that works out. Mexican blanket seat covers, goofy foot gas pedal (check!), gloss red 'steel look' aluminum wheels from a later hubcap car with beauty rims and chrome 'nuts. There's worse things you can do with an old beat up 123. And it would be light years cooler than that giant block of solid cotton candy.
Flat black has to be done right. Start out with about 20 cans of 99 cent Home Depot flat black (I'm constantly buying those) as a base coat and once you have a decent base, topcoat with the best rattle can stuff you can get. Heat up some water in a pot, place the cans in the pot and let them get warm (I've actually had the flame going under the pot with four cans in it, just don't get stoned and chase a butterfly around the yard while that's going!) and the paint will come out much better - the higher temp lets the paint mix and flow better, and the higher pressure in the can results in a better spray pattern. The only way to fly when spraying in cold weather.
I wonder if the Brightside marine paint could have a flattening agent added to it for a 'roll on' flat black. Although, really, I'd probably just do the extra bodywork and go gloss black at that point.
But yeah, flat black done wrong will make a perfectly good car look like a burnt out shell from a third world war zone. I'd add up the cost of rattle canning a car - you might be able to get a local body shop to hose your car down with black Urethane primer for a similar amount, and it'll look way better, less work on your part, and if you decide to go gloss later just wetsand it flat and get to it. Urethane, not Lacquer - the lacquer primer doesn't seal against water. Even in LA you'll start getting rust spots over time.
I found a run-over Acer laptop in the Colorado Auto & Parts parking lot. Got a good 80gb hard drive out of it.
Edit: LOL, the user name is "Filty Rich"
Edit2: This guy left a lot of data on there. He is lucky I found it instead of some punk that would try to steal his ID.
(This post was last modified: 02-01-2010 06:07 PM by ForcedInduction.)
Was the 420sel the w140 new body S class it looked like a 6cyl? I saw that volvomino Saturday I got a good haul of euro w126 parts at the upullnpay in Denver
both euro bumpers modified to fit US spec cars
I also got heater controls in french
and the fan fare horn and switch
I also snagged the euro headlight adjuster switch!!!
I picked this up past weekend. It's a 2.47, but unfortunately it is in a 2nd Gen w126 flavor. Hmmm now what to do with it... Put it in a 2nd gen w126? Play around with it and transfer the guts to a 1st Gen housing? Sell it? It most likely would need big buck clutches since the odo says it has 210,000 miles on it. Hmmm.
The almost grab of the weekend is a 116,000 mile 617.952. Was just about to pull it and while under the car I noticed oil along the left side of the under belly. Upon closer inspection of the oil pan was crushed and cracked (reason to have a skid plate). Decided to open it up and look at the #2 bearing.... Deep scratches on the bearing surfaces and scratched up journal. Damn! Could of been the 3rd 617.952 I own without a car!
(This post was last modified: 07-05-2010 06:19 PM by DeliveryValve.)
I got a pair of w126 euro front,rear bumpers a euro fan fair horn and switch + the euro headlight adjuster switch and heater control's in french! + I got a rad and fan and fan clutch for my 300sdl from a tow yards online shipped! put them in to day and drove it to my new house with no issues!
I firmly believe that it is possible to put a 2nd gen w126 diff in a 123. The problems being drive shaft length.
(07-05-2010 06:16 PM)DeliveryValve Wrote: Hmmm now what to do with it... Put it in a 2nd gen w126? Play around with it and transfer the guts to a 1st Gen housing? Sell it?
(07-06-2010 09:43 AM)winmutt Wrote: I firmly believe that it is possible to put a 2nd gen w126 diff in a 123. The problems being drive shaft length.
It's probably possible if you make custom adapter blocks or do some major welding.
See pics.
Side view of mounting system, Left 2nd Gen and right 1st Gen
Top view of mounting system. Top 1st Gen and Bottom 2nd Gen
Rear view mounting system. Left 2nd Gen and right 1st Gen
Oh some work would be needed but the mounting location between 1st and 2nd is the same, the body is the same. It would be possible. Probably the cheapest route to get a real LSD in a W123.
