Help OIL Leak???
Help OIL Leak???
i just installed my k26 turbo today to replace the older turbo. after 30 years of baked on bolts and other things i finally got it replaced and installed. i dont know what the peice is called but it the peice that right on top of the turbo with the 2 bolts and has a small gasket on it. the little gasket broke so i threw it away without a replacement and just tighted the bolts up and used the "gasket making silicone" from autozone. After i started the car it started to leak right away out the sides.
is this because it specifically needs that gasket? and where do i find this gasket?
ps. is this the peice? and its the turbo drain? will a new one stop the leak?
http://www.autopartswarehouse.com/detail...widMjZ5S86
(This post was last modified: 02-05-2010 09:10 PM by W116Lorinser.)
02-05-2010 09:07 PM
RE: Help OIL Leak???
That is the oil feed for the turbo. You can just buy some gasket material and cut one out. I would stay away from silicone on anything that is involved with the oiling system. I once had a Datsun that had silicone block a passage and snapped the cam. You could even use a cereal box for the gasket material in a pinch.
02-05-2010 09:34 PM
so its leaking because no gasket... correct?
and it not something wrong because of the new turbo right? just getting paranoid when i see leaks... i always think the worst.
02-05-2010 09:49 PM
It needs a gasket in there! It has high pressure oil in there to lubricate it
02-05-2010 10:14 PM
^^What he said - at 3 Bar you have 43.5 psi give or take. Most likely it is leaking because you do not have a gasket.
02-05-2010 10:20 PM
But the exact same piece below the turbo doesnt have a gasket? Only the top one does?
02-06-2010 10:30 AM
(02-06-2010 10:30 AM)W116Lorinser Wrote:  But the exact same piece below the turbo doesnt have a gasket? Only the top one does?
They both should have a gasket, but the other side is not pressure fed, it is the drain line.
02-06-2010 01:35 PM
what about these oil drain and retun kits on ebay ? they look nice and say they will work better? can it work as replacement?
http://cgi.ebay.com/ebaymotors/ws/eBayIS...K:MEWAX:IT
02-06-2010 06:28 PM
It wont add any performance the stock parts work just fine for the stock turbo!
Those kits are more useful if you plan on putting a non stock turbo on there!
02-06-2010 10:15 PM
