How do you remove wood trim from w116?
i want to remove all my wood trim because i want to have it sent of to autodynamicswest.com where they will redo it in silver carbon fiber. how do i remove these dash panels? are they glued on ?
07-30-2010 03:28 PM
RE: How do you remove wood trim from w116?
Very carefully!!!!
Its got lot of little nuts inside the dash last time I did it! I had to removed the heater controls the inside of the glove box and my speedometer cluster and play contortionist for about an hour with small wrenches and sockets in some places my bare hands and determination not very easy!
07-30-2010 05:10 PM
(07-30-2010 05:10 PM)willbhere4u Wrote:  I had to removed the heater controls the inside of the glove box and my speedometer cluster and play contortionist
with all that it might be better to just pull the entire dash out. Thats not too difficult.
07-31-2010 01:29 AM
Its alot harder than the w123?
On my w123 there were just little metel tabs twisted over behind the dash holding it in place..
07-31-2010 10:15 AM