(07-08-2010 12:47 PM)winmutt Wrote: Oh some work would be needed but the mounting location between 1st and 2nd is the same, the body is the same. It would be possible. Probably the cheapest route to get a real LSD in a W123.
Yes cheaper if you can find a good one. Then if you do find one, the clutches/friction disks most likely need replacing. Now it's going to get expensive.
I think I will go the route of swapping housings at some point. I would like to gain experience of how to set these things.
So getting new clutches/friction disks would be on the list. There are a couple of brake/clutch relining shops here in town, I wonder if they have the capability to re-line these plates. Although different (but concept is still the same), my buddy had some hard to find brake shoes relined locally for 20 bucks. The other thought is using existing transmission friction disks. Might be too far-fetch though.
(This post was last modified: 07-08-2010 12:58 PM by DeliveryValve.)
(07-08-2010 10:42 PM)charmalu Wrote: Dave, GSXR over on PeachParts has done some LSD clutch replacments on the W124`s. It has to be similar type set up.
It is, my thinking is that it is easier to find good 126 LSD.
It almost looks like a locomotive, but it is a bit small for that, my guess is a big as generator. I have a piston from a locomotive and it is about 12" across and 14" tall.
1982 300SD:304,xxx Super M-pump with 7.5mm elements, 265 Nozzles, GT35 water cooled turbo, M90 Supercharger, A/W Intercooler, Serpentine drive belt, 3" SS exhaust with Magnaflow muffler, 240 breather, AEM dry Filter, Manual Boost Control, EGT / Boost / EMP gauges....Moved on to other projects
1995 F-350 7.3L PSD:230,xxx 6.0 IC, DIY Stage 1 Injectors, 17* hpop, Tony Wildman Chip, John Wood Trans, 6.4L TC, 3" down pipe, 4" straight exhaust, 310 HP on wheel dyno - 8500# dually: 0-60 in 6.98
Spotted two 190s with 5speeds, going back for a 240d 4speed, a om616 head, a pair of 2nd gen w126 headlights, a pair of euro w116 headlights, a boot for my stick, and a sweet trunk rack of a 80's Subaru i can adapt to my w123.
(08-03-2010 04:48 PM)garage Wrote: Spotted two 190s with 5speeds, going back for a 240d 4speed, a om616 head, a pair of 2nd gen w126 headlights, a pair of euro w116 headlights, a boot for my stick, and a sweet trunk rack of a 80's Subaru i can adapt to my w123.
Gooood day=]
Well today was 50% off day at ecology, so i got up at 6 to grab my goods that i stashed away, and all i ended up with was the euro w116 headlights..the car that the rest of the stuff was stashed in was gone, so i searched the yard looking for it..with no luck.
Sucks.
Gooood day=]
Sucks.
Damn, That sucks!
1982 300D Turbo ... The Tank ... E-fans, Exhaust/Down pipe ends at Firewall, A/C delete, ALDA delete, Rack limiter delete 2009 Buell 1125CR ... 146 American Made horse power on two wheels 1972 GMC Sprint (El Camino) ... http://www.youtube.com/watch?v=G73Q8cSpEbs 1988 Jeep Cherokee XJ ... The offroad master, Detroit Lockers, 4" Lift, 32 x 11.50 BFG Mud Terrains, Cut front fenders, bastard leaf pack
Gooood day=]
Sucks.
Damn, That sucks!
ecology has a 50% off day? niiiiice! you go to the one in downey?
Gooood day=]
Sucks.
Damn, That sucks!
Yeah they have a 50% off day a couple times a year i think.
No i havnt been to the one in downey.
Found a pair of pristine black front seats out of a 1989 560sel.
It dosnt have the normal MBtex type of material..i will try to get pictures up soon(i should stop saying that and actually do it huuh?)
Only $14.97each.
There not manual....but ill make it work
Got myself a new shift knob for the 4speed, one with the gears on it! My old one was all chewed up looking, like somone peeled all the material away.
It makes the interior look alot cleaner, and it is about 2 1/2inches shorter wich means quicker shifts
I also spotted a w126 280SE, with a wonderful looking light blue cloth interior, most of the cloth interiors i find are sunbaked and rip very easily, this was very nice.
Made me wish i had cloth seats.
