I'd ride the heck outta this!
Re: I'd ride the heck outta this!
Really. That is interesting. Those air cooled Yanmars don't even need (or have) a glowplug! The service trucks at work have one each for the air compressor and they start easily even in freezing weather with just the starter and compression release.
Is there a manual disconnect to stop parasitic losses of the front wheel turning the motor like a pump when its not powered?
I bet it would get 120mpg with a little bit smaller rider.
| 10-21-2008 02:49 AM |
patracy
ForcedInduction Wrote:Really. That is interesting. Those air cooled Yanmars don't even need (or have) a glowplug! The service trucks at work have one each for the air compressor and they start easily even in freezing weather with just the starter and compression release.
I didn't take a pic of the front "disconnect". It's nothing more than valves to close the flow from the pumps lines, with another valve joining the two lines together. So basically you close the pump flow off to the front wheel, open the connection valve, and the front system becomes a closed loop. There is still a slight drag, but nothing more than what your brakes cause.
I'd suspect it would get a lot better mileage with a smaller rider, rear only wheel drive, narrower motorcycle size tires, and better aerodynamics.
| 10-21-2008 09:09 PM |
squozzer
RE: I'd ride the heck outta this!
And here I was expecting a picture of Amanda Seyfried...
Diesel:
79 240D -- auto
Gas/Petrol/Benzin:
02 RAV4 -- daily driver
94 Jetta -- eventual 24 HOL combatant
85 K5 Blazer -- 377 SBC, 144ci huffer
68 GTO -- slowly rusting in garage
| 05-20-2010 01:28 PM |
